FAQ: Official wheel "SPACER" thread!
Old Dec 13, 2012 | 04:28 PM
  #1081
TheWoods's Avatar
TheWoods
No name spacers. Not hub centric. Oem 2006 base wheels.
Old Dec 13, 2012 | 04:32 PM
  #1082
installation's Avatar
installation
They make hubcentric rings for every size. Measure the bore, convert to mm and check ebay.
Old Dec 13, 2012 | 04:38 PM
  #1083
TheWoods's Avatar
TheWoods
Wrong.
They do not make 82.5 / 66.1
Even if they did, the spacer is too think. The bore is too tall, the ring wouldnt even make in into the rim.
But thats not the question in this thread.
Old Dec 13, 2012 | 04:47 PM
  #1084
Waiz's Avatar
Waiz
Get another set of spacers that already have the rings in them, problem solved
Old Jan 5, 2013 | 07:25 AM
  #1085
ocityf1nest's Avatar
ocityf1nest
I have one inch wheel adapters and I have never had any problem, alignment or any vibration. I track and drag my z. 04 track 19x9.5/10.5 +12 with one inch adapters.
Attached Thumbnails FAQ: Official wheel "SPACER" thread!-image.jpg
Old Jan 27, 2013 | 09:47 AM
  #1086
Edmonton 350z's Avatar
Edmonton 350z
55 pages of reading later....I bought my car used with 19x8 Axis Mod's on it, with 255 on the rear and 235 on the front. I know the wheels are the wrong offset for the car. I think the offset on the Axis is 40 rear, 35 front. I'm looking at the B2 spacers, hubcentric ring and studs already on. Will 20 front and 25 rear be enough spacer, or should I be looking for 30+ for the rears for a closer fit to flush? I can't measure right now, as it's got the 18" 03 Touring with winter's on. Stock ride height, won't be lowered. Thanks.
Old Jan 27, 2013 | 06:03 PM
  #1087
Diesel350's Avatar
Diesel350
Ichiba Quality at it's best:
http://www.clublexus.com/forums/is-s...2-spacers.html
http://forums.maxima.org/7th-generat...-not-safe.html
Old Jan 27, 2013 | 07:26 PM
  #1088
freddys 350z's Avatar
freddys 350z
if your gonna run spacers, do it right. i got ARP extended studs with z1 slip on hub centric spacers.
Old Jan 27, 2013 | 11:17 PM
  #1089
Edmonton 350z
I still need to run winters on the 18's so I don't want extended studs! That's why I want ones that include studs for the summers. Winters are only 225's.
Old Jan 28, 2013 | 12:46 AM
  #1090
freddys 350z
what do studs have to do with winter tires?
Old Jan 28, 2013 | 03:10 AM
  #1091
angelo350z's Avatar
angelo350z
Old Jan 28, 2013 | 07:02 AM
  #1092
terrasmak's Avatar
YOu will also be able to run your spacers with your winter wheels and tires.
Old Jan 28, 2013 | 08:21 AM
  #1093
Edmonton 350z
Any advice on the size with the wheels and tires I mentioned? I mentioned the winters as the wheels and tires are different sizes and I didn't want one set to look horrible and thought I may have to run winters without spacers then.
Old Jan 28, 2013 | 10:50 AM
  #1094
terrasmak's Avatar
Probably 25mm front and rear
Old Feb 4, 2013 | 10:20 AM
  #1095
User 42426's Avatar
User 42426
Default These are hubcentric rings right???
Hey guys,
Sorry for the noob question but wanted to make sure these were hubcentric rings that are supposed to eliminate vibrations when spacers are installed with aftermarket wheels. When i install the wheel on the rings/studs, the rings don't stay put. I can see them move since my center caps are off the wheels. I can literally push them in, and then pull them out with my finger in between the center cap hole. Is this normal? I don't see a point to the rings if they can move. Would this have anything to do with steering wheel vibrations at high speeds?
Attached Thumbnails FAQ: Official wheel "SPACER" thread!-imag0098.jpg
Old Feb 4, 2013 | 10:36 AM
  #1096
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
That is a hubcentric ring for the spacer, yes.
Old Feb 4, 2013 | 10:45 AM
  #1097
User 42426's Avatar
User 42426
^^Does it make sense that they move in and out while the wheel is installed?? I can stick my finger while the center caps are off and move the rings in and out. Doesnt seem like anything is resting on it or touching it. Doesnt that defeast the purpose?
Old Feb 4, 2013 | 11:10 AM
  #1098
AdvanZ33's Avatar
AdvanZ33
Since you can move the ring I assume you aren't mounting OEM wheels. The hubcentric ring pictured above makes the spacer hubcentric to the OEM center bore, but, if you are mounting wheels that have a different center bore than OEM your set up isn't fully hubcentric. You will need hubcentric wheel rings like these:
Old Feb 4, 2013 | 11:52 AM
  #1099
User 42426's Avatar
User 42426
Since I don't have that do you think that might be the reason for high speed vibrations?
Old Feb 4, 2013 | 11:58 AM
  #1100
AdvanZ33's Avatar
AdvanZ33
Hard to say. Doubtful if you are using the right lug nuts and torquing them correctly in a star pattern.
