Suspension 101
Old Jan 8, 2011 | 09:08 AM
  #321
JasonZ-YA's Avatar
JasonZ-YA
^ yes of course.......i mention this back in the beginning......post 21, 4th pic down.
3 degree SPC bolt kit - 30 bucks
http://www.importpartspro.com/spcretoadbok.html
SPL pro midlink - $655:
http://www.splparts.com/SPL_RML_Z33.html
then plus lock out washers... + $30??
see, the thing is, everyone buys the spc bolts....LoL...
-J
Old Jan 8, 2011 | 09:10 AM
  #322
WhosRich's Avatar
WhosRich
Holy cow those midlinks are expensive.
Old Jan 8, 2011 | 09:13 AM
  #323
beezee's Avatar
beezee
No kidding!
Old Jan 8, 2011 | 09:19 AM
  #324
Gsedan35's Avatar
Gsedan35
Originally Posted by beezee
I just installed the D-Spec Shock/Spring combo on my 05 Touring.
I have 19s 9.5 with 245/35/19 front and 10.5 with 275/35/19 rear. Car is still waiting
for the first test drive after the D-Spec install because it is stored for winter. I have the SPC camber and toe kit waiting for installation after everything settles. Now after reading about all the slip stuff with the toe bolts, I am tempted to just install
the camber arms first, go for allignment and see if I can live with the toe. Is this something you would consider if it was your car? Thanks
With over 120K on the clock and a ton of different setups run, over roads that can offer plenty of bumps and inpacts. I have never seen the oem or SPC toe cam bolts move,..........EVER. And I mark the washer and subframe together so I'm not guessing. So install the toe cam bolts from SPC and get the toe the way it's supposed to be.
Old Jan 8, 2011 | 09:29 AM
  #325
JasonZ-YA's Avatar
JasonZ-YA
I have seen them move......i think your's don't because of your knowledge on alignments and you probably doing it yourself?????
I have seen crappy alignment techs over power the "flat", due to not loosening the nut side enough.....if any of these Daily driver guys are dropping their car off at alignment and sitting in the waiting room then they are not ensuring the trailing cam bolt is following the head cam bolt???
I mention all of this earlier on (post 19 - during alignment this is what should be done comment).....where i talk about what you should be doing while your car is being aligned....watch them do it..ensure the trailing cam is following the bolt head side cam...
-J
Old Jan 8, 2011 | 09:37 AM
  #326
beezee's Avatar
beezee
Interesting. I guess I would have to find a place where they will alow me under the car
to ensure this. In most cases due to safety reasons, customers are not allowed in the work area
Old Jan 8, 2011 | 09:39 AM
  #327
JasonZ-YA's Avatar
JasonZ-YA
^ yep.......exactly, it can be frustrating at times....ive been lucky enough to talk my way back and now they all know me and welcome me, its no biggy now..
its just that due, to the issues that can happen, its best to be there, have a good understanding of what exactly is being done, and ensure the alignment is being done right...
-J
Old Jan 8, 2011 | 09:53 AM
  #328
beezee's Avatar
beezee
At the least I will explain the situation to them and see if they even understand.
That will determine if I stay there or go somewhere else. Like you said, GSedan35 is so knowledgeable in suspension, he will catch any screw up right away and it sounds like
there would be no slipping if done right
Old Jan 8, 2011 | 10:02 AM
  #329
JasonZ-YA's Avatar
JasonZ-YA
Ya in general i the 3 degree bolts aren't made well....if the slots/doctors pill in the subframe are not dremeled and are not opened up well, then the alignment tech is giving all his might to fight the eccentric past the raised flats in the subframe...
I attribute that issue to those following the "protocav spc bolt install" he states that all you need to do is elongate the doctors pill to the inside only...and this is true, but if the alignment tech doesn't know you did that, then he fights to turn the eccentric all the way around versus going back the opposite way, then he is prematurely fugg'n everything up....
then, plus, the alignment tech is watching the screen, not constantly checking to ensure the trailing eccentric is following...........
PLUS ~~~ the trailing cam/eccentric isnt on "shank" of the bolt...its being pushed around with the "threads" of the bolt......its to easy for it to be fugged up and the cam "flat" over powered...
