FAQ: Official wheel "SPACER" thread!
Old Apr 19, 2012 | 11:07 AM
  #801
sry110's Avatar
sry110
One thing I take issue with, and it's as much with the "name brand" spacers as it is with the "ebay" brands, is that everyone talks about "super high strength aircraft-grade T6061 Aluminum alloy blah blah blah" and nobody seems to talk about the grade (i.e. strength) of the pressed-in studs that ultimately hold the wheel onto the spacer in those high-lateral-force maneuvers. I would personally be more worried about whether the studs will fail in tension (or in torsion when tightening the lug nuts) than I would be about a flat aluminum plate cracking or bursting centrifugally.
Old Apr 19, 2012 | 12:24 PM
  #802
Waiz's Avatar
Waiz
Threads merged
OP you should really read/search in this thread there is a ton of good info
Old Apr 19, 2012 | 04:26 PM
  #803
sry110's Avatar
sry110
Just installed a set of adapter-type 15mm spacers tonight. I know that as a general rule, lug nuts should be re-torqued after driving 30 miles or so in case they have lost some torque (thermal, vibration, etc). So the question is: do the lug nuts that hole the spacer to the hub also require re-torquing? Seems like they would....but that's a pain in the *****, because you have to remove the wheel, torque the nuts, replace the wheel, torque the wheel lugs, then in another 30 miles re-torque the wheel lugs.
Any thoughts?
Old Apr 25, 2012 | 07:57 AM
  #804
sry110's Avatar
sry110
Any thoughts?
LOL nobody ever considered this aspect I guess?
Old Apr 25, 2012 | 08:25 AM
  #805
terrasmak's Avatar
Any thoughts?
Very easy way around this. If your running a 20mm spacer or less, it should be a slip on spacer. 25mm and larger, just buy different wheels.
Old Apr 25, 2012 | 08:41 AM
  #806
sry110's Avatar
sry110
I agree that the ideal situation is to have extended studs that accommodate the spacer thickness. In fact last year I did have a set of longer studs installed front and rear to accommodate 10mm spacers, but not 15mm spacers. With the 15mm spacers I was only getting maybe 7.5 turns on the lug nut until it was torqued, which is only 9.4mm thread engagement and I felt I should be getting at least 12mm (1 diameter's-worth) for proper seating. So my options were 1) buy set of longer studs and install them or pay to have them installed, or 2) buy a pair of adapter-type spacers. Option 2 is less expensive, less invasive and a quicker solution. Not ideal, but as long as the spacer is seated properly and securely to the hub, then I think it is an acceptable solution for my street-driven car.
Sorry, not trying to get defensive here, but my question was regarding lug nut seating torque and not whether my solution is the ideal one.
EDIT: I realize this was a standard terrasmak response. But there are enough people out there running adapter-type spacers, and I haven't found one person saying that they went back and checked torque on the spacer lug nuts. Therefore I think it's a valid discussion to have. What good is it checking the torque on the nuts holding your wheel to the spacer, if the nuts holding the spacer to the hub are about to fall off?
Old Apr 26, 2012 | 05:46 AM
  #807
MantisMan's Avatar
MantisMan
^ Not real sure what your question is....you pretty much answered it in your original post on the subject. The process you listed is exactly what I did after installing mine, and yes, it is a pain in the ***** but given the situation I thought is was the best option (better safe than sorry).
And just for reference everything was still fully torqued after checking them so not sure if it's completely necessary but it did give me some peace of mind.
Old Apr 26, 2012 | 07:05 AM
  #808
sry110's Avatar
sry110
You answered the question, thank you! I also expect they will be fully torqued when I check them, but the superstitious side of me says that if I don't check them, they won't be torqued.
I did give them a little extra nudge past 84 lb-ft just to be "sure", but I'm thinking this weekend I'll pop the wheels off and check it anyway.
[Side note: I knew the correct procedure was to pop off the wheels and check torque on the spacer hardware, but in all my searching I never saw anyone on my350z talk about it. I figured it was a worthwhile topic to put down in writing for everyone's edification.]
