87mm TB Project
Old Mar 29, 2015 | 02:35 PM
  #361
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Very interesting. Thanks for the update.
Old Mar 29, 2015 | 04:06 PM
  #362
bikinilust's Avatar
bikinilust
Woooowww
Excited to see what kind of hp numbers are to be found
Old Mar 30, 2015 | 02:17 PM
  #363
Fixxxercask's Avatar
Fixxxercask
Dyno day scheduled tomorrow at noon. This guy is super booked and I have to take a half day from work to make this happen unfortunately. I have a couple hour window tomorrow to get all the tuning done. Since the time frame is narrowed, I most likely won't get to test both intakes. I would love to but it all depends on how things go.
Fingers crossed for 300whp!!! Hoping for 320 but realistically that probably won't happen.
Old Mar 30, 2015 | 02:20 PM
  #364
MonkeyMagic72's Avatar
MonkeyMagic72
I just read through the entire thread, and I consider doing this similar intake mods to my HR. It won't be that size though, lol. Got any update of this beast on the dyno?
Old Mar 30, 2015 | 02:22 PM
  #365
03threefiftyz's Avatar
03threefiftyz
Old Mar 31, 2015 | 02:29 PM
  #366
Fixxxercask
Dyno day not so well today. Car is having issues and pulling loads of timing around 5200 rpm. Not sure the root cause of it. I am talking with some folks about possibilities. Strange thing is, I put stock MAF, TB and plenum back on and its doing the same thing. Starting to think its mechanical. You can see in the logs that the cam solenoid % dumps to 0 for some reason and right after that, timing goes to hell and power is gone. No codes either. To be continued.
On a brighter note, looking at what little graph I have, the car is making the same power at 4800 that my old motor made at peak. I think its got 300+ in it once I get this ironed out.
Old Apr 1, 2015 | 03:40 AM
  #367
03threefiftyz
We'll get ya sorted....
Old Apr 2, 2015 | 06:19 AM
  #368
2TH PWR's Avatar
2TH PWR
At 4800 rpm it looks like my engine made about 232 hp.
Old Apr 2, 2015 | 06:20 AM
  #369
2TH PWR's Avatar
2TH PWR
My last dyno. currently undergoing rebuild. new injectors. new exhaust.
Old Apr 2, 2015 | 06:26 AM
  #370
Fixxxercask
Nice!
I am not far off that at all. We will see what happens once I get this sorted out.
Old Apr 3, 2015 | 07:18 AM
  #371
waldo36's Avatar
waldo36
That TQ curve...I mean straight power line. That's just awesome.
Old Apr 8, 2015 | 05:51 AM
  #372
Fixxxercask
Checked timing chain; all links are perfect and all timing marks spot on. No links any teeth off. Replaced both cam sensors and will replace crank sensor. Going to zero out the cam table too. Going to drag strip (with a road race car, I will probably look like a dbag, but oh well...lol) on Sunday to do some data logging. This is way cheaper than burning $100/hour on dyno. Hopefully I can pinpoint issue or replacing those sensors helps. I have a feeling its a tuning issue. If all ends well on Sunday, I will scheduled dyno again.
Old Apr 8, 2015 | 05:54 AM
  #373
Classy's Avatar
Classy
I always just looked for a not very used country road
Old Apr 8, 2015 | 11:31 AM
  #374
Fixxxercask
I would love to, but I have to drive through a decent amount of rural areas first before I get there. Where I live, I know people would complain and the car would get impounded. There are no tags on the car anymore, therefore not registered either.
Old Apr 8, 2015 | 01:28 PM
  #375
Classy's Avatar
Classy
Ah, dedicated track car, not even attempting to be street legal
Old Apr 8, 2015 | 01:33 PM
  #376
03threefiftyz
Ha....we have to go to the extremes to take the fight to Z06's in TT3.
Old Apr 8, 2015 | 02:23 PM
  #377
Classy's Avatar
Classy
What can you do to make your 350Z compete with a Z06 in TT3??
Old Apr 8, 2015 | 02:43 PM
  #378
03threefiftyz
Tin can and lots of aero. Unfortunately they do the same thing, but ballast up or restrict the motor.
Old Apr 8, 2015 | 03:14 PM
  #379
03threefiftyz
The spoiler to the Z06 East Coast winners could be Chris Mayfield in an S54 E36 if he makes the trip from CO to VIR in Sept...
Old Apr 9, 2015 | 02:39 AM
  #380
Fixxxercask
Yea the Z06's run big power and heavy weight with a ton of perfectly placed ballast and moster tires or detune both with loads of aero. My buddy (ST3 National Champ) runs detune to 330whp at around 3100lbs or so with 200lbs of ballast in his car and runs 275 tires. He has his car tuned to make 330whp around 4700 RPM or so all the way to redline so its basically making 330whp the entire time its on track.
Hard to compete with that if the driver is really good.
