OEM battery lasts forever.
Old Sep 21, 2014 | 08:26 AM
  #161
92K1500's Avatar
92K1500
My 04's battery lasted about 9 years before it finally died.
I even have a stereo putting a big load on it and I run it engine off quite a bit.
Old Sep 21, 2014 | 10:27 AM
  #162
bealljk's Avatar
bealljk
Mine was +/- 9years 2003 through 2012 - but the majority of time it wasnt on the road it was in a garage/parking structure.
Old Sep 21, 2014 | 11:20 AM
  #163
92K1500's Avatar
92K1500
I think I was around 75-80k miles when I replaced it.
Old Jan 31, 2016 | 01:27 PM
  #164
GreyZ33Track's Avatar
GreyZ33Track
I am now going to replace my OEM battery on my 04 with 49k miles. I wish I could get the OEM again. Very long life.
Old Feb 1, 2016 | 10:01 AM
  #165
zakmartin's Avatar
zakmartin
My factory battery lasted 8 years and 34K miles. I replaced it a couple months ago just due to its age. I'm still using the factory battery for bench testing parts and I keep it charged using a Battery Tender Plus.
I replaced my factory battery with another Nissan battery (more powerful, same footprint.) The Nissan battery cost less than a new Interstate unit. So far, it's been working like a champ.
Old Apr 13, 2016 | 10:59 PM
  #166
Chadro's Avatar
Chadro
Yesterday i though my OEM battery finally gave out, I had trouble starting the car, thought for sure it was the battery dying, long story short, P0340 error code / cam shaft sensor
So my 04 currently has 106k miles on it and still on its original battery. Talk about dependable!
Old Jul 1, 2016 | 02:05 PM
  #167
HCO_surfer's Avatar
HCO_surfer
Which Nissan battery did you get? Part number offhand? In my z I have a CCA 550 but would like something with more juice.
Old Jul 1, 2016 | 05:43 PM
  #168
craig12895's Avatar
craig12895
I would recommend not getting a battery with more 'juice'. Nissan OEM specifications state what battery our cars come with from factory (which is a Deka brand battery). That specific battery is rated for a specific CCA (I don't know this off hand, maybe it is 550 like you are saying you currently have). Nissan chose a battery with that cranking ability because it's in the "sweet-spot" for the battery, meaning that it will make the battery work, but doesn't over-discharge it.
Getting a battery with a higher CCA may be beneficial and seem fine initially, however in the end you will get less life out of a battery with too high of a CCA. If our cars do not discharge the battery enough, then the car will continue to keep charging the battery and that will quickly lead to an over-charged battery. Yet again, an overcharged battery is fine initially but soon after the plates in the battery will begin to expand, the casing will bulge from this expansion, the straps in the battery will get extra stress from this extra pressure in the battery, and the second a strap begins to crack, the battery will begin to short out and its quickly downhill from there.
Sorry for the lengthy response, but I wanted to back it up my answer with an explanation
Old Jul 1, 2016 | 07:01 PM
  #169
Tochigi_236's Avatar
Tochigi_236
Going on 9 years, 17.8k miles, still holding strong.
Old Apr 9, 2017 | 05:05 AM
  #170
evets's Avatar
evets
Replacing my battery today ... 10 years but only 19,500 miles!
Old Apr 9, 2017 | 12:56 PM
  #171
dcains's Avatar
dcains
I've replaced the battery in my '08 twice, once abut a month ago, and previously about 3.5 years ago. Florida heat is tough on a battery, though. Second was a WalMart Everstart Maxx, and I'm beginning to think the quality of their batteries had suffered lately. We've had two in my wife's TL-S, and both just barely outlived the 3-year warranty, but in the past I'd get 5 or 6 years out of one. This time I put a NAPA Premium in the Z, mostly because they were the only shop that had the proper size in stock.
Old Apr 9, 2017 | 02:46 PM
  #172
craig12895's Avatar
craig12895
Both your Everstart and Napa batteries are produced by East Penn (Deka). You're likely just choosing a different battery group/size/type. Hopefully your new one treats you better than your last.
Typically a very good gauge for how good the battery is, is by seeing how long the warranty is.
Old Apr 10, 2017 | 02:35 AM
  #173
dcains's Avatar
dcains
They all seem to be 3 years now, with only the real low-end cheap ones having less of a warranty.
Old Apr 10, 2017 | 03:17 AM
  #174
craig12895's Avatar
craig12895
Its probably just the florida heat getting to them. Most of our East Penn batteries are solid for at least 4 years. But the high heat is very hard on them so its likely that Florida is the culprit
Old Apr 10, 2017 | 03:40 AM
  #175
carbuffguy's Avatar
carbuffguy
'06 on oem battery here
lapham3
Oct 7, 2022 03:15 PM
350z82
Oct 1, 2015 06:25 PM
