car wouldn't start
Old Sep 3, 2003 | 07:23 AM
lhapp's Avatar
lhapp
Unhappy car wouldn't start
twice now I have turned the key and nothing happens! I turned the key over, reinserted and tried again . . . nothing. . .. I adjusted the steering wheel and nothing. . . adjusted the steering wheel again and it finally caught and started. . . anyone else having this problem?
Old Sep 3, 2003 | 07:28 AM
yobri's Avatar
yobri
Something might be interfering with the connection of the microchip inside the key housing... that is my guess.
Old Sep 3, 2003 | 07:34 AM
6kLaunch's Avatar
6kLaunch
As you are aware, the clutch must be dis-engaged before the starter withh launch. Check to see that the clutch switch is activated properly.
Old Sep 3, 2003 | 09:45 AM
noahbuddy's Avatar
noahbuddy
a nissan engineer said they had trouble with speed pass interfering with the chip in the key. make sure if you have a speed pass you hold it in your hand, away from the ignition when you start.
Old Sep 3, 2003 | 10:47 AM
lhapp's Avatar
lhapp
thanks! no, I do not have a speed pass, and what exactly do you mean by clutch switch?
Old Sep 3, 2003 | 07:08 PM
6kLaunch's Avatar
6kLaunch
Since the clutch must be depressed to start the car, the clutch linkage must have a switch somewhere detecting that the clutch is depressed, closing the starting circuit.
Old Sep 5, 2003 | 07:57 AM
VaGentleman's Avatar
VaGentleman
Do you have any aftermarket alarm system installed?
I do and the same thing happended to me. I tried all 3 keys, but it just wouldn't start.....all guages lit up but nothing when turning the key to start the engine.
Had it towed into the dealerships and it turns out that the after-market alarm wiring to the starter relay wasn't delivering the necessary volts.
Turns out it was just one of the alarm's wire connection that needed to be re-done.
VG
Old Sep 5, 2003 | 08:46 AM
lhapp's Avatar
lhapp
interesting. . . nope no alarm --
Old Dec 13, 2003 | 11:12 PM
ZZZealous007's Avatar
ZZZealous007
So how did you fix it? My car wont turn on. The ignition key will not turn the parking brake and wheel was locked. Help!
Old Dec 14, 2003 | 07:29 PM
jtree007's Avatar
jtree007
Charter Member #53
That is just the steering lock.. just something to stop theft... Try to wiggle the wheel left and right while trying to turn the key and you should unlock the steering wheel..... for more info check you owners manual
etkms
Jun 19, 2022 06:30 PM
lolwatbro
Oct 9, 2021 04:58 AM
350z_z33.
Jul 3, 2017 04:01 AM
Juztin
Nov 22, 2015 07:03 AM
Katie93
Sep 15, 2015 05:57 PM
