Advanced Resonance Tuning (ART pipes)
Old Jun 24, 2012 | 06:56 PM
  #801
PeterSellers's Avatar
PeterSellers
Originally Posted by F2CMaDMaXX
Based off Z1's description, seems like it's not uncommon on a lot of aftermarket TP's/HFC's.
Good find.
I had the carbon gaskets that came with the ART pipes fail almost immediately. I replaced them with RTV and was fine for about 5K miles but just recently got another CEL for the bank 1 O2 sensors (same as before, indicative of another leak at those joints).
I think the exhaust manifolds are made of different metal than the ART pipes (or any other test pipes for that matter) which causes an issue when they heat up and expand at a different rate from the test pipes.
Old Jun 24, 2012 | 07:01 PM
  #802
PeterSellers
Originally Posted by ronn1
Depends on torque curve. My Chevy Cobalt turbo had 350 peak torque down low and only 290 HP.
Agree that for a Z, it's not likely given the typical curve. Maybe he has a *peaky* curve?
It's quite common for turbo charged cars to have higher peak torque than horsepower. It's very uncommon for a high revving N/A car to have that, however. Either something is wrong with the top-end of his car or the dyno was giving off an incorrect reading.
Old Jun 24, 2012 | 07:16 PM
  #803
F2CMaDMaXX's Avatar
F2CMaDMaXX
I understand it to be partially to do with the angle the gasses pass the joint, the extreme temp and pressure causes the issue with flat flange connections. The problem only exists on later models where the connection is different on the manifold.
Old Jun 25, 2012 | 10:31 PM
  #804
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by ashram
It may be wrong but it feels so right lol, i dont Know my dyno sheet is in the tuning thread i think my car being an automatic may explain the weird torque curve. I thought the art pipes where supposed to give greater torque gains then h.p ?
Yes, they give higher absolute delta gains in TQ but they also make more HP than test pipes too.
Old Jun 26, 2012 | 05:53 AM
  #805
Hydrazine's Avatar
Hydrazine
If you need a replacement set of gasket just let me know. We have a new heavy duty gasket material that can take the heat.
We also have a new inlet design for the HR and VHR ART pipes that uses the stock metal crush ring. It will never leak or blow out.
Old Jun 27, 2012 | 05:13 AM
  #806
AgentZ33's Avatar
AgentZ33
tony, when did the new inlet design take effect? if purchasing from vendor, will they have it? or will need to purchase through you to get the latest redesign?
Old Jun 27, 2012 | 11:38 AM
  #807
PeterSellers
I sent you a PM, I am definitely interested in the new gaskets.
Old Jun 27, 2012 | 08:20 PM
  #808
Hydrazine's Avatar
Hydrazine
They have been shipping for the last couple of weeks.
  #809
Hydrazine's Avatar
Hydrazine
Replied.
Old Jul 2, 2012 | 08:37 AM
  #810
sic6spd350z's Avatar
sic6spd350z
PM sent about exhaust and art pipes
Old Jul 11, 2012 | 09:16 AM
  #811
NFGZ's Avatar
NFGZ
I purchased mine from a vendor around the 1st of july, he was out in California I wonder if I have them? Do you have pics of these to compare?
Also, If i wanted to put a wideband on my car, would I have to have a bung drilled into my ART pipes for my 07? I really dont want to have that done lol. Or would on the manifold or Y pipe suffice?
Old Jul 11, 2012 | 10:36 AM
  #812
Duckeee's Avatar
Duckeee
i ordered mine last week and they came yesterday. also a california vendor.
Old Jul 11, 2012 | 11:36 AM
  #813
F2CMaDMaXX's Avatar
F2CMaDMaXX
The V3 pipes are for the HR motors and have a 'lip' on the end of the pipe that connects to the manifold.
If you post pics it can be confirmed.
Old Jul 11, 2012 | 05:21 PM
  #814
Hydrazine's Avatar
Hydrazine
Here you go.
This new gasket sealing design will never leak.
Old Jul 11, 2012 | 05:35 PM
  #815
Hydrazine's Avatar
Hydrazine
OFF TOPIC BUT VERY IMPORTANT
Please note if you have recently sent an email to Motordyne it may not have gone through. Our email volume is very high and for some reason it has corrupted Outlook.
I thought I had it fixed last week but apparently its not completely fixed. Not all emails are making it through. We are working to fix it now!
If you have any questions please feel free to call us (661) 298-7555.
Thank you!
Tony
Old Jul 12, 2012 | 12:08 PM
  #816
NFGZ's Avatar
NFGZ
Hey Tony, do you have any suggestions on the wideband question? Thanks for the photos!!
[QUOTE=Hydrazine;9806959]Here you go.
[QUOTE]
Sweet! This is what mine looked like. Purchased from a cali vendor, I believe it was an infinity car dealership. Thanks man!
Old Jul 12, 2012 | 04:06 PM
  #817
Hydrazine's Avatar
Hydrazine
I suggest putting the wideband after the merge collector of the Y pipe.
Old Jul 15, 2012 | 01:03 PM
  #818
xsackofricex's Avatar
xsackofricex
Hey Tony, does the DE have the new inlet design or is it only for the HRs?
Old Jul 15, 2012 | 02:36 PM
  #819
F2CMaDMaXX's Avatar
F2CMaDMaXX
Only the HR's need the flange, there is no problems at all on the DE's.
Old Jul 17, 2012 | 07:40 AM
  #820
Duckeee's Avatar
Duckeee
I installed mine a few days ago on my HR with the new V3's and last night the car threw code P2A03. Should I suspect a leak somewhere? everything was fine prior to install, so I do not suspect the o2 sensors to be at fault.
edit: I used my cobb accessport to scan the code and it said something about control unit dtc code P2A03.
