How-To Repair Stuck / Broken Window Motor ...
Old Nov 21, 2014 | 07:30 PM
  #561
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
My passenger side finally crapped out on me, and without warning, after being fine for over a decade so I'll have to do this sometime in the near future.
On a side note, my AutoZone motor on the driver's side's been without any problems since being installed 3-4 years ago.
Old Nov 30, 2014 | 08:30 PM
  #562
VO...'s Avatar
VO...
Administrator
Updates. Mine are still working fine. Although I believe my driver's side switch is starting to malfunction. Sometimes when I click it to auto raise or lower, it'll start then stop. I have to engage it a 2nd time for it to work..
Old Jan 19, 2015 | 03:22 PM
  #563
aireoh's Avatar
aireoh
finally got around to doing it, bought the lifetime warranty motor from AutoZone.
5.5/10 difficulty.
Old Feb 15, 2015 | 10:35 PM
  #564
sandiegosurfer's Avatar
sandiegosurfer
Update - as of 2/15/2015, the A1 Cardone motors at O'Reilly's have a LIFETIME warranty.
Old Apr 10, 2015 | 01:28 PM
  #565
Z33Garage's Avatar
Z33Garage
I rebuilt mine with new brushed and it worked for about a week. Now when it goes up and down it grinds and gets stuck (either all the way up or all the way down). I am wondering if perhaps the gears inside are fubar and I should outright just get one at advance auto parts...
Also, the video of my fix.
Old Apr 12, 2015 | 04:34 PM
  #566
icer5160's Avatar
icer5160
It sounds like the drive gear that the motor shaft links up with may be stripped out. There's also the possibility that the brushes you used are too loose and wobbling on the commutator, this could affect timing of the motor. But only 1 week of use is really short. I've had mine up and running strong for around a year now. No problems at all.
-Icer
Old Apr 18, 2015 | 05:56 AM
  #567
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Gonna be doing this today. Hopefully, we'll take some pics and add some pointers to the thread.
Old Apr 18, 2015 | 04:44 PM
  #568
3hree5ive0ero
Retired Admin
My passenger side window crapped out on me about 2 months ago and I'll be doing mine tomorrow.
Side note, anyone know what happened to the original DIY thread before this?
Old Apr 22, 2015 | 10:03 AM
  #569
camilleri21's Avatar
camilleri21
someone broke into my Z and smashed the passenger side window. Took it to an auto body shopped and they seemed to fix my window motor problem lol
Old Apr 22, 2015 | 06:09 PM
  #570
icer5160's Avatar
icer5160
Hey Smooth, how was the experience?
Success?
Old Apr 22, 2015 | 07:28 PM
  #571
SmoothZ's Avatar
SmoothZ
Success?
Seeing that I hadn't done it in years before this last time, it went well. We cleaned up the motor and housing and got it to work. Hopefully, it lasts for a while.
Old Apr 22, 2015 | 08:03 PM
  #572
3hree5ive0ero
Retired Admin
I just purchased a new one from Auto Zone for $150. My passenger side works now!
Old May 2, 2015 | 12:00 PM
  #573
abarclay's Avatar
abarclay
No way on earth I would have attempted to do this on my own without this thread. Took about 4 1/2 hours, but I gots 2 working winnders Huge thank you to VO and kwadell!!
Old May 2, 2015 | 01:23 PM
  #574
SmoothZ's Avatar
SmoothZ
I don't remember how I knew what to do the first time, but I just took it little by little and figured it out.
Old May 7, 2015 | 07:54 PM
  #575
SMKAHOE's Avatar
SMKAHOE
If anyone can please help i would greatly appreciate it. Heres my problem...As soon as I turn off my car, both my windows roll down at the same time and I can't roll them up using the key in the door or from the inside.Windows work perfectly when the car is on but as soon as i turn it off the windows roll down all the way down and i have no control over them. I have tried the reset procedure but it does nothing.
Old May 8, 2015 | 10:50 AM
  #576
icer5160's Avatar
icer5160
SMKAHOE,
First, you might want to make a new thread, since your window motors appear to be working just fine.
Second, if the reset procedure isn't fixing this issue, then there might be a short or problem with your window control switch module located within the driver's door.
Another possibility, do you have an aftermarket alarm system installed?
How long has this issue been going on? Do the windows roll down completely or only part of the way?
-Icer
Old May 8, 2015 | 04:54 PM
  #577
rich2342's Avatar
rich2342
EFF this... wth, motor just took a dump. Guess I gotta pay after reading this, damn. thought the motor would be easily accessible.
Old May 8, 2015 | 05:00 PM
  #578
SmoothZ's Avatar
SmoothZ
It's not hard, but you might as well buy a new motor. I get a free replacement if mine takes a nosedive.
Old May 8, 2015 | 05:23 PM
  #579
rich2342's Avatar
rich2342
I find it strange, that I Unflashed my car today with Uprev and then I started having this issue with the window.
I got it to go back up once playing with it a bit, after the first time It got stuck, then later out of habit hit the auto switch and down it stayed for the night.
Could it be a fuse or short or something due to electrical surge from Uprev process?
Old May 10, 2015 | 08:45 PM
  #580
SMKAHOE's Avatar
SMKAHOE
icer5160,
Thanks for your reply, I do not have an aftermarket alarm system. The problem has been going on for a week now and the windows roll down all the way down into the door.
