FAQ: Official wheel "SPACER" thread!
Old Mar 26, 2012 | 04:05 AM
  #761
MantisMan's Avatar
MantisMan
Originally Posted by big_dish
Man, I dont know. I dont get it.
The ends of the bolts are pushing through all of the lugs, front and rear. I have no idea why.
I don't get it either....what are you trying to say with "the bolts are pushing through all of the lugs"??
Are the studs too long causing the OEM (closed end) lug nuts to bottom out and not tighten on the wheel?
If so....look back a few post where I had the same issue. Ordered some open ended lug nuts and that cured my problem.
Other than that, I'm not really sure what you're problem is without a better explanation.
Old Mar 26, 2012 | 07:15 AM
  #762
big_dish's Avatar
big_dish
That is what I mean, yes. They tightened them down to the wheel though, but the end caps are pushed out (you can see the bolts coming through the ends). They ordered some longer nuts, but at $4 per nut ($80 more dollars), I dont know if its necessary to switch them out, or just make sure they are always tightened against the wheel.
Not sure if this is a cosmetic thing or safety related, at the end of the day.
Old Mar 26, 2012 | 07:39 AM
  #763
MantisMan's Avatar
MantisMan
^ Are you running OEM lug nuts?
The OEM lug nuts are closed end, I don't see how the studs could be coming out of the ends
Pic....
Notice the ends on the lugs are closed....are these the same as yours??
Old Mar 26, 2012 | 09:08 AM
  #764
big_dish's Avatar
big_dish
Pic....
Yes I am, and you're right, they are closed end... the bolts are literally pushing the ends off.
I'll get a picture up here in an hour or so...
Old Mar 26, 2012 | 09:18 AM
  #765
MantisMan's Avatar
MantisMan
Yeah, would like to see some pics.
What you are describing seems almost impossible unless they were installed with a 3/4" impact. It would take some crazy amount of torque to pop the ends off of those lugs
But from the sound of it you probably need to pick up some new lugs. I went with a set of Muteki SR35 open ended in chrome ($60 shipped: ebay)......they match up nice with my stock rims.
Old Mar 26, 2012 | 09:25 AM
  #766
MantisMan's Avatar
MantisMan
Linky to the lugs I bought....
http://www.ebay.com/itm/ws/eBayISAPI...E:L:OU:US:1123
He has three sets available and they're still on sale!
Old Mar 26, 2012 | 10:27 AM
  #767
big_dish's Avatar
big_dish
Here is a picture with my iphones macro lens- its pretty close up so you can see the detail... This is one of the more drastic ones though, most of them you can just see the stress of the bolt- but they haven't pushed through.
I'm wondering if they did use an impact gun, I thought you werent supposed to do that with spacers though (unless that is just the spacer lugs, and not the actual wheel lugs).
I'll check out the ebay link too...
Old Mar 26, 2012 | 10:38 AM
  #768
MantisMan's Avatar
MantisMan
Wow, that's f*ckin' crazy!
And yep, I'm sure that was done with an impact and obviously over-torqued since I highly doubt 80 ft-lbs would cause that damage
I don't think I would trust driving around like that since you really don't know if the wheel is torqued to spec. Better safe than sorry and pick up some open ended lugs.
Old Mar 26, 2012 | 11:56 AM
  #769
big_dish's Avatar
big_dish
Yeah they already ordered new bolts, I'm not sure if I can wait for the ebay ones (although they are $40 less) to get here, since this is my daily driver. I may just go have them put the new ones on.
Do I need to make sure they dont use an impact gun this time (or is that only for the lugs that connect the spacer to the hub)?
Old Mar 26, 2012 | 12:05 PM
  #770
MantisMan's Avatar
MantisMan
If it makes any difference the ebay dude shipped my order the same day and I got them 48 hours later (USPS priority mail).
And I always tell the dealership/shops....NO IMPACTS.
And make sure they know the correct torque (80 ft-lbs)
Old Mar 27, 2012 | 06:05 AM
  #771
big_dish's Avatar
big_dish
Good deal.
So both the lugs that hold on the spacer, and the wheel lug should be at 80 lbs?
I thought it was just the spacer lugs, but figured the shop would know the correct info anyway.
Old Mar 27, 2012 | 06:25 AM
  #772
MantisMan's Avatar
MantisMan
Yep....80 ft-lbs for both the spacer nuts and wheel lugs.
Old Mar 27, 2012 | 11:42 AM
  #773
big_dish's Avatar
big_dish
OK cool, thank you
Old Apr 5, 2012 | 04:49 PM
  #774
freedonutss's Avatar
freedonutss
Default Ichiba V2 Wheel spacer install question
Quick question,
Im installing a set if Ichiba v2 15 mm wheel spacers on the rear of my car. The rear wheels are Axis Hiro 19x10.5 +35. Without the spacers the wheel goes on easy and bolts right up. When I installed the spacers with the hubcentric ring, the wheel doesn't want to go on all the way. I tried snuggling it on there but it wont budge. It only goes on about half of the way. I made sure the hubcentric ring was pushed in all the way against the hub. Any suggestions? Should I be installing the spacers without hubcentric rings?
Old Apr 5, 2012 | 05:01 PM
  #775
saywat?'s Avatar
saywat?
does ur wheels have the space in the back in between each lug hole? if not thats ur problem
Old Apr 5, 2012 | 05:04 PM
  #776
freedonutss
I forgot to add that part, yes they do have holes for that.
Old Apr 5, 2012 | 05:06 PM
  #777
saywat?'s Avatar
saywat?
then u probably gotta get wider spacers, i believe 20 or 25mm will sit flush on the hub, so its flush or cut off the length of the stud thats sticking out.
Old Apr 5, 2012 | 05:14 PM
  #778
freedonutss
Ah I see. Im not risking trying to force the wheel on by torqing the lugs down or running them without the rings so ill have these up for sale shortly.
Old Apr 5, 2012 | 05:21 PM
  #779
kevincat's Avatar
kevincat
are the hub centric rings the right size for center hub? also you might want to put the rings on the wheels first because sometime rust and oxidation will prevent he rings to seat properly.
pictures of what you are talking about would also help.
Old Apr 5, 2012 | 05:32 PM
  #780
freedonutss
I saw what it was. Saywhat? was right on the money. The wheel has holes in it for the factory studs but they arent wide enough so I saw where the studs were leaving marks inside of those holes. Looks like my only option is spacers with extended studs replacing the stock ones. Thanks guys!
