To TPS or not to TPS......?
Old Feb 4, 2004 | 08:15 PM
Bassmaster's Avatar
Bassmaster
Default To TPS or not to TPS......?
Got a wild hair and bought some new wheels (Volk). Should I:
1) Go the extra expense and remove my stock TPS (provided I can find a shop who can do it) instal on Volk then sell my stock Wheels (Track with Toyo T1-S minus the TPS) and have no spares if I bend a rim?
2) Instal new wheels and Tires minus the TPS (cheaper) and save my stock Track wheels with TPS as an extra set, for the event that I can return the car to stock form when/if I sell it?
Thanks
Old Feb 5, 2004 | 05:32 AM
Static's Avatar
Static
You can still use your tps's.... here u go:
https://my350z.com/forum/showthread....0&pagenumber=1
Old Feb 6, 2004 | 02:15 PM
ChinaClipper's Avatar
ChinaClipper
Option #1. If you forego your TPS', you might grow tired of looking at the yellow warning light that comes on the dash after about 40-45 minutes of running without the TPS receiver getting any signals.
Old Feb 6, 2004 | 04:36 PM
Bassmaster's Avatar
Bassmaster
Yea, that would suck. I have gotton inconsistant reports on that light however. Some say it goes away after awile, some say it dosnt.
Old Feb 8, 2004 | 04:24 AM
szyp's Avatar
szyp
Default resetting the TPS
Does anyone know how to reset the TPS in the car itself once the wheels have been removed to be remounted, or is it a requirement to go to the dealer to have it done? Thanks.
Old Feb 23, 2007 | 03:56 PM
dc567's Avatar
dc567
+1
Old Feb 23, 2007 | 04:01 PM
redlude97's Avatar
redlude97
If you are using your stock tps sensors in the same location, then the light resets itself
Old Feb 23, 2007 | 04:57 PM
DavesZ#3's Avatar
DavesZ#3
If you take them out of the old wheels and mark which one they came from (LF, RF, LR, RR) then put them on the new wheels in the same location, then there's absolutely nothing that has to be done to keep TPMS working correctly.
You don't need a dealer to do that, any competent tire shop can handle the sensors. They're pretty common on newer cars so finding somebody who can handle them is not really a problem.
Old Feb 24, 2007 | 07:06 AM
Viffer35Z's Avatar
Viffer35Z
Bass, what extra expense is there to swap the TPS to the new wheels? I just ordered a set of Nismos and went to the tire shop who'll be putting on my Eagle F1's, and swapping the TPS is part of the deal. $1160 out the door for F1 Eagle GS-D3 tires (245/275 40-18)including swapping the TPS.
Old Feb 24, 2007 | 08:10 AM
bb1314's Avatar
bb1314
da Terminator!
Since you have the Nismo wheels, swapping the TPS is a no brainer. The TPS on your stock wheels are part of the valve stem. So just take out the TPS from the stock rims and put them on the Nismo rims like a regular valve stem. There's no magic to it and they shouldn't charge you an extra buck for it. Well.. they will have to dismount the tires from your stockers to get the TPS out. Just need to make sure they label the TPS (Front Right, Front Left, Rear Right, Rear Left). It's not fun if they're mixed up...
Old Feb 25, 2007 | 06:31 AM
Viffer35Z's Avatar
Viffer35Z
Yes, I will certainly make a point of this to the tech who swaps the tires out for me. I've heard this many times...if done right, you don't even have to recalibrate the TPS.
ChrisMCagle
Sep 1, 2004 11:54 AM
onecoolee
Jun 21, 2004 02:57 PM
zeroday
Jun 1, 2004 10:58 AM
Z391
Apr 23, 2004 07:00 PM
