VDC light and SLIP light
While driving.. usually on the freeway.. they randomly come on and stay lit.
searched a little and its just the 2 lights and no brake light.
seems like it may be worn brakes? but brakes seem fine.
i think my alighment is off.. could that be a reason why?
help plz thanks!
help plz thanks!
I'd go with Spike's guesses first - tire sizes, worn pair of tires. Then I'd check brakes fluid and brake pads.
However, even with this gross misalignment (I drove the car a couple of days after hitting the curb before having it aligned back to spec), I never experienced any problem with VDC.
Based upon my experience, I doubt that alignment is the causing the OP’s problem. Of course I’m basing my comment on personal experience (one instance on one car) and someone else may provide a different experience.
--Spike
brake fluid is good, pads are good, fluid is good!
my steering wheel is pretty off though lol..
going in for alighment. my friend works at nissan and he said it might be the alighment and have to recalibarate the steering angle sensor.
so hope this works! going in saturday~ give you guys updates!
tires are good too lol
Actually, he's talking about the misalignment of steering wheel and front wheels - as measured by the steering angle sensor. If the computer thinks the steering wheel is turned and it's not really, that can trigger VDC. I believe, as you do, that OP meant suspension alignment (camber/caster/toe) which couldn't be that far out of alignment as to trigger a VDC problem.
The OP (tw8715) states: ”While driving.. usually on the freeway.. they randomly come on and stay lit.”
He doesn’t mention the event is concurrent with applying the brakes.
I've pushed my brake replacement (even to the "squeal"), but that did not affect my car's VDC.
--Spike
I haven’t heard about anyone with that problem though. Was your car in an accident or did you replace some steering/suspension components recently?
Please let us know how this is repaired since it will be a good learning experience.
--Spike
I just had my lights come on! I tried all the normal fix's Alignment, Steering Angle reset, Brake fluid, brakes, etc...no of that was the problem...me and a friend who owns his own shop did a deep look and we were getting the error code 1142 Steering Angle Sensor...we couldn't look deep enough so i took it to the dealer and that was the same thing they found they said there was no communication coming from the sensor! basically this meant I needed a new Steering angle sensor...these are about $500 plus install which shoul donly be about an hours labor...I'm just awaiting for th part to arrive then i'm going to put it in the car and hopefully that is it done and fixed...
I've got a similar thing happening now. I get VDC intervention in right hand sweepers on trailing throttle. If I get on the gas, it stops. Never happens in left turns. Never happens in low speed turns even at fairly high g loads. Just 50-60 mph right hand sweepers off the gas. The VDC light goes out as soon as the VDC stops. So what do I do? Rear sensor, steering angle sensor?
I've had the same exact problem. Although when you VISUALLY inspect the brake fluid level it looks fine however that can be the cause of your problem. I remember I kept saying to myself my brake fluid is fine but someone from this forum told me to top it off with extra fluid all the way up to the top, I tried it out and problem went away. So buy some brake fluid and top it off and see if that solves your problem.
