Advanced Resonance Tuning (ART pipes)
Old Jun 21, 2012 | 10:17 AM
  #781
User 42426's Avatar
User 42426
^^I know plenty on art pipes, been following and drooling over them ever since they came out. I guess I do need a tune or just be satisfied
Old Jun 21, 2012 | 11:25 AM
  #782
F2CMaDMaXX's Avatar
F2CMaDMaXX
You might find more driving, and i mean normal driving, will let you feel the results a little more.
Did you reset your ECU?
The hissing, assuming you've checked for leaks, will die down as they carbon up.
The problem with overall power increases, is that they're harder to feel as the gains are all over the board. With something that only gains in the upper RPM, it's really easy to feel the change.
Get the tune, no one has been disappointed with the way the car feels afterwards, ignore the dyno queen number chasers, that seems to be what people are disappointed with for some reason.
I felt gains with my ART pipes, but the pull all round was a nice improvement. When you've heard what normal TP's sound like or HFC's, you'll appreciate the ART pipes more.
Old Jun 21, 2012 | 11:27 AM
  #783
User 42426's Avatar
User 42426
^^I can't say enough good things about the sound, I used to run tp and hated the rasp. Thanks for the advice, i might have to recheck my bolts for leaks. Maybe a tune in the future
Old Jun 21, 2012 | 11:34 AM
  #784
realist alive's Avatar
realist alive
you should know NA mods do not add a lot of hp to begin with. You just spent a lot of money ($500) on a part that could have been bought for $150 (regular test pipes) and you would have had plenty of money for a tune.
Old Jun 21, 2012 | 12:12 PM
  #785
User 42426's Avatar
User 42426
^^Yes I know na mods don't do much, I have been on these forums for quite some time. How much are tunes then? Based on your figures, they are around 300?
Old Jun 21, 2012 | 04:45 PM
  #786
ITOzann's Avatar
ITOzann
Old Jun 21, 2012 | 05:10 PM
  #787
Ruined Z's Avatar
Ruined Z
Tunes usually go for $500+
Old Jun 21, 2012 | 05:45 PM
  #788
2004Black350z's Avatar
2004Black350z
Exhaust Whore
600+. But worth it. My car only picked up a peak of like 10-15whp but my car felt like a different monster with CIN and uprev. I don't regret it one bit
Old Jun 21, 2012 | 05:58 PM
  #789
F2CMaDMaXX's Avatar
F2CMaDMaXX
Don't forget, it's the increase below the peak power, the lower down improvements.
Old Jun 21, 2012 | 07:44 PM
  #790
realist alive
not the best route but yes $300
http://www.z1motorsports.com/350_g35...oducts_id=3294
Old Jun 21, 2012 | 08:18 PM
  #791
ashram's Avatar
ashram
I felt the same way when i got my art pipes installed, After a tune my car put down 275 whp and 286 tq with just the art pipes , now im all smiles well except fore that pesky ses light lol, get a tune bro.
Old Jun 21, 2012 | 08:33 PM
  #792
Deteria's Avatar
Deteria
Lol something is up with your Z ashram... HP should be higher than torque!
Old Jun 21, 2012 | 08:59 PM
  #793
ronn1's Avatar
ronn1
Depends on torque curve. My Chevy Cobalt turbo had 350 peak torque down low and only 290 HP.
Agree that for a Z, it's not likely given the typical curve. Maybe he has a *peaky* curve?
Old Jun 22, 2012 | 10:55 AM
  #794
AgentZ33's Avatar
AgentZ33
Tony:
Will these help instead of just rtv for HR 350z?
Z1 Metal HR/VHR Manifold 3 Bolt Gasket
http://www.z1motorsports.com/350_g35...oducts_id=6448
Old Jun 22, 2012 | 11:44 AM
  #795
Deteria's Avatar
Deteria
^^Yea I know the stock filter is already great, and one of the best options for intakes, along with a k and n drop in filter. But I was mainly asking if there was that big of a difference between the aftermarket intake you tested and the stock intake since you did decide to do another test on the stock intake, and got better results. I have both my stocks hr intakes and the jwt hr intakes, so I can swap it out if its that big of a difference.
It depends where you live tbh. The engine bay gets pretty hot as is, and during the summer, even hotter in some cases. Short ram intakes basically just suck that hot air in the engine bay, making it even less efficient than if you were just running stock intakes. Point is, cold air is more beneficial at a performance stand point, and CAI's are more recommended. If you are comparing short ram vs stock, you may find the stock to be a better performer during the summer months (depending on where you live). If you are debating on it at a price standpoint, I would say probably isn't worth the $ as the stock HR intakes are already pretty efficient as is. You'd be paying more for the sound than actual benefits (short ram). And again, you would have to get tuned each time you swap, due to air flow differences, for proper results. Personally, I just stuck with the stock HR intakes. I saw no real point in spending $250-500 for dual intakes, as optimized as the stock HR filters are, plus it is easier to just swap the oem filters or clean the K&N drop-ins.
Old Jun 22, 2012 | 01:03 PM
  #796
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I havn't tested the HR intakes. So there is no way I can say if they are good or not. Sorry I couldn't be of more help here.
Tony
Old Jun 22, 2012 | 01:06 PM
  #797
Hydrazine's Avatar
Hydrazine
Originally Posted by AgentZ33
Tony:
Good find. I'm sure they will.
Old Jun 22, 2012 | 07:17 PM
  #798
PeterSellers's Avatar
PeterSellers
Tony:
Thank you for posting this! I've been looking for something like this for awhile. The RTV is the only thing I don't like about the ART pipes, and now it looks like it's no longer necessary.
Old Jun 22, 2012 | 08:00 PM
  #799
F2CMaDMaXX's Avatar
F2CMaDMaXX
Based off Z1's description, seems like it's not uncommon on a lot of aftermarket TP's/HFC's.
Good find.
Old Jun 23, 2012 | 12:21 AM
  #800
ashram's Avatar
ashram
It may be wrong but it feels so right lol, i dont Know my dyno sheet is in the tuning thread i think my car being an automatic may explain the weird torque curve. I thought the art pipes where supposed to give greater torque gains then h.p ?
