New NASA Class for 2012: Spec Z
Old May 2, 2012 | 03:28 AM
  #681
laze1's Avatar
laze1
Thnx Mike, but the plan is to purchase new stub axles, so I am not freaking out yet, as I still have time before my 1st race @ Road Atlanta June 15-17..
I will see if they can send me pics...
I appreciate your concern. !!
Old May 2, 2012 | 03:49 AM
  #682
terrasmak's Avatar
Please post pics of the stubs , also look at my thread about the stub shafts slipping out. You can see the machine work that needed to be performed. Pretty simple and cheaper than buying stubs.
Old May 2, 2012 | 04:51 AM
  #683
laze1's Avatar
laze1
PM sent..
Old May 2, 2012 | 06:35 AM
  #684
laze1's Avatar
laze1
Good stub axle pix from Wavetrac
Pics of my 2007 base model open diffs stub axles
Old May 2, 2012 | 12:23 PM
  #685
terrasmak's Avatar
https://my350z.com/forum/engine-and-...-pull-out.html just a quick and easy cut from being able to accept a snap ring like the other one.
Old May 3, 2012 | 08:47 AM
  #686
laze1's Avatar
laze1
new stubs axles (2) in-the-house now...
Old May 3, 2012 | 08:53 AM
  #687
laze1's Avatar
laze1
terrasmak...I think we have 2 separate problems...
My issue is that the axles will not slide completely into the WaveTrac diff...so the clips don't even com into play...the stub axles are too long...they are hitting something inside the Diff...
http://www.wavetrac.net/technical.htm
Old May 6, 2012 | 10:00 PM
  #688
DFW Z33's Avatar
DFW Z33
I am salad
I was reading the NASA Spec Z rules pertaining to interior modification, and it seems like weight reduction is allowed up until section 18.2j that states
"j) Other than to provide for the installation of required safety equipment or other authorized modifications, no other driver/passenger compartment alterations or gutting is permitted."
Soooo does this mean you cant remove all the plastic asthetic stuff in the cabin or not? Im confused. Anyone know what the official standing is on this?
Old May 6, 2012 | 10:49 PM
  #689
Voboy's Avatar
Voboy
Laze, I bet it was just an issue of shaving/trimming down the stub axles, much like the Quaife requires you to do as well:
https://my350z.com/forum/engine-and-...tub-axles.html
The Wavetrac picture just looks like a shortened version of an OEM stub axle aka base model open diff stub.
Old May 7, 2012 | 06:57 AM
  #690
terrasmak's Avatar
Yup, it seems like yours needed to be cut for the c clips and the length shaved down to the VLSD short stub length.
Old May 7, 2012 | 04:32 PM
  #691
laze1's Avatar
laze1
The C-clips are fine, that is not the problem...the length of the axle is the problem
you need Qty of 2x VLSD short "un-modified" Axles and it fits perfectly!
Old May 7, 2012 | 09:24 PM
  #692
SE5spd's Avatar
SE5spd
I needed to have my open diff 07 stubs to be shaved down for my os giken unit as well.
Old May 7, 2012 | 10:15 PM
  #693
scotts300's Avatar
scotts300
3 sets almost ready for SpecZ (six 9s and six 10s). Just need to get the silver ones painted black, then get the rest of the tires mounted up.
Old May 8, 2012 | 03:01 AM
  #694
laze1's Avatar
laze1
So, you are the one who scarfed up all the 18x9 RPF1s in the entire world???
Question: What offsets are you running?
Old May 8, 2012 | 08:01 AM
  #695
scotts300's Avatar
scotts300
All were used!
+35 on the 9 and +38 on the 10.
Old May 8, 2012 | 05:41 PM
  #696
laze1's Avatar
laze1
Are you sure the 18x9s are ET 30???
I can only find 18x9s ET35 new...
And what spacers are you running?
Old May 8, 2012 | 05:59 PM
  #697
03threefiftyz's Avatar
03threefiftyz
They are +35's. Scott bought the last set I had...
Old May 8, 2012 | 09:31 PM
  #698
scotts300's Avatar
scotts300
I knew I should of looked first. Sorry fellas!
Old May 9, 2012 | 02:00 AM
  #699
laze1's Avatar
laze1
thnx!
Old May 10, 2012 | 07:25 AM
  #700
dkmura's Avatar
dkmura
General & DIY Moderator
Nissan Motorsports just announced a bonus contingency payment for any NASA Spec Z races in June and July. No matter the number of entries or finishing position, Spec Z racers are eligible to make an additional $100 above and beyond the usual contingency.
