Custom 3" Intakes on VQ35HR project....
Old Apr 2, 2014 | 01:54 PM
  #181
KingBaby's Avatar
KingBaby
Hardest Setting
Originally Posted by The_Assassin
Metal heat shield ? :0 lol don't make a rice box
Talked with CIN and they supposedly have a HR injen long tube Z in today? Told him that me and a few others are interested! Waiting to hear back!
Told home dub it the "BM intake pipe"
Old Apr 2, 2014 | 01:58 PM
  #182
npr350z's Avatar
npr350z
Bm 6 inch for the win!
Old Apr 2, 2014 | 02:28 PM
  #183
dilat3d's Avatar
dilat3d
Aren't most heat shields metal?
You could get some aluminum and maybe put a wrap or coating on it to reflect heat.
Old Apr 2, 2014 | 02:48 PM
  #184
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Greyz don't take this in a bad way but if I was CIN and it took me 8+hours of tuning for the new intakes the last dam thing I would do is "share" a base map or even a part of it. Also commenting again on my opinion but doubt they will do a group by since it won't be mass produced it would be one guy fabbing cutting and welding all himself. It's not like an exhaust where a tribe full of kids in China made 1500 or more of them
Old Apr 2, 2014 | 03:35 PM
  #185
npr350z's Avatar
npr350z
bm be agood guy and post your maf scaling tables!
Old Apr 2, 2014 | 04:44 PM
  #186
Bmurray350z's Avatar
Bmurray350z
i'll do it in exhange for some tomei 264s, ppe longtubes, gt-r manifold conversion kit, and some 09+ maxima throttle bodies
Old Apr 2, 2014 | 04:49 PM
  #187
npr350z's Avatar
npr350z
good thing i dont have an hr
Old Apr 2, 2014 | 05:15 PM
  #188
The_Assassin's Avatar
The_Assassin
09 maxima throttle bodies?....sounds like you got another idea murray we should start donating to you lol
Old Apr 2, 2014 | 05:29 PM
  #189
npr350z's Avatar
npr350z
yeah BM! where you got that gtr manifold conversion stashed? coming up with some great ideas
id maybe consider the 2k6 m45 tb, it tapers down from 80mm to 75mm. maybe just bore it out and just go 3' all the way through.
Old Apr 2, 2014 | 06:18 PM
  #190
SurraTT's Avatar
SurraTT
lol another one of mine actually
Old Apr 2, 2014 | 07:01 PM
  #191
npr350z's Avatar
npr350z
You see what me and Waldo36...well Waldo 36 are doing with a 2k6 m45 tb?
Old Apr 2, 2014 | 07:10 PM
  #192
XChacalX's Avatar
XChacalX
good luck on the Maxima09 TBs ... I had mine for well over a year ,, still not installed yet ;/ Blowing an engine suck then military life isn't always a good timing...
I gained quite a bit of power few years ago with an oversized CAI & TB, I always knew there was quite a bit more left on the intake side
Old Apr 3, 2014 | 09:01 AM
  #193
Nismo350z#0310's Avatar
Nismo350z#0310
this sounds absolutely lovely
I swear ta Gawd I want to do some sort of GTR manifold conversion
Old Apr 3, 2014 | 02:56 PM
  #194
0jiggy0's Avatar
0jiggy0
According to a 370 thread kingbaby posted. Mounting a gtr mannifold isnt just a simplr bolt on affair.
Im going bigger with tomei 272`s. Ppe`s are already in. 150 for the intakes sounds dirt cheap. I paid more then that for almost new nismo intakes a long time ago!
Are the maxima tb`s straight bolt on?
Old Apr 3, 2014 | 04:04 PM
  #195
npr350z's Avatar
npr350z
To jiggy.
The tbs harness is the same, but the bolt holes no. The hr tb seems to have quite a bit of distance between the bolt holes though. If they line up with the de tb, you could use the nwp adapter bracket; then run either the 2k9 maxima tb (75mm tapers down) or the 2k6 m45 tb (80mm tapers down). Then get either of them bored out, my vote is for the m45 tb, that way it's 3" all the way through.
If any of you are willing to post pics of measurement on one of your hr tb, I would gladly measure my stock de tb, and see if the nwp tb will work for the hr.
Old Apr 3, 2014 | 04:08 PM
  #196
Bmurray350z
From speaking to a guy on fb last night (redline06), larger tbs without changing the manifold would be pointless because the hr mani can not be bored at all.
Old Apr 3, 2014 | 04:20 PM
  #197
npr350z's Avatar
npr350z
They also said that over sized intakes wouldn't show gains for along while around here.
I'd call motordyne to see if their m370 Im would work for you guys. Or get real sassy and make the gtr manifold fit. I read the thread about it awhile ago, but it can be done. What was it fuel rails, bolt holes, and some other stuff. That doesn't sound impossible. Maybe expensive, but a used mani goes for around 900$ or you can buy an after market one. I mean compared to an exhaust if it came in under 2g and made the same power itd be worth it right? And great if you ever went boosted.
Old Apr 3, 2014 | 04:21 PM
  #198
npr350z's Avatar
npr350z
I'm not saying anything bad about redline06, I hope it didn't come off that way!
I will say other car platforms have put larger tbs on stock Im and have seen gains, that's all.
Old Apr 3, 2014 | 05:43 PM
  #199
waldo36's Avatar
waldo36
NPR,
The 2k9 maxima and 2k6 m45 are one in the same, per NWP. They both start at 80mm and taper to 75mm. Just the m45 doesn't have the coolant lines like the maxima.
Old Apr 3, 2014 | 06:12 PM
  #200
npr350z's Avatar
npr350z
If I can find the links or pics, Ill show you that the 2k9 tb starts at 75mm and tapers down to 72mm.
