Another Daily Driven Vortech Build
Old Jul 2, 2018 | 03:09 PM
  #361
WTFMike's Avatar
WTFMike
Glad to see you got your issue sorted out. When my first built motor let go, I let everything sit for a bout a year before rebuilding it. On a whim before I fired up my new motor I had my Precision 1200cc injectors tested/cleaned and I'm glad I did. My #4 was stuck too. I was running ethanol when my last motor let go. So, my fuel system sat for a year with ethanol in it.
Old Jul 3, 2018 | 08:04 AM
  #362
BluestreamDE's Avatar
BluestreamDE
Thanks man. I've been using the same gas station when I was in TX and now here in SC for approx 18 months daily driving before having issues with my injectors. I may need to test and clean them every year just to be safe from now on.
My fuel pump filter looked fine with a few spots of dirt as well when I checked it. Did you change your fuel pump out as well?
Old Jul 3, 2018 | 09:56 AM
  #363
WTFMike's Avatar
WTFMike
When I first fired up the new motor, in November, I was running a single 450 pump in the OEM hanger. That pump only made it to January then I started having issues. The pump started losing pressure, so then I swapped it out for a new 450. And in April I added the CJM twin pumps and an Aeromotive in line filter. I'm leaning towards having my injectors cleaned/tested every other year. And I'll replace my filter probably every 10-15k miles as a bit of preventive maintenance
Old Jul 3, 2018 | 10:09 AM
  #364
BluestreamDE
Thanks for the reply. I'm waiting on that CJM Twin, haven't seen any updates on their site being available yet. An inline fuel filter would seem necessary as well with ethanol usage, thanks for sharing.
Old Jul 3, 2018 | 10:56 AM
  #365
bealljk's Avatar
bealljk
on the CJM RFS setup I spliced in a fuel filter and eliminated the in-tank sock ... I picked up a used Peterson nascar fuel filter and it's perfect ...
simple, practical, inexpensive...
Old Aug 11, 2018 | 06:28 AM
  #366
BluestreamDE
Back home after 6 weeks, time to reinstall my refurbished injectors.
Old Aug 11, 2018 | 10:59 AM
  #367
BigBlue's Avatar
BigBlue
Looks great! Question: What is that BIG roundish silver thing near to your driver's side headlight?
Old Aug 11, 2018 | 11:19 AM
  #368
BluestreamDE
Ohh that thing? Some YSi leafblower ...
​​​​​​Started up the car and no misfire. Idles a bit rough on 2 month old e85 so I dumped in a fresher 5 gal jug I had in the garage. It was a bit richer at idle since the injectors are flowing much better, so I reduced some fuel comp around idle and light load tables for now and it seems to idle fine at 1100rpm. Wisest 200 dollar fix.
I do hope this helps those with pump e85 setups as I had no ideal how fast injectors would get reduced efficiency, and shorter operating life on it. Be mindful to check your injectors at least anually as good maintenance with running cornjuice.
Old Aug 14, 2018 | 09:07 AM
  #369
BluestreamDE
So today I experienced some misfiring under load with regular driving that accompanied the blinking cel on the dash. I Was messing with the pigtail adaptors for my injectors while the car was running and on 2 of them if you move them a certain way, it will cause the engine to struggle at idle, so imaging driving the car and based on how much the car vibrates, it effects the connectivity to signal the injectors accurately to open and close. So some new pigtails are In order, as well as a multimeter. Car was fine these few days until now.
Old Aug 14, 2018 | 12:57 PM
  #370
bealljk's Avatar
bealljk
Interesting ...
I have had intermittent missed/non firing (no CEL though) at high engine load instances ... not sure if my pig tails are faulty or not??
Old Aug 30, 2018 | 10:30 PM
  #371
BluestreamDE
Update on the car, I will be going under the knife to do some headwork on the car. Going to be running full JWT. S1 Camshafts/Springs+Shims, and porting the heads. Car is no longer going to be daily driven and will be a full on project car. Updates will be as frequent as I can. Very excited on this.
Old Aug 31, 2018 | 04:08 AM
  #372
Conway_160's Avatar
Conway_160
Damn, looking forward to this!
Old Aug 31, 2018 | 08:42 AM
  #373
bealljk's Avatar
bealljk
we'll need more updates ... come on!!
Can we assume it will still be street legal?
You have L19s right? What head gasket are you going to put back in?
Old Aug 31, 2018 | 09:47 AM
  #374
BluestreamDE
I am running Tomei Head Gaskets which are cosmetic and have no issues with them so I will more than likely run them again. Yup L19s are on the car.
I'm also taking the AC out the car as well to run all the bigger piping that came with the kit. Car will still be street legal but without AC this car will just be a weekend toy after its all said and done.
Old Sep 26, 2018 | 02:40 AM
  #375
BluestreamDE
Not much of an update, but life has thrown yet another wrench in my path, good news that it's not a car issue. My HVAC has stopped working at my home, plus I need to buy a new fridge because for some reason this am, I woke up to a puddle surrounding it, and it damaged the wood underneath it, looked like it was doing it for a while but didn't notice. So going to be proritizing my racecar funds to home improvements.
There are mods I can do for free for the time being, like installing my used Setrab oil cooler upon doing my oil change soon. I also have an RJM pedal that has been collecting dust, we'll be doing this once I have time...
Old Sep 26, 2018 | 08:05 AM
  #376
BigBlue's Avatar
BigBlue
Good luck with all of these personal/home items Bluestream, I hear you on the home projects; I've been forking out thousands of $ the past couple of yrs. getting this place fixed up one project after another. I look forward to you getting that beast on the road again!
Old Oct 5, 2018 | 10:00 AM
  #377
BluestreamDE
Finally made a walkaround video.
Not the best quality as I dont record stuff normally, but Enjoy.
Old Oct 5, 2018 | 02:05 PM
  #378
BigBlue's Avatar
BigBlue
Wow! The car looks and sounds badass! I love the V7 sound and you did a great job with the video also. Congrats; how is it running?
Old Oct 5, 2018 | 02:46 PM
  #379
BluestreamDE
Thanks Blue. Still some things i notice that needs fixing like the paint and other stuff but i appreciate the kind words.
Its running well, did some preventive maintenance checks and street tuning on the car today cleaned up some lean conditions during half load/throttle n washed it.
Old Oct 6, 2018 | 02:24 AM
  #380
BluestreamDE
Replaced my 3 piece janky charge pipe with the R-Rydes Vortech piping last night. A much cleaner look in the bay for sure.
