G35 Build 2nd Try
Old Jun 27, 2019 | 06:33 PM
  #341
rustyschopshop's Avatar
rustyschopshop
Glad to see you are back on track... Crossing my fingers that you might get lucky and just need to reloom
Old Jun 30, 2019 | 04:57 AM
  #342
Conway_160's Avatar
Conway_160
Welp did a compression test and leak down test on the car yesterday. All the cylinders were between 160-165psi with a 25-28% leak down. So put on my coolant burping funnel to try and burp the coolant some more to see if that's what is causing the problems. Ran the car for idk 3-4 heat soaks to get everything flowing, i even held it at different RPM's to help.
Took it for a spin to see if i fixed anything and nope still filling up my overflow tank with the Koyo high pressure cap ~138kpa.
I would think it would be dam near impossible to lift a head at 540hp on a blower car pushing 17psi with L19's.
Bealljk suggest pulling the thermostat to make sure it's functioning and to drill some small holes in it so there is always flow.
Old Jun 30, 2019 | 09:15 AM
  #343
bealljk's Avatar
bealljk
I did this on my twin turbo setup with two 3/16" holes and two 1/4" holes in the thermostat plate and it was too much - my ECT would fluxuate quite a bit between 160* and 210*. Another consideration is that I was not running any of the OEM auxillary hoses (like the heater core hoses, bypass, etc) so I wanted some flow no matter what.
On my current setup I put two 3/16". Maybe you only put a single 1/8" - 3/16"?? If you want an extra thermostat plate let me know … I got like 4 of them!
My thought process is that these engines are temperamental when it comes to bleeding and air pockets sit inside the thermostat housing and don't/wont let the thermostat gate open up.
Conway - are you getting white smoke out the exhaust?
Old Jul 22, 2019 | 07:28 AM
  #344
eZg's Avatar
eZg
Any update? Got my fingers crossed that it's a minor issue.....
Old Jul 23, 2019 | 02:40 AM
  #345
Conway_160's Avatar
Conway_160
Sorry for the delay not much of an update been kinda a busy and upset with the car all at the same time.
Car is still pushing coolant into the expansion tank so i think i have more air in the system. I think there is still more air in the system that i have to get out.
I also have to redo some damn RTV, before i get the car back on the road. My timing chain tensioner access panel is leaking and it appears say driver side cam access panel is also pissing oil all over my belts.
Unfortunately i don't have the time to mess with it as I'm going on leave next week.
Old Aug 18, 2019 | 04:35 PM
  #346
Conway_160's Avatar
Conway_160
Da *** causes this?????
Old Aug 19, 2019 | 11:35 AM
  #347
eZg's Avatar
eZg
mine did that when T-stat was not opening........
Old Aug 19, 2019 | 11:40 AM
  #348
Cedric Guerin's Avatar
Cedric Guerin
Ya looks like a blockage.
Old Aug 20, 2019 | 10:16 AM
  #349
Conway_160's Avatar
Conway_160
Brand new T-stat that i tested before installing, i also drilled a small hole in it to help bleed it.
Old Aug 20, 2019 | 10:17 AM
  #350
Conway_160's Avatar
Conway_160
Any known ways of how to track it down??
Old Aug 20, 2019 | 10:36 AM
  #351
bealljk's Avatar
bealljk
I feel your pain CW. Might you be able to remove the thermostate element all together and repeat the process to see if the thermostat element is the issue?
Old Aug 20, 2019 | 10:43 AM
  #352
iideadeyeii's Avatar
iideadeyeii
Garden hose through heater core both ways. Had a blockage in a wrangler and this fixed it. /Shrug your results might be different. Did you use a lisle funnel?
Old Aug 20, 2019 | 12:20 PM
  #353
onevq35de's Avatar
onevq35de
Old Aug 21, 2019 | 04:54 AM
  #354
Conway_160's Avatar
Conway_160
Yes i did
Originally Posted by onevq35de
This is a common issue with these engines. The exact same thing happened to me. The t-stat isn't opening because too much air is in the system and it's at the t-stat so it doesn't get hot enough to open. Close to the bottom of this page https://www.infinitiscene.com/thread....230572/page-2
So, basically now i just need to drive it softly or let it idle until i hear the fans kick on. a few times so it gets up to temp and opens the t-stat and bleed it's self out?
Also i get hot air out of my vents is that not a sign i'm getting flow?
Old Aug 21, 2019 | 05:53 AM
  #355
onevq35de's Avatar
onevq35de
Old Aug 21, 2019 | 02:12 PM
  #356
aarrgghh's Avatar
aarrgghh
The heater core doesn't go through the thermostat. It's on one of the bypass loops like the hose that goes around the front.
Old Aug 22, 2019 | 02:16 AM
  #357
2bad240's Avatar
2bad240
did you jack up the front end while bleeding it?
Old Aug 22, 2019 | 02:54 AM
  #358
Conway_160's Avatar
Conway_160
Started this process last night. I have a auto zone code reader that also has a live date stream so i was able to see my coolant temp.
I drove the car around the neighborhood at like 15-20mph while saying at less then 2000rpm's and 10% throttle. I watched my temp climb up to 210 then it started to fall back down to about 195-205 when i was pulling back into the yard. So i think it finally opened after driving around for 10-15 mins. I noticed it did push a little water into my reservoir but nothing to crazy. It very hard to grab the lower radiator hose to see how hot it is due to the blower setting right there, but it was firm and felt hot so that helps me believe that it did open.
Once it cooled down i opend the radiator cap and it pulled in some air so it didn't pull all the coolant back in from the reservoir so i'll have to top of the radiator tonight. Then repeat.
Yes, not at a crazy cazy angle but i ensured the radiator cap is the highest point in the car.
Side not: Aluminum radiators suck, they get way to hot and F up your arms when trying to reach for things.....
Old Aug 25, 2019 | 11:05 AM
  #359
Conway_160's Avatar
Conway_160
Update: after messing with it for a week it's still same results.
So this morning i removed the thermostat to see if that was my problem. I filled the car with only water since i'll be draining it once i get either good or bad results.
I installed my spill free funnel and filled the car to get rid of the air in the system. Once the car got up to 180 and i no longer noticed air coming out i shut it off to let it cool down.
Once everything cooled down i went for a drive staying put of boost and below 3K rpms. Drove for ~3 miles and temp stayed around ~185. Pulled over to check reservoir and it was where i filled it to.
Next step add boost.... that's where it went south.
Drove about 1/2 mile and temps climbed to 210-215 so nothing out of the ordinary. Checked my reservoir again and FML its filled and air bubbles are a flowing.
Drove the car home and temps started coming back down 205 when i parked.
Next step is to put my high pressure coolant cap on and go for another drive with no boost then low boost to see if it happens again.
I'm out of thoughts.
Old Aug 25, 2019 | 01:12 PM
  #360
jdm-v35's Avatar
jdm-v35
If you only used water that could possibly be an issue when hitting higher temps especially when reaching boiling point. Part of the reason for coolant is to raise the boiling point.
The only other thing I can think of if its specifically when boosting is that your headgasket is leaking compression under boost.(BTW I have an HKS HG for sale if you need one! lol)