Old Apr 26, 2012 | 07:10 AM
  #809
MantisMan's Avatar
MantisMan
Lol...I did too
Old Apr 29, 2012 | 06:29 PM
  #810
gotmeaZ's Avatar
gotmeaZ
Default how would these wheel spacers go on????
how would these wheel spacers go on? am i not thinking hard enough or are you supposed to drill holes or what??
Old Apr 29, 2012 | 06:39 PM
  #811
beezee's Avatar
beezee
Those holes do not look like through holes unless the pics are not clear to me. And even if you drill through there are no reccess shamfers to make installation possible. What brand and size are those. Maybe I am not thinking hard as well
Old Apr 29, 2012 | 06:50 PM
  #812
mr. sparco's Avatar
mr. sparco
It's magic. OR just the angle of the picture.
Old Apr 29, 2012 | 07:14 PM
  #813
Phenom's Avatar
Phenom
Toasty
My guess is those are countersunk holes with an opening for the stud but the angle only allows you to see the countersink but not the opening.
Old Apr 29, 2012 | 07:20 PM
  #814
bmccann101's Avatar
bmccann101
oh dear god, they are conical lug seats.. they are simply taken at an angle where you cant see the holes.
you are all fired.. now go facepalm in private.
Old Apr 29, 2012 | 08:05 PM
  #815
Phenom's Avatar
Phenom
Toasty
Why are we all fired?
Old Apr 29, 2012 | 08:23 PM
  #816
bmccann101's Avatar
bmccann101
Haha looks like a thread got merged.... there was only 2 people in here when I posted haha.certainly wasn't the 40 page " spacers" thread
Old Apr 30, 2012 | 04:37 AM
  #817
Phenom's Avatar
Phenom
Toasty
Even just the people in the thread before, its not like everyone was wrong until you posted
Old Apr 30, 2012 | 07:06 AM
  #818
sry110's Avatar
sry110
Probably right, but the angle on that one hole (about 1 o-clock on the spacer to the right) looks like you should be able to see at least the edge of the thru hole, i.e. if you put your ruler on the screen and measure from the front face to where the color changes, versus measuring the entire thickness of the spacer at the same angle, it seems that there either isn't a thru-hole, or they drilled the hole too deep before machining the countersink.
Either way, when you've purchased spacers that thick, you've already purchased wheels that were 2" too narrow.
Old Apr 30, 2012 | 08:03 AM
  #819
Phenom's Avatar
Phenom
Toasty
This is a really good point.
Old Apr 30, 2012 | 09:29 AM
  #820
sry110's Avatar
sry110
Just an FYI for anyone in the market for spacers: I needed a set of 15mm adapter-type, hub-centric spacers and was about to purchase the Ichiba V2's from B2AutoDesigns in Florida. When I placed my order I found out the Ichiba's were out of stock, but they offered to sell me their own B2Auto brand spacers (which happened to be a few dollars less than the Ichiba). I figured I would take the chance and support a forum sponsor. Plus the parts shown in the photos B2 posted in their vendor classified thread looked promising.
Received the spacers a few days later and I was pleasantly surprised. The quality is as advertised (appearance-wise). The packaging is professional and the parts were in good condition. The construction appears to be of high quality and feels sturdy, i.e. clean machining work and studs pressed firmly into the spacers. My main concern is that the lug nuts supplied with the spacers, to hold them to the wheel hubs, are a bit of a thin-height design, and I was worried that torquing them to the factory spec (I do 84 lb-ft) would be too much. But B2 confirmed that it was an acceptable torque level so I went for it. After about 30 miles of driving I took the wheels off and checked torque on the spacer nuts, and they were still torqued to spec.
I would recommend these spacers as an alternative to the "name" brands out there. I'll keep an eye on them for how they hold up to weather, road grit, brake dust etc.
NOTE: If you end up buying these, you will need a 17mm thin-walled socket to secure the spacer lug nuts. The spacers do not come with any special installation tools since the lug nuts have a standard hex nut contour. You may need a deep socket since the nut is a bit thin and your stock studs will be protruding through the nuts. Do not use a standard 17mm hex impact socket because the wall is too thick.
I don't know who actually manufactures the pieces, but based on the installation instructions in the package it appears to be someone in Japan.
Here are some pics of the spacers as-received:
