Rare door handle question
Old Mar 8, 2015 | 06:37 PM
vb350z757's Avatar
vb350z757
Default Rare door handle question
My drivers side door would not open from the outside door handle, but i could use my key fob to put the windows down and open the door from the inside.
I bought a new door handle for the outside and installed it, but what i am experiencing now seems a little funky.
I can open the door from the outside with the new handle now..but i have to yank pretty hard while im using the door handle to get the sucker to open up.
There definitley feels like there is something binding/hindering/getting in the way as i open the new door handle.
All the rods seemed to be in place correctly.
I was just curious if anyone had any suggestions.
Thanks.
Old Mar 9, 2015 | 06:29 AM
dkmura's Avatar
dkmura
General & DIY Moderator
It sounds like the inner door latch is binding in a big way. I'd disassemble the door again and take a close look at the mechanism. Nissan generally engineers precision stuff and it never binds unless damaged or misassembled.
Old Mar 9, 2015 | 06:41 AM
vb350z757's Avatar
vb350z757
I double checked everything after this was happening. Everything looked good, I reassembled the handle... I had even taken the interior door handle off and inspected the cables from the locking mechanism as well as the interior handle and all of that worked fine..
The outside handle just will not release the door latch unless I basically give it a good tug, however the inside handle releases the door latch without issue.
Old Mar 9, 2015 | 06:48 AM
92K1500's Avatar
92K1500
When my outside door handle was in the process of breaking I had to pull on it harder/quicker to get it to release before it finally broke completely.
Old Mar 9, 2015 | 07:07 AM
vb350z757's Avatar
vb350z757
That's the thing... I just put a brand new door handle on it yesterday..
Old Mar 9, 2015 | 07:47 AM
92K1500's Avatar
92K1500
That means either that handle is broken too or something is bent/ inproperly installed.
Old Mar 9, 2015 | 09:10 PM
vb350z757's Avatar
vb350z757
Well..fixed.
Props to you sir.. I kind of omitted the fact that I once had attempted to slim Jim the door open because I locked my keys in my car.
Anyway I knew the rod that seats in the blue "funnel" was slightly bent, however it didn't seem like an issue because the door worked smoothly a few times and then quit on me again.
Long story short I checked out some images of a new rod vs mine and the difference was more than I thought. I bent that sucker back into its correct shape, reinstalled everything, and WALA! Perfect. The rod is now set back into the latch mechanism perfectly, the handle/lock/latch are all smooth as silk and in proper working order.
Thanks again! ...that slight bend from the slim Jim really threw everything out of whack.
Old Mar 10, 2015 | 05:18 AM
92K1500's Avatar
92K1500
Glad you got it working. At least it was a cheap/easy fix.
Old Aug 6, 2023 | 09:48 AM
Zefix's Avatar
Zefix
deleted
Old Aug 6, 2023 | 11:59 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Good post but OP hasn't been on here in years.
Old Dec 18, 2024 | 06:31 PM
GaryH350z's Avatar
GaryH350z
My 2 cents. Great information and I was able to find the GTR part on ebay, took 5 weeks to get here from Japan.
It's not an exact fit as the original has female threads for bolts and this part has male studs which did not come with the part. Had to go to Home Depot and get 4 6mm nuts.
On the driver side I took the panel off because I also changed the motor. After taking the speaker out you can easily get to the hinge,
On the passenger side I decided to try to get through the speaker which is more difficult, without taking off the panel I ended up having to release the panel near the speaker to get to the 3rd bolt holding the speaker in. Once you take the speaker out then the hinge is easy to get to and replace.
cyukio
Dec 28, 2018 06:49 AM
nkbelliotti
Jul 12, 2018 08:32 PM
xz350zx
Mar 21, 2014 05:57 PM
stevie
Nov 12, 2006 08:00 PM
