Norcal Track Days
Old Jul 19, 2011 | 04:17 PM
  #381
pchio's Avatar
pchio
You could probably spend 150 less and get better fittings, etc....if you just piece it together. It is really very simple.
Totally Agree! I guess that is probably the extra money to pay for someone who did the research and back their products.
Installation is simple, however, it involves removing bumper, drill holes on radiator support for mounting brackets and hoses.
Old Jul 19, 2011 | 04:20 PM
  #382
SE5spd's Avatar
SE5spd
Originally Posted by pchio
I have the GTM oil cooler, and I also did the installation on King's 350z too. I have been using it for many many track days. No issue and no problem at all. They have 2 sizes, one for street and one for racing. However, if you have HR and stock bumper, the engine will still runs hot. It might be better to get a aftermarket bumper with bigger opening or the racing oil cooler (bigger).
This is what I'm looking at
http://www.gtmotorsports.com/product.php?productid=16939
How can you tell the difference between the "street" and "race" one?
Old Jul 19, 2011 | 05:37 PM
  #383
wheelophile's Avatar
wheelophile
im still waiting for you to post those LMGT4s for sale, buddy!
NO ONE but me is going on the 29th at t-hill with team racing?
Old Jul 19, 2011 | 07:14 PM
  #384
SE5spd's Avatar
SE5spd
How much?
Old Jul 19, 2011 | 07:17 PM
  #385
SE5spd's Avatar
SE5spd
Btw whats your Z look like and what yr is it? I wanna know if I saw you on the 10th at thunderhill or not?
Old Jul 20, 2011 | 12:03 AM
  #386
pchio's Avatar
pchio
HD is smaller, Competition is larger. Give GTM a call if you are not sure. They are very helpful.
Or you can talk to Rod @ Z Car Garage for his opinion.
Hey, haha. I have been using them for my track wheels. Perfect size, looks and offset. I dont think I am going to sell it any soon. But if I do, I make sure I let u know
Old Jul 20, 2011 | 12:21 AM
  #387
SE5spd's Avatar
SE5spd
I talked to rob a couple weeks ago, I think I'm gonna go to him a call when I'm ready to pull the trigger.
Old Jul 20, 2011 | 12:28 AM
  #388
SE5spd's Avatar
SE5spd
http://www.gtmotorsports.com/product.php?productid=17403
That one correct?
Hmm I wonder if the extra $150 or whatever is worth the differance?
I probably won't even get it until I start getting to the point where I notice my oil pressure lower then normal after track sessions.
Old Jul 25, 2011 | 09:57 PM
  #389
SE5spd's Avatar
SE5spd
Does anyone use an oil temp gauge? I'm thinking of getting one before I get an oil cooler to see what my temps actually get to, or of my oil is getting to hot. That, or getting a gauge at the same time I get a oil cooler.
Any input?
Old Jul 26, 2011 | 06:14 AM
  #390
scotts300's Avatar
scotts300
Any input?
You should absolutely get a gauge, and follow it with an OC when you're ready (i.e. when you drive the car hard enough to require it).
Old Jul 26, 2011 | 08:17 AM
  #391
SE5spd's Avatar
SE5spd
Yeah I was thinking of getting this
http://www.glowshiftdirect.com/tinted-7-color-oil-temperature-gauge.aspx
And getting a single gauge holder for the pillar
Or I really wanna put it in the cubby but don't know how to wire it from there.
Old Jul 27, 2011 | 03:30 PM
  #392
SE5spd's Avatar
SE5spd
Just ordered a oil temp gauge and gonna attempt to build a gauge holder for the cubby
Old Jul 27, 2011 | 04:01 PM
  #393
Neimad's Avatar
Neimad
When you get it, see if you can use the same signal from the pressure sensor.
Old Jul 27, 2011 | 04:35 PM
  #394
SE5spd's Avatar
SE5spd
I just bought a oil filter sandwich and gonna rig it up that way. What you just said might be easier though..if possible? (anyone know if that's possible?)
Old Jul 28, 2011 | 02:17 PM
  #395
SE5spd's Avatar
SE5spd
Finished building the gauge holder for the cubby last night, one the gauge comes in and everything is said and done I'll post pictures. If anyone likes it, I can build them one since I bought WAYYYYYY to much ABS plastic
Old Jul 28, 2011 | 02:50 PM
  #396
scotts300's Avatar
scotts300
I don't think oil temp comes along with the pressure signal on the 350. The 370, yes, but I don't believe the 350's ECU reads oil temp, hence why you need to tap in or do the filter sammich.
Old Jul 28, 2011 | 03:22 PM
  #397
Neimad's Avatar
Neimad
I checked the datastream yesterday, no oil temp. Fuel temp is there if anyone wants it though.
I was confused yesterday, thinking oil and pressure used the same type of sensor to drive a different type of gauge. Isn't it a direct correlation between pressure and temp?
I think I need to give my ASE's back.
Old Jul 29, 2011 | 07:17 AM
  #398
scotts300's Avatar
scotts300
PV=nRT suggest it is a direct correlation, but I think you get a lot more temperature rise with only a minimal increase in readable pressure. Plus the oil pressure changes with g-forces.
Old Jul 29, 2011 | 12:14 PM
  #399
SE5spd's Avatar
SE5spd
It should be here by Wednesday or so, so ima do a brake bleed and install my SS lines, install the gauge (hope it's not to hard lol) and I'm ready for thunderhill in September
Old Jul 29, 2011 | 05:57 PM
  #400
solidfish's Avatar
solidfish
Its a sad day for me. The car has been sold...
Just as I was getting a little better around the track! I had to start picking up the baby and needed rear seats. Thought of every option to make that work in the Z, but couldnt make it happen.
I'll still be on here to keep up with the track news. And I still plan to get on the track with the next car, even if its a sedan.
