FAQ: Official wheel "SPACER" thread!
Old Sep 23, 2012 | 03:09 PM
  #961
terrasmak's Avatar
5 to 10 mm up front and 10 to 15 in the back. I have 5 , 10 and 20mm spacers out the house for test fitting.
  #962
kingdom's Avatar
kingdom
Originally Posted by Tomato_Slicer
Dang, Didn't even need to ask a question. Gotta love these sticky threads.
Seriously. Very precise guide.
I dont know about the Z but it was a pain in the *** to remove the stock studs on an rsx I used to have.
So for the Z I went with 25s in both front and rear. Cant wait to set the car back down. I running stock suspension and wheels.
  #963
kingdom's Avatar
kingdom
I dont know about the 350z but getting anything smaller than 25mm was a pain in the *** to remove the stock studs on an rsx I used to have.
I just put on 25s. But Im on stock suspension. youd be mexi flush with the 25s
Old Sep 23, 2012 | 03:15 PM
  #964
~trtlespeedZ~'s Avatar
~trtlespeedZ~
ill keep that in mind because i might be interested in getting those HFC from you once i get my exhaust on.
Old Sep 23, 2012 | 03:18 PM
  #965
~trtlespeedZ~
LOL no mexi flush for me
Old Sep 23, 2012 | 03:24 PM
  #966
terrasmak's Avatar
As soon as I get the hardware kit for my PPE longtube headers the HFC's and DC headers will be off the car. As soon as I order from Z1 again I'll also have 15 mm spacers at the house. I want a full set for any wheel and tire combo in the future.
Old Sep 23, 2012 | 03:28 PM
  #967
mr. sparco's Avatar
mr. sparco
Lowered 3/4" when it thumped on dips. After roll I was able to lower it more and have a lot more flexibility with alignment, wheels, and tires.
Old Sep 26, 2012 | 10:53 PM
  #968
leekaa's Avatar
leekaa
Default Wheel spacing?
Okay so i just got my Z recently, and today i got it lowered. I love it, looks great. BUT, i feel like it can still look better.
I noticed, after dropping it, the wheels are kind of hidden under the body? Does that make sense? Like the fender comes out farther than the tires..I dont like that. Now my question is, is there a way to get the tires out further without making my tires all angled? I dont want the tires angled way out, i just want them pushed out so that they are EVEN under the fender.
You know how SUV's and truck people put their tires out farther than the car? thats what i mean. but obviously i dont want them way out, just even under the fender lining.
I'm sorry if this doesn't make sense, i hope it does. I'm just getting into cars and my knowledge is lacking. Help would be great..
Old Sep 26, 2012 | 11:24 PM
  #969
onesexyz's Avatar
onesexyz
Spacers will help, I have sustec springs and 20mm spacers all around and it looks very clean. The best option is to get new wheels with an aggressive off set but if you're on a budget like me, spacers are def a practical option. Just make sure they're make/model specific, not some cheap universal crap. As far as the camber issue, it's not enough to worry about. My tires haven't shown any signs of uneven wear in about 8k miles. Also helps to have non directional tires so they can be rotated if need be. Hope this helps. Also, with 20mm spacers you'll have to replace the lugs/studs with longer ones which can be a PITA, took me about 4 hours to get them on. Good luck and happy modding.
Old Sep 26, 2012 | 11:28 PM
  #970
leekaa's Avatar
leekaa
So if i were to follow your route, all i need is 20mm spacers and it will be even under the fender line?
And when you say aggressive off set, you mean tires that are wide? If i were to simply get wider tires would the HEIGHT of the tires fit and not rub against the fender?
Old Sep 26, 2012 | 11:38 PM
  #971
KingBaby's Avatar
KingBaby
Hardest Setting
https://my350z.com/forum/wheels-and-...er-thread.html
Old Sep 26, 2012 | 11:43 PM
  #972
leekaa's Avatar
leekaa
OH great! I didnt even know there was a section for this!
Thanks a lot guys.
Old Sep 26, 2012 | 11:52 PM
  #973
KingBaby's Avatar
KingBaby
Hardest Setting
there's a section for every single question you could come up with...
Old Sep 27, 2012 | 04:43 AM
  #974
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
Truth. It has been spoken in this place.
Old Sep 27, 2012 | 09:30 AM
  #975
tylerxfire's Avatar
tylerxfire
B2 1 piece bolt on spacers..they are a vendor
/thread
Old Sep 27, 2012 | 09:42 AM
  #976
Duckeee's Avatar
Duckeee
lol.
._.
assuming you're on stock wheels, get 20-25mm bolt on hub centric wheel spacers. done.
/threadx2
Old Sep 27, 2012 | 10:24 AM
  #977
bmccann101's Avatar
bmccann101
hahahaha.
Old Sep 27, 2012 | 10:39 AM
  #978
Daytondakid13's Avatar
Daytondakid13
Default Spacers spacers spacers
So just got coilovers and a new set of forged wheels. Now I planned on running spacers and some negative camber(I have camber arms all around) but once I got the wheels I realized they don't have the cut out holes in the back of the hub? So is it possible to run spacers? My last wheels had them, but these don't. Sooooooooo am I just sol on the spacer thing or what?
Old Sep 27, 2012 | 10:42 AM
  #979
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Spacers w/ extended studs.
Old Sep 27, 2012 | 10:48 AM
  #980
Daytondakid13
Does that replace the stock studs? To make them really long so I have enough to be safe and thread my lugs on?
