My $100 like OEM fit NAVIGATION setup
Old Oct 23, 2010 | 03:13 PM
  #481
kihun's Avatar
kihun
After that error sign, i deleted all my previous files on sd card and re did the whole thing and now, i can't even press on navigation button. it's greyed out.
Old Nov 10, 2010 | 12:13 PM
  #482
ColecatZ's Avatar
ColecatZ
I have had this installed for a while now, but I have one question... how do you route the antenna over behind the guage cluster.... maybe I'm tarded but the dash section seemed a bit dense and I didn't see the method of removal/jurry riggin it.
Thanks in advance.
Old Nov 13, 2010 | 02:52 AM
  #483
Lefix's Avatar
Lefix
Can someone please tell me if this monitor has one or two video inputs?
Thank you
Old Nov 16, 2010 | 06:28 AM
  #484
06blueZ's Avatar
06blueZ
both the plenio and the magellan 1700 have one video input.
Old Nov 30, 2010 | 06:40 PM
  #485
VanDamme22's Avatar
VanDamme22
I recently bought a used Plenio VXA-2100 off of eBay for $89.95, but the seller did not include the remote (no so big of a deal) or the external antenna (a very big deal).
The seller tried to tell me the newer units did not require an external antenna and that Plenio switched to internal antennas for the VXA-2100.
I knew from this thread that the 2100 needed an external antenna to work and of course when I tried the unit, it did not pick up a GPS signal.
I sent the unit back through ebay buyer protection (another $20 out of pocket) and the seller said I took the unit apart and removed the warranty sticker (whatever that means) and that he would not refund my money. I returned the unit exactly as I received it.
I've been looking for a 2100 for a long time and it has been a disappointment that this one did not work.
I thought I would share my experience to warn any others that might buy a unit from ebay. The seller's ebay username is hamilton1870. Not trying to bad mouth anyone, just want to take care of my fellow Z drivers.
I'm still trying to decide if I should wait for another 2100 to pop up or get the Magellan 1700.
Old Dec 14, 2010 | 06:37 PM
  #486
06blueZ's Avatar
06blueZ
definetly get the Magellan 1700. I have been using it for about 4 months now, and havent had one issue. it gets a gps lock very fast, had great support with firmware and map updates, and is just overall much higher quality. its worth the extra cost because once its in there, its a pain to get it out to fix or tweak, and i had to do that more than once with the Plenio. It froze, sometimes the screen wouldn't come on, gps wouldn't get a fix, etc... Dont bother finding and modding the plenio.
get the Magellan, or you could also look into some of the new 7" android tablets that are coming out...
Old Dec 17, 2010 | 09:57 PM
  #487
VanDamme22's Avatar
VanDamme22
Thanks for the recommendation. I just bought another Plenio 2100 on eBay (before reading your post) which is what made me come back to this thread.
Yeah, an Android tablet would be awesome. I have a Droid phone and really like the Android system. If I have any problems with the Plenio, I'll look into the tablets.
Thanks again, 06blueZ.
Old Jan 8, 2011 | 11:23 PM
  #488
Lefix's Avatar
Lefix
Thank you all for the contribution, I got one from eBay and it's working great! Took a few tries to get it working but it's totally worth it. One of the best mods for the money.
Old Jan 17, 2011 | 01:52 PM
  #489
kihun's Avatar
kihun
this ****ing pos navi stopped working. it was working well and one day it decided to give me error. so i reinstalled new map but now navigation button is greyed out. i can't click on it. wtf am i suppose to do now?
Old Jan 17, 2011 | 01:57 PM
  #490
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
^ Doesn't that mean that the system can't detect a navi program? You can buy mine.
Old Jan 25, 2011 | 06:45 PM
  #491
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Originally Posted by Kwame@z1Auto
If it has an audio out why don't you just hook up an amplified center channel speaker to it and hide the speaker in the footwell somewhere?
