Engine Light from Test pipes
Old Apr 28, 2006 | 05:20 PM
Cannysage's Avatar
Cannysage
Question Engine Light from Test pipes
I've done the non fouler technique and the light did not go away. Do I need to drive around for awhile? any ideas?
Old Apr 29, 2006 | 06:08 AM
Did you try clearing the SES light by disconnecting the battery or the multi-step method?
Old Apr 29, 2006 | 10:00 AM
Cannysage's Avatar
Cannysage
nah.. but I guess I can try it tonight, before I go to sleep.
Old Apr 29, 2006 | 10:51 AM
Mr_pharmD's Avatar
Mr_pharmD
u should of went to autozone to check out the code first to determine if u really needed the non fouler. It's free to use and takes less than 1 minute to find out the problem.
Old May 1, 2006 | 10:44 AM
Demon Z's Avatar
Demon Z
What about o2 simulators?
Old May 1, 2006 | 11:08 AM
99atlantic's Avatar
99atlantic
do that; codes don't usually disappear as soon as the problem is fixed...usually takes a while (or until u rest the memory). if you reset it and it comes back, then the non-foulers didn't work.
Old May 1, 2006 | 12:37 PM
Zexy's Avatar
Zexy
Reset your ECU and they should clear.
Old May 1, 2006 | 05:04 PM
Blue_Streek's Avatar
Blue_Streek
what year is your Z. remember 04+ will throw a code. if you got an 03 you are good. ive driven about 500miles and no codes i got an 03 enthusiast.
tommy
Old May 1, 2006 | 07:15 PM
rxkevin's Avatar
rxkevin
Same thing happend to me, just disconnected the battery and it was gone.
Old May 1, 2006 | 08:17 PM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
The light will not go out by itself - you have to clear the CEL with the pedal or the battery disconnect method first. After 200 miles - you'll know if it worked or not.
Rick
Old May 1, 2006 | 09:46 PM
Zincognito's Avatar
Zincognito
By the way, what do you think of the sound from everyday driving to WOT?? Im assuming you have an exhaust, how LOUD is it??
G
Old May 2, 2006 | 12:52 PM
rxkevin's Avatar
rxkevin
Well I have Nismo headers, Strup test pipes and Nismo exhaust, and it was a bit loud at first but after 400-500 miles it seems to either have gotten a bit quieter, or my hearing is not what it use to be and I am use to the sound.
Old May 2, 2006 | 05:43 PM
99atlantic's Avatar
99atlantic
you're just used to the sound
when I got my headers+hfc I was like
No wi'm like 'that's it?'
But people are still like when I drive by, so it's just as loud, my hearing just got used to it ^_^
Old May 2, 2006 | 07:58 PM
Zincognito's Avatar
Zincognito
Anyone??
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
samansharif
Sep 25, 2015 12:31 PM
