FAQ: Official wheel "SPACER" thread!
Old Oct 30, 2012 | 09:48 AM
  #1021
Moussa93's Avatar
Moussa93
Originally Posted by AllstarE4
Yes you'll need a camber kit with the Sportline springs to get it back into spec.
Thanks for answering again
Will this do the job: http://www.ebay.com/itm/72050-SPC-Re...0ae4d1&vxp=mtr
Old Oct 30, 2012 | 10:48 AM
  #1022
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
I would recommend doing a fender roll. Your wheel and tire selection will open up just a bit more and when it's done well you can't tell from the outside of the car.
Old Oct 30, 2012 | 11:08 AM
  #1023
Bmurray350z's Avatar
Bmurray350z
Those will do the job, yes
Old Oct 30, 2012 | 01:14 PM
  #1024
Moussa93's Avatar
Moussa93
Thanks for your answers guys, much appreciated
Old Nov 5, 2012 | 09:11 PM
  #1025
track04's Avatar
track04
Default Spacers Stuck on Hub
I have a set of 20mm H&R spacers on my rear hubs.
They are the ones with the extended studs installed and spacers slip on.
I cant get them off having tried a number of techniques, and penetrating oils.
There is nothing to grab on to but there are 10 holes.
5 for the studs to come through, and 5 more that are just there.
the 5 empty holes i am thinking of taping installing some bolts in them and using a puller to pull out.
Any simpler ideas?
Old Nov 5, 2012 | 10:03 PM
  #1026
GLRacing's Avatar
GLRacing
There are probably a few other ways to go, but if you have bad rotors, I would take this as an opportunity to change the rotors--what I mean is....take off the dang caliper and BANG AWAY AT THE ROTOR WITH A HAMMER! (but make sure your parking brake is off and have the front wheels chocked)
Old Nov 6, 2012 | 05:38 AM
  #1027
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
Get the thinnest flathead screwdriver or chisel you can find and wedge it between spacer and rotor and tap away. Is there any gap at all to do this?
Old Nov 6, 2012 | 05:43 AM
  #1028
taywan's Avatar
taywan
I've had similar issue. If u take the caliper off, u can wiggle the rotor off and it should push the spacer off. U sure u have the bolts holdin them on-off right? Jk.
Old Nov 6, 2012 | 08:22 AM
  #1029
terrasmak's Avatar
This and then a little antisieze on the hub when you install the spacer again
Old Nov 6, 2012 | 09:11 AM
  #1030
bmccann101's Avatar
bmccann101
strange that no one has reccomended the BFH.
(Not a normal one lol.. a BIG ONE. )
that kind of shock will budge more than you think lol.
BFH = BIG FKIN HAMMER.. usually soft edged plastic etc.
makes frustrating jobs like this one FUN. lol.
Old Nov 6, 2012 | 09:15 AM
  #1031
VMRWheels's Avatar
VMRWheels
+1
This is what I'd recommend doing as well.
Old Nov 6, 2012 | 09:21 AM
  #1032
SQuaLZ's Avatar
SQuaLZ
Hell yea use a rubber hammer it will come right off. I wouldn't use a screwdriver if you plan on reusing the spacer and rotor. Good luck and have fun!
Old Nov 6, 2012 | 09:55 AM
  #1033
track04's Avatar
track04
i tried a chisel between the rotor and spacer, cant get that to work
i have a dead blow hammer that i have hit the face with, cant get that to work
I think the easiest will be to remove the rotor and clamp the spacer in a vice
then ill have something (the rotor) to really grab ahold of
Old Nov 6, 2012 | 10:59 AM
  #1034
SQuaLZ's Avatar
SQuaLZ
Are you trying this in cold conditions? I remember I had a difficult time taking my buddy's wheel from his 3 series (damn bolts instead of studs and nuts) and I ended up just kicking the damn wheel multiple times until it came off. The coldness could have "seized" the spacer on.
If this is the case I would put it in the garage or something and wait.
Old Nov 6, 2012 | 11:00 AM
  #1035
SQuaLZ's Avatar
SQuaLZ
Heres another idea, why don't you not bolt the spacer to the rotor but put the wheel on and bolt the spacer to the wheel then pull the wheel off? Wouldn't that work?
EDIT: Sorry I thought they were bolt-on spacers. I would try leaving it in a garage overnight or something or even put a blowdryer on it then try to pull it off, or even warm water.
Old Nov 6, 2012 | 11:08 AM
  #1036
805350z's Avatar
805350z
I vote for BFH.
Old Nov 6, 2012 | 11:19 AM
  #1037
terrasmak's Avatar
Scratch that idea , the spacer is stick to the hub, not the rotor. If you can get the rotor off the spacer will have fallen of by then
Old Nov 6, 2012 | 12:31 PM
  #1038
SQuaLZ's Avatar
SQuaLZ
Correct me if I am wrong but I believe my spacer is against the rotor, not the hub. The rotor sits on the hub, with the studs holding the rotor in place. Maybe I am wrong, these damn financials at work are killing me. Only a few more days until normal work hours for me again. Life of an accountant, sigh...
Old Nov 6, 2012 | 12:46 PM
  #1039
MUZZY's Avatar
MUZZY
get a flathead sand it down to get a super thin shim and bang away with a hammer, work around to get it off. I just did it 2 weeks ago on another ride. You also need to be a MAN and not be like "ewww its too hard".
Old Nov 6, 2012 | 02:09 PM
  #1040
GLRacing's Avatar
GLRacing
No the spacer is probably "hubcentric" which means its pretty much fitted onto the hub. Like I said, start banging away on the back of the rotor and get them both off. Rotors are cheap cheap anyways.
