Is a Y-Pipe recommended ...
Old Apr 10, 2007 | 05:26 PM
r3zon8's Avatar
r3zon8
Default Is a Y-Pipe recommended ...
is a Y-Pipe recommended for a 2006 350z while leaving the rest of the exhaust system stock??
id like to add a little deeper sound to my car but nothing too loud? im not going for performance, just a 'nicer' sound. Ofcourse i dont want to make the performance worse!
i was looking into the JIC Y-Pipe, from my reading most people like that one, is there another Y-Pipe that is better or that more of you have liked better?
Old Apr 10, 2007 | 06:11 PM
first350's Avatar
first350
I like my AAM Y-pipe...as good as any others...great design, welds, and fitment:
AAM's Y-pipe
I'm not sure the difference it'll make for sound, but it might be exactly what you're looking for; the larger diameter piping should make the tone slightly deeper...as well as gain some performance!
-Peter
Old Apr 10, 2007 | 07:25 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I've seen that y-pipes make it a little louder and a little raspier. They also make power too.
The stocker is indeed restrictive.
Old Apr 11, 2007 | 05:08 AM
r3zon8's Avatar
r3zon8
did any of you install it yourself?
most of the reading ive done about them, say you can install in 15 minutes since its a 'bolt-on' part, no modification needed.
is there maybe a how-to guide on the forums? ill go search for it, but if any of you have experience in it give me a few pointers.
Old Apr 11, 2007 | 06:03 AM
OCZTrack's Avatar
OCZTrack
Um... it's 6 bolts.
How-To Guide:
Step 1. Unbolt the 6 bolts that connect the stock Y-Pipe.
Step 2. Replace stock Y-Pipe with new Y-Pipe.
Step 3. Bolt in 6 new bolts.
Step 4. Drink beer. (Bud-Light Bottles work best)
Step 5. Call it a day.
Old Apr 11, 2007 | 08:02 AM
Hydrazine's Avatar
Hydrazine
^ Like OCZtrack said.
Its super easy. Its probably the easiest mod you can do.
Old Apr 11, 2007 | 10:23 AM
03zsmith25's Avatar
03zsmith25
get high flow cats..id say you will get better results from them, but pay more as well
Old Apr 11, 2007 | 02:45 PM
jonnylaw's Avatar
jonnylaw
What about bottlenecking issues when the larger diameter y pipe dumps the air into the smaller diameter b pipe (usally from 3 inches to 2.5)? Would this not cause a turbulent air flow w/out a cone filter modification to the mid pipe? Couldn't this negate any gains attained from the install?
Old Apr 11, 2007 | 07:49 PM
first350's Avatar
first350
check out the post I wrote w/ my install, it's got a few simple tips to make things easier...but it's a very very easy install-you'll have to push a little on the Y-pipe to get the flex pipes to move enough to get it out and put the new one in.
https://my350z.com/forum/intake-exhaust/238812-aam-3-single-ti-installed-pics-vid.html
Old Apr 11, 2007 | 07:52 PM
first350's Avatar
first350
yes, this would not be ideal...but IMO the gains realized from a new Y-pipe would be more than the losses from a larger to smaller diameter transistion.
Old Apr 11, 2007 | 09:38 PM
jonnylaw's Avatar
jonnylaw
Wouldn't the sound be affected as well--raspiness?
Old Apr 11, 2007 | 11:14 PM
Armitage's Avatar
Armitage
No. Rasp comes from the lack of resonators. Run test pipes or a poorly muffled exhaust and you will get rasp. A y-pipe should not lead to raspiness.
Old Apr 12, 2007 | 05:59 AM
r3zon8's Avatar
r3zon8
from most of the units ive seen its 2.5" dumping into the 3.5" not the other way around. am i right?
heres a ****ty diagram.
/ (3.5)exhaust
engine?---(2.5)ypipe
\ (3.5)exhaust
so back on the subject.
Thanks for the link to the guide+vids, its exactly what i was looking for. for those of you who did insall this part, was it worth it? do you like the sound of the car more now?
Old Apr 12, 2007 | 06:20 AM
first350's Avatar
first350
I wouldn't expect to get rasp from this set-up...
I think the OP is talking about a OE exhaust system w/ aftermarket Y-pipe...the OE cats are around a 2.5", so that connection to the y-pipe should be fine, but all non-OE Y-pipes I've seen have a 3" outlet...which will be larger than the OE exhaust.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
apex locator
Jul 23, 2021 02:27 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