To accomplish the same thing in the past for navigation or ham radio, etc. - I just purchased a 4 channel (2 stereo sources) mix board (like a DJ would use) that you can get for $50-$100. Then I ran my front left and right pre-amp outputs to 2 channels, and my other audio source (navigation, etc.) to the other 2 channels. I set the sound levels for the navigation to what sounded appropriate, and then I ran the output from the mix board to the amplifier. This way, it's all coming out of the same speakers and it is just mixing the audio together.
I've used this same setup for my past 3 vehicles, and it is a great way to do it if you have pre-amp outputs and amplifiers.
Old Apr 2, 2011 | 02:32 AM
  #492
sssmasss's Avatar
sssmasss
is there anyway i can update the map? it made me turn right when the new sign said one way going left. I almost got into an accident. thanks
Old Apr 5, 2011 | 10:58 AM
  #493
sssmasss's Avatar
sssmasss
bump bump!!
Old Apr 9, 2011 | 08:22 AM
  #494
o2sys's Avatar
o2sys
Originally Posted by sssmasss
bump bump!!
Buy the latest OCN map...that's the only way now.
Old Apr 9, 2011 | 12:54 PM
  #495
sssmasss's Avatar
sssmasss
that's suck
Old May 13, 2011 | 08:25 AM
  #496
VanDamme22's Avatar
VanDamme22
Duplicate
Old May 13, 2011 | 08:26 AM
  #497
VanDamme22's Avatar
VanDamme22
I'm wondering if someone would be so kind as to give a little bit more detailed of an instruction set for the unzipping and transferring of the files downloaded from Megaupload.
Since there is a Part 1 and a Part 2 to the SD card download, I'm a bit confused as to how to merge the files into 1 complete set when unzipping. Since both Part 1 and Part 2 contain different files within the same folder names, I think there may be some issues with needing to replace the "existing" files (from Part 1) with the "new" files (from Part 2) when you unzip Part 2 to the same location that you have just unzipped Part 1. I went ahead and said "Yes to All" when prompted to Replace any duplicate files/folders, hoping for the best.
When I add the CONTENTS of the SD card file from the unzipped download to the SD card that came with the Plenio, my navigation button is greyed out when I start the unit up. (I remember reading greygooser151's post #400 on page 20 of this thread about the contents rather than the actual "SD card" folder, but I still have the same problem even after following his advice.)
Also, after extracting all the files, I still have some folders that remain as zip folders within the OCN8 folder; namely the "branding" and "data" folders.
Can anyone verify that there should be the following transferred to the Plenio SD card:
-MobileNavigator folder with a C31 file and an application file within
-OCN8 folder with numerous files and folders within (12 total items)
or have I done something wrong with the unzipping?
Thanks in advance.
Finally, I had some trouble getting the files to download from Megaupload and I will post my solution when I get a chance in case anyone else runs into the same problem in the future.
Old Jul 21, 2011 | 05:12 PM
  #498
MI 35th's Avatar
MI 35th
OGPremierMafia
Just completed this mod for $75 bucks! Thanks for the post. This looks and still works great.
Old Jul 22, 2011 | 10:36 AM
  #499
ColecatZ's Avatar
ColecatZ
... its a pain to get it out to fix or tweak, and i had to do that more than once with the Plenio. It froze, sometimes the screen wouldn't come on, gps wouldn't get a fix, etc... Dont bother finding and modding the plenio....
Thanks for disclosing all that before you sold it to me....
Old Jul 22, 2011 | 11:11 AM
  #500
MI 35th's Avatar
MI 35th
OGPremierMafia
Colecat, Ive ben messing with mine for a little while before finally installing it.
Its comes down to how you have it modded. You don't need all the states' POIs delete the states you won't ever use, which for me is everything west of illinois
If you need some help let me know. It only freezes due to older CE tech trying to run a more advanced NAV system. if you have OS 1.62 stick to a 2gb SD if you have 1.64 get a transcend 133 4gb card. either way its not a $1500 nav, although for me it works better than the OEM and looks badass in the car.
