Unofficial Enkei Wheels Thread
Old Oct 24, 2012 | 08:19 AM
  #1501
ny350zat's Avatar
ny350zat
specs?
Old Oct 24, 2012 | 09:01 AM
  #1502
Bmurray350z's Avatar
Bmurray350z
18x9.5 +15
18x10.5 +15
255/40/18
275/40/18
roll rear fenders
/thread
Old Oct 24, 2012 | 09:48 AM
  #1503
mvp2765's Avatar
mvp2765
Sounds about right ^
Old Oct 24, 2012 | 09:56 AM
  #1504
iKevinz's Avatar
iKevinz
These are my specs. Lowered on Eibach Sportline.
18x9.5 +15 18x10.5 +15
255/40/18
275/40/18
Rolled rear fenders. The Square set up is also an option 18x10.5 +15 All around
Here's a pic
Old Oct 24, 2012 | 10:42 AM
  #1505
terrasmak's Avatar
18x9.5 +15
18x10.5 +15
255/40/18
275/40/18
roll rear fenders
/thread
Many other tire options too
265/35 front and 285/35 rear
275/35 front and 285/35 rear
10.5 +15 is really not that great of an option, around -3 front camber is needed. Good for track, not street.
Old Oct 24, 2012 | 10:45 AM
  #1506
ny350zat's Avatar
ny350zat
So what would be a good offset for the streets on the front end of the car? 15+ for the rear is fine right?
Old Oct 24, 2012 | 10:48 AM
  #1507
ny350zat's Avatar
ny350zat
can I run oem alignment specs in the front w this set up?
Old Oct 24, 2012 | 10:53 AM
  #1508
terrasmak's Avatar
9.5 +15, is what you want. and you may need a slight amount more front camber than OEM spec. OEM specs suck anyhow -0.3 to -1.1 i believe but it shoud be -0.6 to -1.5 IMO
Pull up and offset calc < Google the bold, and you can see the difference between 10.5 +15 and 9.5 +15
Old Oct 24, 2012 | 11:08 AM
  #1509
ny350zat's Avatar
ny350zat
That much camber wudnt ruin my tires right? I really dnt have much clue about this..I wud like to run 245 in front 275 in the rear...
Old Oct 24, 2012 | 11:48 AM
  #1510
terrasmak's Avatar
If you do a lot of corner turning it will mmake you tires last longer, if you have nothing but straight roads like us who daily drive in Vegas , it will reduce your tire life by a few thousand miles. No big deal.
Ive was runnning around -2 on the street for a few years and still got around 30k out of my street fronts, then for the year before my car became a dedicated play toy i was running -2.8 up front and still got over 25k out of them.
Camber hurts a little, inproper toe will screw up the tires in a quickness.
Old Oct 24, 2012 | 12:10 PM
  #1511
ny350zat's Avatar
ny350zat
haha yea dude i live in long island NY i dont see straight road unless i get on a highway......ok so so far this is what ill do 18x9.5f 15+offset and 18x10.5r 15+offset rear, 245 tires in front and 275 tires in the rear w a slight fender roll? any other info u guys might suggest?
Old Oct 24, 2012 | 12:24 PM
  #1512
terrasmak's Avatar
255/40 front
Old Oct 24, 2012 | 02:17 PM
  #1513
ny350zat's Avatar
ny350zat
Wudnt this be too much ratotional mass on the wheels\tires? Nd possible affect mpg? And performance?
Old Oct 24, 2012 | 03:08 PM
  #1514
terrasmak's Avatar
Then keep the 245 up front and get a 265/40 for the rear.
No point of increasing the width stagger and making it understeer worse than stock.
Old Oct 24, 2012 | 03:59 PM
  #1515
scotts300's Avatar
scotts300
Best? DEPENDS.
Start reading and decide for yourself: https://my350z.com/forum/wheels-and-...ei-thread.html
Old Oct 24, 2012 | 04:11 PM
  #1516
03threefiftyz's Avatar
03threefiftyz
I only have about -2.5, run a +15 10.5" (in the front) and use a 315. I do, however, run a lot more spring and bar than probably anyone on this forum. That said, it only rubs on occasion (did cut a tire down when the car got airborne).
A 275 should fit no problem with low -2 (or more camber) on the front I would think.
Didn't even rub on high grip concrete (and the car was rolly as s__t)
Old Nov 5, 2012 | 02:41 PM
  #1517
Midnight_Slide's Avatar
Midnight_Slide
18x9.5 +15 up front with 235/35/18
18x10.5 +25 rears with 285/40/18
No rubbing at all. Just a lil camber /w fenders rolled.
Im waiting on my 255/40/18's for up front
Old Nov 5, 2012 | 03:05 PM
  #1518
TravisFTW's Avatar
TravisFTW
looks nice! . is that gunmetal color or sbc?
Old Nov 5, 2012 | 03:14 PM
  #1519
Bmurray350z
what suspension you on Midnight Slide?
Old Nov 7, 2012 | 03:42 AM
  #1520
350Zdj's Avatar
350Zdj
so much win in this thread. I'm gonna start saving up for a set of RPF1's now and have them professionally custom painted.
