NWP 75mm throttle body
Old Jul 1, 2013 | 06:07 AM
  #41
MrEous's Avatar
MrEous
Originally Posted by waldo36
Where did you get a 4" MAF housing and are you running a 4" intake tube? I'm running the GTM 3" MAF with the 3" COBB hose.
A friend of mine in MD had them made up for a bunch of Maxima guys (I have a Max)...did good work, I love it.
Old Jul 2, 2013 | 01:47 AM
  #42
2bad240's Avatar
2bad240
Here's my custom 4" intake and 75mm tb. No adaptor plate. Just redrilled the holes
Old Jul 2, 2013 | 03:02 AM
  #43
MrEous's Avatar
MrEous
^ Very nice...
Old Jul 2, 2013 | 03:23 AM
  #44
2004Black350z's Avatar
2004Black350z
Exhaust Whore
2bad you do any dyno test? Any reason y u didnt run it down further to prevent heat soak? Is it 4" straight or like 4 to 3.5
Old Jul 2, 2013 | 04:42 AM
  #45
Fixxxercask's Avatar
Fixxxercask
Nice! How much MAF tuning did you have to do to get that to work and did you use Uprev?
Old Jul 2, 2013 | 05:54 AM
  #46
bmyles's Avatar
bmyles
I'm interested in doing this for sure. I might pick up a used upper intake manifold to have custom drilled. Also, I'm guessing we have to email Surratt about the PnP harness? I was on his site and didn't see it, but maybe I just suck at looking. I might want to see some dynos before taking the plunge, though.
Old Jul 2, 2013 | 06:58 AM
  #47
waldo36's Avatar
waldo36
@2bad: but you can't put you're strut bar on because the tube sits too high, correct? And is the TB you're using the NWP TB?
And to get off track real quick, I suggest ditching the V+ (http://www.zcarmotoring.com/showthre...V-PLENUM-USERS!!)
Old Jul 2, 2013 | 07:51 AM
  #48
2bad240's Avatar
2bad240
At work guys il reply with info and dyno numbers once I get off base and get signal.
Old Jul 2, 2013 | 10:09 AM
  #49
denchan350gt's Avatar
denchan350gt
There is no difference between his TB and NWP he just is not using their adapter plate
Old Jul 2, 2013 | 10:35 AM
  #50
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
That thread hasn't been updated in almost a month; what became of it?
Old Jul 2, 2013 | 03:02 PM
  #51
waldo36's Avatar
waldo36
I haven't emailed kinetix yet. But the first time I emailed them, they said it the plenum deteriation was due to the DE design flaw. Because it allowed too much oil into the intake, it was breaking down the plastic. So it's not kinetix's fault, but nissan engine design flaw. So I don't think much will happen if I show them this.
Old Jul 2, 2013 | 03:42 PM
  #52
bmyles's Avatar
bmyles
Well then clearly they didn't do enough testing. What a cop-out.
If 2bad240's results are clear cut, then we could be onto something. I personally wouldn't want a 4" intake...I'm thinkin 3.5", but regardless, someone could start making them.
Old Jul 2, 2013 | 04:54 PM
  #53
2bad240's Avatar
2bad240
yes i dyno tested it it made 252hp on a dynojet before the intake and TB i had it tuned after on a superflow and it made 252 also but the owner said the superflow was known to test 20% lower than the dynojet i was on before
there is literally no room to run it farther i have the gruppe-m carbon scoop in the bumper to supply fresher air to the intake and a jwt heat shield to try to keep the heat off and it is straight 4"
i dont run a strut bar as my car is pretty much just for drag. i got my TB off ebay awhile back and instead of using a adapter i redrilled the holes in the TB and i bought my pnp harness from voltage drop back before he was mass producing them but he is advertising them for $80 shipped on facebook now.
as a whole i dont feel like the setup is worth the money as far as power i cant tell a difference and i have switched the TB's at the track and picked up a tenth by switching back to the stock one...
Old Jul 2, 2013 | 04:58 PM
  #54
2bad240's Avatar
2bad240
and as far as the kinetix i never had any issues besides the nitrous backfires i had the busted the first 2 kinetix. i actually have the post shaved off my kinetix now for clearance room on something i have modded inside the plenum.
Old Jul 2, 2013 | 05:20 PM
  #55
bmyles's Avatar
bmyles
That's not what I wanted to hear, haha. If you didn't run any faster at the track, that more or less seals the deal. Would've helped if you had dyno'd on the same dyno in similar conditions, though.
Old Jul 2, 2013 | 05:25 PM
  #56
2bad240's Avatar
2bad240
Yea I wish I could have ran both on the same dyno. But I'm very picky about where I take my car and there was some personnel changes at the first shop so I went elsewhere. I will dyno them very soon for you guys on the same dyno. Same day and post results.
Old Jul 2, 2013 | 05:38 PM
  #57
2004Black350z
Exhaust Whore
Dyno Is def needed. I mean 15hp is good. However if that's bs we need to know
Old Jul 2, 2013 | 05:47 PM
  #58
denchan350gt
I plan on track testing it tomorrow or Friday depending on the weather. 3 runs with and 3 runs without. Plan on testing it on a cammed maxima and a bolt on 350z time permitting.
Maxima has 3.5 intake 350z has stock z tube. I'm looking for a higher consistent trap speed not times.
Old Jul 2, 2013 | 05:50 PM
  #59
2004Black350z
Exhaust Whore
F that maxima lol. So stock Z tube Into a bigger tb wouldnt be choke point
Old Jul 2, 2013 | 05:53 PM
  #60
terrasmak's Avatar
I have a feeling results are minimal for most, without tuning , quality headers, cams etc etc , you won't see much from this. This also includes the MAF housing.
