unwanted lights on my cluster
Old Feb 29, 2008 | 06:36 PM
misterlv's Avatar
misterlv
Default unwanted lights on my cluster
i dont know why my abs light keeps coming on like 3 seconds after i start my car. and sometimes when the brake light feels like it it will too even though the brake is down. can anyone tell me how to fix this problem?
Old Feb 29, 2008 | 06:56 PM
surfcity40's Avatar
surfcity40
add brake fluid. (I'm not goofing on you. The cluster lights when you need to add fluid).
Old Feb 29, 2008 | 07:18 PM
misterlv's Avatar
misterlv
are you sure? anti lock brake system is lighting up because of that?
Old Mar 1, 2008 | 06:56 AM
Tim@WestCovinaNissan's Avatar
It will start with the brake light normally then if the fluid gets low enough the abs light can come on also. Check fluid level and add accordingly.
Old Mar 2, 2008 | 10:13 AM
misterlv's Avatar
misterlv
i will check the brake fluid level and if needed i will add more. thanks for the advice all.
Old Mar 3, 2008 | 03:25 PM
misterlv's Avatar
misterlv
umm checked the brake fluid and its at max. abs and brake light still on. any advice?
Old Mar 3, 2008 | 03:36 PM
Flee0588's Avatar
Flee0588
could be the speed sensor. if your axles or sensors are loose it could be throwing the light. does your abs ever come on randomly?
Old Mar 5, 2008 | 05:15 AM
misterlv's Avatar
misterlv
the abs light is always on when i turn on the car.
Old Mar 13, 2008 | 11:35 PM
Bumble_Zee's Avatar
Bumble_Zee
FREEDOM FIGHTER
i'm having this problem now... have you fixed the problem?
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
