ST/SU Build
Old Jan 9, 2016 | 06:26 AM
  #181
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Originally Posted by Dblock55
My neighbor signed for this, he said he had to think twice when he saw the box
LoL signed for your terrorist starter kit today, dont expect me to hold your body up and walk the streets if you get shot though...
http://toprightnews.com/at-this-fune...mething-video/
Old Jan 9, 2016 | 09:11 AM
  #182
Dblock55's Avatar
Dblock55
Haha thar is hilarious.
Old Jan 9, 2016 | 04:14 PM
  #183
Dblock55's Avatar
Dblock55
Parts 2
Old Jan 10, 2016 | 01:53 AM
  #184
armt350z's Avatar
armt350z
So is all of your glassing done by hand laying? Have you though about vacuum resin infusing, or is there a reason you don't?
Old Jan 10, 2016 | 06:51 AM
  #185
Dblock55's Avatar
Dblock55
This is only the second thing I've ever built with fiberglass so I'm fairly new to it. Laying by hand is relatively simple and yield nice results that only require a little bit of touch up if done properly. Vacuum infusion looks amazing but twos a significant investment. After the hood I don't think I'll be gassing anytime soon.
Old Jan 10, 2016 | 07:43 AM
  #186
90nissanS13's Avatar
90nissanS13
You've been showing some nice work with your airfoil, if you have a diy process for vacuum forming, you should share.
If not, im sure we could come up with a cheap and effective method with a shop vac, garbage bag and some other parts.
Old Jan 10, 2016 | 10:32 AM
  #187
armt350z's Avatar
armt350z
I'll detail the vacuum infusion from a mold when I get to that point . I'm also going to try vacuum infusion around a formed part to see if it works. At a previous job all we did was vacuum infusion.
I've got a vacuum pump, I still have to make a resin pot. None of which is cheap unfortunately.
Old Jan 10, 2016 | 02:46 PM
  #188
Dblock55's Avatar
Dblock55
Plenum spacer installed... little bit of oil pooled up in lower plenum, anyone experience this?
Old Jan 10, 2016 | 02:58 PM
  #189
armt350z's Avatar
armt350z
Its common, part of the pcv system process.
Old Jan 10, 2016 | 03:56 PM
  #190
90nissanS13
Yup, that is totally normal. It's a good idea to run a catch-can if you want to prevent the oil build up.
Old Jan 11, 2016 | 10:06 AM
  #191
Dblock55's Avatar
Dblock55
Shouldve gone for that drive... got snow last night and more on the way
Old Jan 11, 2016 | 04:49 PM
  #192
90nissanS13
When an opportunity presents itself, you take it.
It was sunny and 68 degrees today, I sat outside and day dreamed. It was nice.
Old Jan 13, 2016 | 04:36 PM
  #193
Dblock55's Avatar
Dblock55
Lift showed up today
Old Jan 13, 2016 | 06:19 PM
  #194
90nissanS13
Niceee
Old Jan 17, 2016 | 05:01 PM
  #195
Dblock55's Avatar
Dblock55
Lift is up and running... working on raising garage door now so it can go full lift... this is good
Old Jan 17, 2016 | 05:30 PM
  #196
90nissanS13
Can you set a limit switch for the lift?
Old Jan 17, 2016 | 05:52 PM
  #197
Dblock55's Avatar
Dblock55
You can but the whole point of lifting the door is to get the car up higher... right now it doesn't get too high... no point of having a lift and still having to crawl lol
Old Jan 25, 2016 | 05:14 AM
  #198
Dblock55's Avatar
Dblock55
Swapped the flywheel yesterday, pilot bushing looked like its seen better days so pulled and swapped it. Input shaft bearing needs to be replaced I think... end play is ok but has a d event amount of side play. The FSM doesn't specify a value for side plsy, only end play... I'm guessing this means there should be no side play? Weird thing is its not notchy when you turn the shaft by hand like other bad bearings I've dealt with. Can anyone chime in on the side play?
Old Jan 25, 2016 | 05:18 AM
  #199
Dblock55's Avatar
Dblock55
https://youtu.be/DTBGcut4P0A
Link to a video
Old Jan 25, 2016 | 08:15 AM
  #200
90nissanS13
The input shaft bearing is most likely bronze. Its "fragile" but has an ideal wear resistance. If you even bump it with the input shaft, it is trash.
Im almost certain the input shaft with it's wobbly run-out is normal. I noticed it 50k miles ago and then did another clutch ~30k miles after that and there was no change. It hasn't caused me any trouble at all. I assumed the shaft is on a spherical bearing.
It seems like other's have encountered this as well.