The weak tolerance on the cam cut out is horrible too...the 5 degree bobble is horrible...
In general, they kinda suck, but they are a low cost toe adjustment for the Z....
-J
Old Jan 8, 2011 | 10:13 AM
  #330
beezee's Avatar
beezee
Too many factors involved. No wonder a lot of guys go for moderate drops to avoid having to worry about all these. On the bright side it provides a learning curve to understand how all these litlle pieces play their roles to make up a working suspension
Old Jan 8, 2011 | 10:51 AM
  #331
WhosRich's Avatar
WhosRich
Anyone know how much I should expect to spend on a coilover and front/rear camber set up? Trying to price out a budget.
Old Jan 8, 2011 | 11:10 AM
  #332
beezee's Avatar
beezee
That will be difficult for anyone to do. Wide range from around $1000 all the way up to over $3000. Depends on what you want. Lots of discusions on this. Spend sometime in the market place, search the suspension area for tons of threads about this and make a decision
Old Jan 8, 2011 | 11:18 AM
  #333
exarmyguy's Avatar
exarmyguy
-J
This is exactly why I would rather buy the SPL rear mid links with lock bolts instead of having the toe bolts. Ya, you may pay 500-600+ bucks for them, but I would rather have piece of mind driving hard at the track if I so desire knowing that I won't have toe bolts that can "slip" and my alignment goes kaput.
Old Jan 8, 2011 | 11:35 AM
  #334
WhosRich's Avatar
WhosRich
Oops, I meant how much I should spend on the install. I've read as low as 240 and as high as 400.
Old Jan 8, 2011 | 11:57 AM
  #335
exarmyguy's Avatar
exarmyguy
I installed mine myself, and trust me I'm no mechanic. You just need some basic tools, jack stands, jack, ect. I didn't even need a spring compressor to get the front strut/spring out. There is a DIY thread on here. If you do take it somewhere, I'm going to guess they would charge you atleast 3-4 hours labor.
Old Jan 8, 2011 | 02:34 PM
  #336
beezee's Avatar
beezee
Exactly. Just read through the DIYs on spring installs. You would end up doing it better than paying someone to half-**s it. Besides, it is always fun to work on your car. The first time might take you hours but from then on, you can do it in less than half the time. I suggest you enter the Spring install threads and ask any questions. More info there on that topic
Old Jan 30, 2011 | 06:30 AM
  #337
mikeyfosure1's Avatar
mikeyfosure1
Default stock suspension worn out
Looking to replace worn out stock suspension.
I drive it hard on the street. Getting wheel hop so 1st step is installing solid diff bushings and while I'm at it I want to swap in some new support.
Not really interested in a 1 inch drop. Minor drop is okay. Just want slightly stiffer over stock.
What are my best bets?
Thanks
Sent from my HTC Incredible.
Old Jan 31, 2011 | 10:09 AM
  #338
JasonZ-YA's Avatar
JasonZ-YA
^ many spring options to choose from.........shocks i would replace at least with monroes or go for something adjustable...
https://my350z.com/forum/8293479-post10.html
-J
Old Feb 10, 2011 | 07:14 PM
  #339
carlili4190's Avatar
carlili4190
Jason- I have 3 suspension choices right now and can't decide. Right now I have GF210's spring with stock shocks. I am getting rid of them. I am looking at getting
KW Variant 2
Tanabe Pro 5 w/Teas
Tein w/ EDFC(Probably flex)
This is all strictly for daily driving. I don't want anything that is much harsher then the GF210's. What do you recommend?
Old Feb 11, 2011 | 04:17 AM
  #340
JasonZ-YA's Avatar
JasonZ-YA
KW Variant 2
Tanabe Pro 5 w/Teas
I have driven a 350z with GF210s........so I semi know whats thats like....
as for being an expert on telling you what to choose, i would be lieing to ya...I have never been on any of those 3 choices you listed.....
From doing a quick search, and not knowing what ride height you want.....ie, im guessing a low ride height since you had the GF210s......?!!??!
My guess would be the KW, then the Tanabes, but i dont seem to trust the manufactures web site general notes....i like to see actual pics of the actual units for the 350z to see how they are constructed and then look at spring rates, etc...
The cabin controlled dampening, etc.......loose that idea....its moot...heavy and pointless...
-J
