my turn
Old Feb 28, 2012 | 11:38 PM
  #301
mgrotel's Avatar
mgrotel
Originally Posted by Classy
To be honest, you are probably fine. If it is a low oil pressure issue, it is just your VCT gears chattering because there isn't enough oil pressure to tell them what to do
I'm pretty sure it's the timing chain hitting the case, which I think is aluminum. So it won't take long for the chain to chew through it, but at a minimum it is throwing shavings in my oil. It is annoying as **** and I
Still hear it with the idle at 900
Old Mar 1, 2012 | 04:47 AM
  #302
Classy's Avatar
Classy
There are shavings in your oil?? Uh oh!!!
Old Mar 1, 2012 | 04:56 AM
  #303
e30cabrio's Avatar
e30cabrio
Are you opening the cover to see if there is contact?
Have you sent the oil out to be tested?
Sorry this is happening.
Old Mar 1, 2012 | 05:28 AM
  #304
mgrotel's Avatar
mgrotel
i have not verified there are any shavings in my oil, but a timing chaing contacting an aluminum case makes it pretty obvious
Old Mar 1, 2012 | 05:34 AM
  #305
e30cabrio's Avatar
e30cabrio
If that is what Is happening sure until you open it up who knows?
Old Mar 2, 2012 | 05:03 AM
  #306
Classy's Avatar
Classy
I think you are assuming a lot, and need to dig into it and find out exactly what is going on before you jump to conclusions
Old Mar 17, 2012 | 12:10 PM
  #307
0jiggy0's Avatar
0jiggy0
Bumps in a dump
Old Mar 17, 2012 | 12:13 PM
  #308
e30cabrio's Avatar
e30cabrio
It appears he gave up.
I understand completely but have to say it was so worth seeing it through (in my case)
Old Mar 17, 2012 | 12:26 PM
  #309
0jiggy0's Avatar
0jiggy0
I dont, your first time building a motor and you choose a VQ and are suprised something went wrong? It's all part of learning.
Old Mar 17, 2012 | 12:30 PM
  #310
e30cabrio's Avatar
e30cabrio
That is why I did not do mine myself. I looked at the manual and said no freaking way.
Old Mar 18, 2012 | 11:36 AM
  #311
Classy's Avatar
Classy
I did mine myself and only had one problem (it was my fault for rushing things...)
Either way, I hope he finds happiness in something with more power, I know I will!!!
Old Mar 23, 2012 | 07:53 PM
  #312
mgrotel's Avatar
mgrotel
Was loose torque converter bolts, I torqued them to spec but I guess they need more torque and loctite
Old Mar 23, 2012 | 08:07 PM
  #313
e30cabrio's Avatar
e30cabrio
So all is well?
Old Mar 23, 2012 | 08:14 PM
  #314
mgrotel's Avatar
mgrotel
Yea, except for an oil leak which will be fixed soon
Old Mar 23, 2012 | 08:15 PM
  #315
e30cabrio's Avatar
e30cabrio
Cool glad it was not the motor.
Old Mar 23, 2012 | 08:26 PM
  #316
mgrotel's Avatar
mgrotel
Haha, meeeee too man
Old Mar 24, 2012 | 08:54 AM
  #317
Classy's Avatar
Classy
damn autos!
Old Mar 24, 2012 | 11:26 AM
  #318
mgrotel's Avatar
mgrotel
Damn factory service manual!
Old Mar 24, 2012 | 03:26 PM
  #319
Classy's Avatar
Classy
Damn Nissans?????????
Old Mar 25, 2012 | 06:46 AM
  #320
mgrotel's Avatar
mgrotel
lol
