Replacing headlight lens
Old Jan 3, 2014 | 02:32 PM
rbatakji's Avatar
rbatakji
Default Replacing headlight lens
Hey all,
planning on replacing the outside lens of my headlights. I was planning on buying a pair of cheap ebay headlights and using the lens on my OEM headlights.
My question is are the 03-05 headlights the exact same shape/size as the 06? Because on ebay the aftermarket 03-05 lights are the cheapest and all i need is the outer lens to swap for my 06 oem headlights
Thanks
Old Jan 3, 2014 | 02:56 PM
jhc's Avatar
jhc
General & Tech Moderator
I have used the 3M restore system on 2 cars with excellent results, assuming yours might be clouded but not cracked. All you need is a drill.
Good luck on the lights!
Old Jan 3, 2014 | 05:53 PM
rbatakji's Avatar
rbatakji
The lights aren't clouded or cracked just somewhat scratched/scuffed.
Im assuming the 3M restore system is one of those headlight buffing kits? I've already wet sanded/buffed my lights. Its just that when the headlights are on at night you can really see the wetland marks
Old Jan 3, 2014 | 06:04 PM
BY350z's Avatar
BY350z
Depo brand are a direct swap but are not as good as OEM
https://my350z.com/forum/body-interi...-many-pix.html
Old Jan 4, 2014 | 11:06 AM
rbatakji's Avatar
rbatakji
thanks for posting that thread. I remember seeing it a few months ago but couldn't find it again.
Old Jan 4, 2014 | 04:04 PM
Spike100's Avatar
Spike100
You said: "The lights aren't clouded or cracked just somewhat scratched/scuffed."
How would the lights be "just somewhat scratched/scuffed." as you report?
Old Jan 4, 2014 | 07:16 PM
Sean's Avatar
Sean
Originally Posted by Spike100
WTF?? You said: "The lights aren't clouded or cracked just somewhat scratched/scuffed."
If you drive through corn fields that happens.
Old Jan 5, 2014 | 10:50 AM
rbatakji's Avatar
rbatakji
Its called wet sanding. I wet sanded a while back because they were cloudy. They look fine during the day but when I turn them on at night you can see the wet sanding marks
Old Jan 5, 2014 | 12:08 PM
Spike100's Avatar
Spike100
OK... Got it. Does the "wet sanding marks" diminish the illumination?
I ask because the lens' on my 2003 appear cloudy, but do not seem to lower the light transmission.
--Spike
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
