My $100 like OEM fit NAVIGATION setup
Agreed with quakerroatmeal.
I would like to ask a question regarding the map loading of OCN8 software. For some reason, it takes at least 20min to load map whenever I turn the unit on. I have my antenna installed inside the cluster, below the gauges. I'm not sure this causes the issue.
Thanks guys.
Thanks guys.
Thanks guys.
Thanks guys.
Sorry for not making the question clear.
I don't have any problem with loading screen because I have all the POI's deleted except Texas, Oklahoma, and Lousiana. Ok here is what i did.
- Turned on the unit
- Selected Navigate (Nissan logo loaded, OCN8's main screen loaded)
- Selected Map which is on the bottom
The cursor didn't pickup the signal for the current location until 20min or maybe longer.
i only have POI from three states. I reside in NY and only have POI of NY, NJ and CT. My ocn8 loads up fast and is very responsive and GPS signal is usually at full bar already or takes couple seconds to catch signal.
Thanks to the great dvd and a little help from 3three5five0zero. His dvd made this a breeze...
When i quit the nav a cannot find file or something pops up. Any fix for this?
Anyone have a pic of where to run the power cable. i have an o5. would i use the front cigg lighter to cut into or run it ll the way to the back.
Also a pick of the gps antenae mount behind the cluster?
im a total noob to wiring.... any help is appreciated.
Tap into the back of your cig lighter on the passenger side. Red is positive, black is negative. This is nice because it will power on and off with the car.
For the antenna, just pop off the plastic piece behind the gauge cluster. You'll have to pop off your center console first. There is a little pocket right behind the tach that is perfect for the antenna. This is where I have mine mounted and it works great. Sorry I don't have a picture.
Glad I could be of help.BTW, the errors are inevitable. Keep in mind that with each error, your error log text file gets bigger. Most of us should have the 2 GB memory card with ample amount of free space left (if poi, map, lang, etc were erased). However, as it does fill up the total capacity in increments, you will want to delete these files every once in a while. It's titled "crash" or something to that effect.
It's relatively accurate for most applications, I believe. I took a small trips here and there (no farther than a 80 min drives or so). However, if your area has had recent major road constructions where the layouts change, you'll experience some discrepancies there. Unfortunately, the roads around where I live are full of these new roads, but for most roads you should be fine.
