NA Build Inside....Soup to Nuts :)
Old Jul 17, 2008 | 08:04 AM
  #601
Ivory's Avatar
Ivory
did that really give you any gain? any stats on how much back pressure you lost and the change in torque curve?
Old Jul 17, 2008 | 08:56 AM
  #602
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it was a joke
Old Jul 17, 2008 | 09:32 AM
  #603
__jb's Avatar
__jb
Z + Rear Seat
Originally Posted by Kwame@z1
^ No, new modifications just some additional tuning.
Any news on your BC stroker?
I notice that it's back out of your Sig again... I suspect that's a bad sign...
Old Jul 17, 2008 | 10:32 AM
  #604
Kwame's Avatar
Kwame
Honestly, its not a bad sign I just got tired of seeing it and getting PMs (don't worry I don't mind you asking about it ). But I recently made a huge financial move and left my day job (mortgage biz) to go back to school. So I had to lay off spending huge chunks of money on the Z. I'll be back at it very soon, as I'm at the shop full time (631-863-3820 if you need any parts lol).
How is your project going?
Old Jul 17, 2008 | 11:52 AM
  #605
__jb's Avatar
__jb
Z + Rear Seat
Glad to see that it's still a work in progress.
Mine is coming along, but currently moving slowly too. Ended up special ordering a set of pistons and they seem to be taking forever to come in. Can't do much until we get the pistons.
Old Jul 17, 2008 | 09:18 PM
  #606
Ivory's Avatar
Ivory
Originally Posted by Z1 Performance
it was a joke
After seeing the kind of things happening around the forums, I no longer pass any judgment on anything done to the cars at all. So naturally I have no sense for sarcasm or humor.
In any case, surprised how much you've gained from tuning alone.
Old Jul 18, 2008 | 06:47 AM
  #607
Z1 Performance
Former Sponsor
it shouldn't come as any surprise...proper tuning is what separates just a nice parts list from actually working and making power. This is still all being done on regular run of the mill pump gas as well. Both tunes done so far have been completed in 85-90 degree weather. I'm sure with race gas put into the mix, on a nice cool, fall day, another 10-15 whp could easily be achieved, but I'm all about tuning for the worst case scenarios, as it's just a street car
Old Jul 18, 2008 | 07:58 AM
  #608
Ivory's Avatar
Ivory
Sounds nice. There is hope for 400whp stroker NA yet.
Old Jul 18, 2008 | 08:50 AM
  #609
Hoooper's Avatar
Hoooper
+1000000. i cant believe how many cars i see that have a real nice parts list and even a good ECU/piggyback to tune with but still clearly arent tuned well. its refreshing to see your car where more time goes into maximizing what you have and not what you can buy next
Old Aug 5, 2008 | 10:58 AM
  #610
copec's Avatar
copec
Do you happen to have pics of the porting of the heads and lower intake manifold?
Old Aug 5, 2008 | 11:13 AM
  #611
Ivory's Avatar
Ivory
what kind of valve setup did you use?
Old Aug 6, 2008 | 06:58 AM
  #612
Z1 Performance
Former Sponsor
stock valves on my car, nismo valvesprings
Old Aug 6, 2008 | 08:32 AM
  #613
Ivory's Avatar
Ivory
Oh ok. Thanks, because I talked to the shop with the ITBs from Jenvey, he was telling me a +1 advance on the valves yielded some pretty significant hp to the wheels. So I was wondering if you had any particular setup to the valves.
Old Aug 6, 2008 | 08:34 AM
  #614
nismology1's Avatar
nismology1
How do you advance valves? You mean +1mm diameter? Larger valves are definitely not in the value sweet-spot for building up an n/a VQ.
Old Aug 6, 2008 | 08:39 AM
  #615
Ivory's Avatar
Ivory
he said +1 so..yeah you are right with the mm but Im sure they have a reason to say that, especially after gaining 35whp from it with the ITB
Old Aug 6, 2008 | 08:44 AM
  #616
nismology1's Avatar
nismology1
If my budget was unlimited I'd go for it. I'd probably have the combustion chamber reshaped and get a good valve job before I went oversize, though. My $.02.
Old Aug 6, 2008 | 10:28 AM
  #617
Ivory's Avatar
Ivory
probably going to leave the valves as is, the job just keeps getting bigger
Old Aug 6, 2008 | 11:11 AM
  #618
Z1 Performance
Former Sponsor
You're not going to net 35 whp from going to ITB's on this car, let alone going +1 on valves, whether you use an ITB or not. Based on what I've seen with a bunch of heads on the bench, I'd bet you would not even gain 5 whp. The valve diameter is not the biggest issue on the car, especially in NA form, there are plenty of other areas to focus resources IMHO. Again, a good machinist is the single most important factor in building this, or any other engine
Old Aug 6, 2008 | 01:26 PM
  #619
Ivory's Avatar
Ivory
I'm going by what the tuner told me, which has netted 400+ whp on their NA VQs while running the ITBs in UK, the same ITB in the 380RS Nismo race cars.
Old Aug 6, 2008 | 03:04 PM
  #620
Z1 Performance
Former Sponsor
I won't get into what dyno #'s race teams world wide are getting out of the VQ because that's neither here nor there. Keep in mind that those are full out race builds, on race gas, with tremendous compression, very aggressive cams, dry sump oil systems, full standalone mgmt., sequential gearboxes, etc - these are not street cars by any stretch of the imagination, these are full out, competition level, $300,000 race cars. Yes, those engines certainly do exist, and have for quite some time. For about $50k starting price, they'll even sell you one I bet http://www.rjnmotorsport.com/ is one such source.
The 380RSC race car yes uses a Jenvey setup...but it's not the same setup as you see posted, as the RSC uses an HR engine, not a DE, and it's also got significantly lower mounting than a std. VQ engine,different trumpets, a fully spec'd airbox (I'd guess around $5k alone for that), etc etc.
