Convertible Top Problem -Won't Open
Old 09-03-2007, 12:29 PM
skyhiguy
skyhiguy's Avatar
Default Convertible Top Problem -Won't Open
All,
Have an '04 Roadster and all of a sudden the top will not retract. The windows open, passenger seat tilts forward and I hear rear locks release but nothing after that in opening sequence. I've checked fuses up front and they look fine, pulled and reset them anyway with no change. Any one had this before and what did you find was problem?
rtfutrell97 (09-24-2022)
Old 09-03-2007, 01:49 PM
Chosin
Chosin's Avatar
Sounds like motor problem.
Old 09-04-2007, 02:21 PM
skyhiguy
skyhiguy's Avatar
That's what I'm thinking too ................... any history of these motors needing replacement this early in the program - 23,500 miles 3 1/2 years old, or am I just fortunate?
Bud
Old 09-04-2007, 03:41 PM
Built2shredZ
Built2shredZ's Avatar
Sounds like your the lucky winner
I've yet to hear anyone have problems with the top motor... My brother has a 2004 also and he is continuously lowering and raising his top and its still running strong.
Old 09-04-2007, 05:17 PM
DDS 350
DDS 350's Avatar
Exclamation
I had a similar problem with my 04 at about 13,000 miles - exact same symptoms. It was just out of warranty (more than 36 months) and the service department at the dealer where I bought it wanted $5,600 to fix the problem. They basically wanted to replace the entire soft top apparatus. I complained to Nissan USA and they spoke to the dealer who was not going to do anything for me.
I went to another Nissan dealer and they determined that two shocks had failed and the motor died due to overwork. They fixed this for about $1,200, which was much more reasonable. I am happy to have the top work and being in Florida, I drive top down at least once a day. I just hope that it does not fail again.
Old 09-04-2007, 05:41 PM
raj
raj's Avatar
Default Same problem here
I also have the same problem. Only thing is, it opens sometimes and other times it will not.
Seems like whenever i take it to Nissan to get the problem fixed the top is working fine!!!
Old 09-04-2007, 05:50 PM
skyhiguy
skyhiguy's Avatar
Thanks for the input. I'm in NC and drive top down most of the time .......... especially this time of year. Looks like a trip to the dealership is in order and maybe a call to Nissan first to maybe help soften the blow to the wallet!
Old 09-04-2007, 05:53 PM
skyhiguy
skyhiguy's Avatar
I had that same "sometimers" problem with my passenger window motor last year. Took it to dealer two times and of course it worked both times, the third time a maintenance tech told the service manager that those motors are known to fail and then he replaced it. At least I was unde4 warranty then ...... no more.
Bud
Old 09-05-2007, 08:57 AM
iStan
ZR
iStan's Avatar
At that point, I'd buy a Civic to drive during bad weather and just rip the top out.
Old 02-24-2019, 06:56 PM
Quranjohnson
Quranjohnson's Avatar
Hello I have a 2005 350z roadster and my top does not go down, when I press the button nothing happens no sounds l, no I’m latching, the windows or seats doesn’t move. Do anyone have a idea what that could be? I tried to post a video but it’s not posting
Old 06-01-2022, 05:41 PM
goldengolden
goldengolden's Avatar
Hi, my light that tells me that the roof is open was lit. The passenger seat moved and so did the windows. The soft top roof would not go down and I could hear a latch clicking when I pushed the open roof button. I disconnected the air shocks on the roof with a little screw driver. there is a little band that goes about 60% around the air shock ball. looks like it should be slid towards you to come out of 2 slits on each side of the ball socket. I then lifted the back part of the roof up, the latch was not holding it closed, the back of the roof was free. I didn't know what to do, so I attempted to close the back of the roof, with the ***** of the air shocks back in place, and the metal that gets latched got stuck with a 2" space between the car and the back of the roof. I went back into the car and the roof started working again. So the latch was not holding the back of the roof at the beginning and that is what made the light lite up and stop the roof from functioning. Me messing with the shocks and the back of the roof somehow reset everything to work.
Old 06-08-2022, 02:28 PM
Raynemaeker
Raynemaeker's Avatar
Default top won't open
2004 convertible top won't open . I checked the rear window bow struts and one compresses easily but they are 245.18 from nissan. is there anyway to rebuild these or find them elsewhere?
97131-ce40a
97130-ce40a
Old 06-08-2022, 02:30 PM
Raynemaeker
Old 06-08-2022, 07:37 PM
goldengolden
Default Cheaper ones
97131-ce40a
97130-ce40a
If, I were you I'd go to a compressed air shock store and ask the guy. I found some cheaper ones. https://www.tascaparts.com/oem-parts...RoC7R0QAvD_BwE you should be able to find the other one there too. $153 each.
Old 06-09-2022, 08:29 AM
Raynemaeker
The one I know is weak is the opposite (driver) side. that site says that one is not available. Thanks I will check to rebuild
Old 06-10-2022, 04:29 AM
goldengolden
Maybe you could find one at a junk yard.
Old 06-10-2022, 04:33 AM
goldengolden
Look on Mcmaster car, https://www.mcmaster.com/shocks/
Old 06-12-2022, 09:50 AM
goldengolden
Maybe you could slip a compression spring around the shaft.
Old 03-06-2023, 05:15 AM
Tulip350z
Tulip350z's Avatar
Default What motor for a top that won’t work? 5th bow?
Is there another motor for the top other than a 5th bow?
Old 04-16-2023, 08:58 PM
SynnyG
SynnyG's Avatar
Default Convertible problems
I’m a new Z owner the convertible top won’t open you can hear what I’m guessing is the 5th bow motor engaging but no movement and yes I unlocked the front lock above the rear view mirror and I have a 1-2 inch gap in the back at the storage compartment the car is running and handbrake engaged and foot on the brake (6 speed manual) but I’ve been having the dreaded problems with the passenger side door and window working when they feel like it although you can hear the window motor when you try to roll it down and the door currently won’t open you have to hit the unlock button while standing on 1 foot rub your belly and pat your head while in the middle of a backflip and if you land just right you hit the button and it’ll unlock and open will the top open if 1 of the windows won’t roll down? Any help would be greatly appreciated thanks in advance
Dontmocme
350Z Roadster
13
05-30-2018 05:08 AM
myfairlady33
04-15-2014 09:30 PM
krunch
350Z Roadster
08-23-2012 05:09 PM
David2673
04-13-2011 08:44 AM
brunoboy
350Z Roadster
05-28-2009 04:04 AM
Quick Reply: Convertible Top Problem -Won't Open
