my turn
Old Feb 13, 2012 | 12:20 PM
  #221
Classy's Avatar
Classy
interesting info, just a shot in the dark, but I think your osiris logs will show you that your oil pressure at 600 rpm is low, and therefore is not engaging VCT like it should, but when the rpm raises enough to engage enough oil pressure you are fine. To be honest, I think this problem will probably work itself out during break in. With those BC stage 2 cams, you probably should have at least an 800 rpm idle, have you had any stalling issues or any stuttering at idle?
I hate sound problems on forums, it is impossible to recreate a sound problem on video... We want to help but it is hard too... I wish you at least had a cypher cable, those logs and being able to raise your idle alittle would probably be very beneficial. Best of luck here and if there is anyway I can help, let me know.
Old Feb 13, 2012 | 12:23 PM
  #222
Classy's Avatar
Classy
also, what weight oil are you using, how many miles do you have on the new motor? Have you looked all over the engine for oil leaks? Have you changed the oil yet? I would strain it out and see what comes out, my first 2 oil changes looked ugly, but cleared up and the car made more power by about 5000 miles
Old Feb 13, 2012 | 12:30 PM
  #223
mgrotel's Avatar
mgrotel
i agree about the oil pressure, which is what makes me think i might have some sort of internal leak that causes just enough of a pressure drop at idle to make things noisey. before my next oil change, im going to run some seafoam through the oil to maybe clear out some blocked passages if that is the case. other than that, idk
i do have a cypher cable, i have the full tuning package. is it easy to raise the idle? maybe i should do that so it isnt so noisy anymore
Old Feb 13, 2012 | 12:32 PM
  #224
mgrotel's Avatar
mgrotel
right now i have 200-300 miles on the car. i lost track because of resetting the ecu so many times. i am on the second batch of oil, first was joe gibbs break in oil, now pennzoil plat 5w30 full synthetic. no leaks and no codes. when i dumped the oil the first time, it looked really clean, but had only 150 miles on it or so.
Old Feb 13, 2012 | 12:34 PM
  #225
bjmax's Avatar
bjmax
He Changed the oil. Did you? To 5w30? Or still on the breakin oil?
Old Feb 13, 2012 | 12:36 PM
  #226
Classy's Avatar
Classy
don't quote me because I never had a cable. But I am pretty sure you can raise the idle. I have mixed feelings about seafoam.
Old Feb 13, 2012 | 12:39 PM
  #227
Classy's Avatar
Classy
please keep us updated on what happens with the idle correction, and I will keep looking for what cypher says about oil pressure and VTC
Old Feb 13, 2012 | 12:40 PM
  #228
mgrotel's Avatar
mgrotel
im 95% sure i can raise the idle with the software, im just not sure how. and osiris will not tell me oil pressure.
Old Feb 13, 2012 | 12:41 PM
  #229
mgrotel's Avatar
mgrotel
i will def keep this updated on all things for sure.
Old Feb 13, 2012 | 12:45 PM
  #230
mgrotel's Avatar
mgrotel
youre right, i switched to pennzoil plat 5w30. maybe i should try 10w30?
Old Feb 13, 2012 | 12:54 PM
  #231
bjmax's Avatar
bjmax
5w30 is fine. Lets see What It will do when raising the idle. And about oil pressure can't hurt to buy a nice one.
Old Feb 13, 2012 | 01:05 PM
  #232
mgrotel's Avatar
mgrotel
oh, you mean a nice oil pressure tester?
Old Feb 13, 2012 | 01:22 PM
  #233
bjmax's Avatar
bjmax
oil pressure gauge on your dash. So you can always see it.
Old Feb 13, 2012 | 01:33 PM
  #234
mgrotel's Avatar
mgrotel
yea, eventually that is a definite possibility, but for now i just need a tester to see what my oil pressure is
Old Feb 13, 2012 | 01:58 PM
  #235
denchan350gt's Avatar
denchan350gt
You can raise your idle through cipher. Don't need the tuner program.
Old Feb 13, 2012 | 05:05 PM
  #236
str8dum1's Avatar
str8dum1
you cannot raise idle with just cipher. you have to reflash your car, so you need the tuner program
Old Feb 13, 2012 | 09:49 PM
  #237
bjmax's Avatar
bjmax
i have a consult II cable. and that works fine.. i can raise it to 950 rpm..
Old Feb 14, 2012 | 05:57 AM
  #238
mgrotel's Avatar
mgrotel
doesnt matter, i have the tuner version anyway
Old Feb 14, 2012 | 06:07 AM
  #239
mgrotel's Avatar
mgrotel
small update, over 100 miles and no code at all, so i think its safe to say the code was from the bad bank 2 solenoid that i swapped out. did some more listening to the noise last night with a bunch of extensions attached together to try and narrow down where it was coming from. im not positive, but pretty sure its coming from the timing chain, probably getting slack in it at idle and slapping the covers. although, for a while last night, it was idling and not doing it. so, i think ill see if it works itself out of it, otherwise might be one of the chain tensioners. thats all i have for now
Old Feb 14, 2012 | 07:46 AM
  #240
mgrotel's Avatar
mgrotel
does the manual detail out how to raise the idle and flash the ecu? thanks
