Interior Scratches - Repair Discussion
Old Jun 8, 2009 | 05:38 AM
  #241
JDMZ33's Avatar
JDMZ33
Vendor - Former Vendor
Our Solution.
Old Jun 15, 2009 | 05:09 PM
  #242
Diesel350's Avatar
Diesel350
Does anyone have instructions on how to pop it off or do you have to take the whole door apart?
Old Jun 15, 2009 | 05:23 PM
  #243
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Originally Posted by JDMZ33
Our Solution.
^ I'm going to have to pick those up soon.
Old Jun 16, 2009 | 01:52 PM
  #244
koz's Avatar
koz
Default solve
Had the same problem with mulitple scatches on the switch panel.
Just paint them like I did.
Remove the switch assembly, lite sanding, paint (whatever you like), clear coat and re-install.
$15, save you whole lot of money.
you can do the same with eveything else that can be removable.
Old Jun 16, 2009 | 04:16 PM
  #245
lbz's Avatar
lbz
+1 on home remedy. Duplicolor Flat Black is pretty close match.
Old Jun 16, 2009 | 07:43 PM
  #246
koz's Avatar
koz
Default paint it
$15 only
Attached Thumbnails Interior Scratches - Repair Discussion-in-1.jpg   Interior Scratches - Repair Discussion-in-2.jpg   Interior Scratches - Repair Discussion-in-3.jpg
Old Jun 17, 2009 | 08:46 AM
  #247
FishBrownie's Avatar
FishBrownie
^^I like the look of that silver on those. Anyone know how to get it to look like the brushed silver finish look like the rest of the interior? Don't like the carbon fiber.
Old Jun 17, 2009 | 02:50 PM
  #248
zerosktz's Avatar
zerosktz
Originally Posted by koz
$15 only
that looks freaking awesome. so you just sanded them down with 400-500 grit sandpaper + clear coar + silver? or did you do something else? someone mentioned a DIY for removing the armrests but i could only find one on the DIY section that had all the pictures taken down. is there another one?
any idea on how to remove the latch for the cubby hole in the center console?
just asking cause i actually went to the stealership today and i was told i was no longer under warranty. the cost of the parts there are $92 each armrest.
Old Jun 17, 2009 | 08:42 PM
  #249
lbz's Avatar
lbz
To take the driver's side piece out, just look down inside the depression, pop the little rubber cap off and take out the screw.
You can then use either a flat blade covered in elecrtrical tape to pry up the piece or just grip it firmly and pull up and back. It will pop off.
Disconnect the two wiring harness connectors, pop out the switch assemblies and you are ready to prep and paint.
Passenger side is the same but you have to remove the silver trim piece that covers the passenger side door grip. Very small flat blade, covered in tape again, to pry the edge out from the top and work your way down.
Remove the two screws that hold the handle to the door.
Then pry the piece that holds the switches loose and pull the handle straight out of the door. Disconnect the wiring connectors, remove the switch assemblies and there you go.
You mean the release button for the cubby door in the center console? You can take that out by using a small flat blade screwdriver and popping it out by prying under an edge. Watch carefully in case the spring under the button comes out.
After it's ready to go back in, just put the spring in and snap in the button.
Old Jun 17, 2009 | 09:04 PM
  #250
gr8scott_o's Avatar
gr8scott_o
Just a note, '06 - '08 has a totally different cubby. This method will break the button off. You will need to remove, then completely disassemble the cubby in order to remove the button.
Old Jun 18, 2009 | 07:48 AM
  #251
FishBrownie
+1. I had my button on my '06 replaced under warranty (along with driver armrest, steering wheel trim, and radio ****). They told me instead of replacing the button, they replaced my whole cubby, which was great b/c the guy that had the car before me had drilled a hole in the middle back of the cubby for wiring to something.
Old Jun 18, 2009 | 10:28 AM
  #252
koz's Avatar
koz
I believe you can buy brushed silver spray paint.
All I did was remove, sand, paint, & clear coat.
Look so much better than CF ($$$) and no sticky 3M tape.
Old Jun 19, 2009 | 09:25 AM
  #253
epidemic007's Avatar
epidemic007
im having this problem too.
Old Jun 19, 2009 | 01:06 PM
  #254
ChrisNelson's Avatar
ChrisNelson
Here's a picture of mine. After doing a double din install, we noticed that the rubber coating on both front center console pieces comes off very easily. You can accidentally rub it too hard with your finger nail and it comes off. You can kind of see the scratches in this picture, and there are more when you see it in person:
Old Jun 19, 2009 | 01:33 PM
  #255
koz's Avatar
koz
that's jacked, re-paint
Old Jun 19, 2009 | 03:01 PM
  #256
lbz's Avatar
lbz
Thanks for the correction on the 06 - 08 cubby. Nice to know. I should have spec'd 03-05 on my post.
Old Jun 22, 2009 | 04:35 PM
  #257
minispider's Avatar
minispider
i had a couple of panels replaced under warranty.
Old Jun 22, 2009 | 04:37 PM
  #258
Spork's Avatar
Spork
edit
Old Jun 23, 2009 | 12:38 PM
  #259
ChrisNelson
We are planning on getting the Carbon Fiber replacements for ours.
Old Jun 28, 2009 | 04:58 PM
  #260
pulser8's Avatar
pulser8
I have a 2006 as well. Painted my door panels today (silver). I still have to figure out what to do with the aluminum pieces on the steering wheel and the aluminum covering on the door handle. Also, I noticed that the center console piece that surrounds the radio is wearing.
