Procharged G35
Old Jan 20, 2015 | 07:55 PM
  #101
Conway_160's Avatar
Conway_160
I'll also be running 11:1 compression.
Old Jan 20, 2015 | 10:11 PM
  #102
Danoman32's Avatar
Danoman32
How do you guys get away with that? Pull lots of timing?
Old Jan 21, 2015 | 07:50 AM
  #103
Conway_160's Avatar
Conway_160
You shouldn't have to pull much timing. If you run E85 you will not pull any timing at all. Think about it Vettes, HR motors, Hondas, alot of cars now a days is getting higher compression and people are putting so sort of forced induction on to them with no problem.
Old Jan 21, 2015 | 10:15 AM
  #104
jdm-v35's Avatar
jdm-v35
Originally Posted by 2bad240
http://youtu.be/EJn1kCyIdaY
thanks! now I know it can be done, so I will probably up the boost more when I can.
Old Jan 21, 2015 | 11:28 AM
  #105
Danoman32's Avatar
Danoman32
Huh, never heard of anyone doing this, aside from an all out race motor on race fuel. Good luck and let us know how it works out.
Old Jan 21, 2015 | 11:37 AM
  #106
OldManZ350's Avatar
OldManZ350
You need to do your own testing. It needs what it needs.
With 11:1 CR It all depends your whole Setup, Fuel type, How much Boost, and Camshaft. No two cars are exactly the same. MBT is Key......
TimRod
Old Jan 21, 2015 | 04:58 PM
  #107
Danoman32's Avatar
Danoman32
TimRod
Derp.....
Old Jan 30, 2015 | 08:51 AM
  #108
Conway_160's Avatar
Conway_160
Just got my motor back from the machine shop, crank is all shiny and line hone is done to the block. Was told all of my clerances are standard. Wtf does that mean I dont know.. looks like ill be getting a micrometer to measure and see what bearings I need to get .0030 clerances.
Old Jan 30, 2015 | 09:23 AM
  #109
Danoman32's Avatar
Danoman32
They didn't give you a spec sheet? Lol
Old Jan 30, 2015 | 09:49 AM
  #110
Conway_160's Avatar
Conway_160
Nope no spec sheet, I asked what my clearances were and they told me Standard...
Old Jan 31, 2015 | 10:07 AM
  #111
Conway_160's Avatar
Conway_160
MAIN BEARING OIL CLEARANCE Standard : 0.035 - 0.045 mm (0.0014 - 0.0018 in)
Limit : 0.065 mm (0.0026 in)
CONNECTING ROD BEARING OIL CLEARANCE Standard : 0.034 - 0.059 mm (0.0013 - 0.0023 in)
Limit : 0.070 mm (0.0028 in)
So with that being said, wtf should I put my bearing clearances at?
Old Jan 31, 2015 | 04:46 PM
  #112
OldManZ350's Avatar
OldManZ350
Don't know how much the machine shop is doing for you, but
The machine Shop can not tell you what the clearances are, unless they installed the your crank in your block with your new bearings.
Standard means: that they measured the crank journals and they were within stock tolerance. You need a spec sheet from them.
To gain bearing clearance you can buy bearings that will give you .0001" over stock. ACL makes Race Series Bearings for this purpose. If your building the motor, everything still needs to be miced to verify clearances though.
Also if they polished your crank it will give you an extra .0001"-.0002" depending on how much they did.
TimRod
Old Jan 31, 2015 | 05:57 PM
  #113
Conway_160's Avatar
Conway_160
Ok thanks tim, im going to order my acl hx bearing then platiguage them to see what my clerances are.
Old Feb 1, 2015 | 02:50 PM
  #114
Danoman32's Avatar
Danoman32
Plastiguage......smh
Old Feb 1, 2015 | 04:06 PM
  #115
Conway_160's Avatar
Conway_160
Lol what's wrong with plastiGuage? I don't know of a better way to get clearances.
Old Feb 1, 2015 | 04:45 PM
  #116
Danoman32's Avatar
Danoman32
A Mic and a bore gauge.... Good luck with this motor.....
  #117
Danoman32's Avatar
Danoman32
Do you think pro engine builders use plastiguage?
Old Feb 1, 2015 | 04:50 PM
  #118
Conway_160's Avatar
Conway_160
Yes?? I have no idea this will be my first experience.
Old Feb 2, 2015 | 01:56 AM
  #119
Resmarted's Avatar
Resmarted
Get a proper micrometer.
Or you'll be doing this again in 6 months, with this engine in the dumpster.
If this is your first build I strongly recommend you have a reputable builder put it together for you.
Seriously. A shop that knows these engines and who can set it up properly will save you double what you pay them. Trust me on this.
I've seen plenty of engines, outside Vq35's, eat sh*t and die. 1jz's, 2jz's, rb26's, ej25's, 4g63's, s54/m54. They all eat sh*t and die. Mainly because somebody who didn't know how to do what they needed to do, put it together.
Either that, or you need to do a bunch of engine building research.
Knowing what clearances is one thing... this is actually not that hard for most builds. But knowing how to check those clearances, how machines run, even how to use a feeler gauge correctly takes practice. Every machine and micrometer, torque wrench and feeler has some "error". Good machinists know how things run, and what each part needs to do, how each material acts under stress and can compensate. Great machinists have it down to an art.
Leave plastigauge for your junkyard build/beater build. Don't do it on your vq35. You'll be crying.
Old Feb 2, 2015 | 12:38 PM
  #120
OldManZ350's Avatar
OldManZ350
I will be 61 years old in march. When I was a kid growing up in the late 50's and 60's and early 70's I helped or should I say watched my Dad build Hi performance street/strip motors starting at the age of about 5 years old.
Back in the day plastigauge was a very common practice. Mainly because it was inexpensive. Of corse we had a good local machine shop and always got a spec sheet. My Dad always used Plastigauge to verify bearing clearances.
These motors were run hard and for many miles, and lots of time at the strip and playing on the street. Out of 6-8 motors built that I can remember, they all ran very well and never had any issues. My Brother in his 1960 Ford Falcon with a 289ci would Trophy nearly every weekend for the Class C/Modified Production. It was always towed from the finish line back to the Pits. At age 13, my Brother would let me be the tow car driver. I should note that my Trophing Brother was only 16 years, and with my Dad's help he would beat out all the pro cars and drivers for his class......
All that said, Today I would never build a HiPo Motor without the Proper Tools and Measure everything.
TimRod
