Paint chip, rust.... your DIY recommendations
Old May 23, 2004 | 02:08 AM
yobri's Avatar
yobri
Unhappy Paint chip, rust.... your DIY recommendations
I just noticed a chip and concurrent rusting on my front driver side quarter panel. Before (in the past), I would sand around the area, which would get some of the surrounding paint as well in order to eliminate all of the rust. Now that this is the Z, I wanted to get some advice from board experts about DIY recommendations about how to alleviate this problem. I'd rather not pay to get if fixed, if there is something that I can do about it (since the chip is pretty small). The affected area is not completely rusted, but the beginnings of rust are occuring. Thanks
Old May 23, 2004 | 05:12 AM
Dissolved's Avatar
Dissolved
You have to neutralize the rust. I think autozone or parts america sells a rust neutralizer (comes in a white bottle I believe. It's liquid) in their paint section. If not, try the section with the aircraft paint remover and sanding stuff.
Apply a little of that with a q-tip.
Old May 23, 2004 | 02:19 PM
yobri's Avatar
yobri
Thanks man Glad that this is more simple than I had previously thought.
Old May 24, 2004 | 05:05 PM
n8vz's Avatar
n8vz
get a fiberglass sanding pen(made by 3M) to remove the rust and use some touch paint. You can also try something like Langka blob remover. It works well, but will not be a *perfect* paint job.
Old May 24, 2004 | 06:59 PM
yobri's Avatar
yobri
Thanks n8vz, I bought some Bondo Rust Remover today, did the job nicely. Put some touch-up paint on, doesn't look the best, but I feel a whole LOT better that the chip and rust are gone
Old May 26, 2004 | 08:01 PM
benzz280's Avatar
benzz280
check this out: http://www.customrodderweb.com/tech/...rustinhibitor/
Old May 26, 2004 | 10:25 PM
yobri's Avatar
yobri
Thanks for the link It's now bookmarked. My beater has pretty sizeable rust spots... time to clean those up as well
Old May 28, 2004 | 04:22 PM
ochinsan's Avatar
ochinsan
take it back to the dealer and chew them out. make them repaint the whole panel, I did it and so can you. Tell them the paint job sucks!
Old Apr 26, 2005 | 03:27 PM
zmespeed's Avatar
zmespeed
i bought the car used but i think the origanal dealer is very close to me. plus i have all the paper work for the car. i might do this for the rust inside the door. thx.
i just realized this was not the tread i thought it was but the advice still works for me. haha
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Rev_Night
Nov 7, 2020 06:00 PM
Cashwin
Oct 1, 2015 06:36 AM
