building a n/a monster
Old Sep 8, 2006 | 07:38 AM
  #81
Motormouth's Avatar
Motormouth
didn't bigbri rev to 8k with a built TT motor? that is pretty crazy.
what's the highest someone has raised it to on a stock internal motor so far? 7200?
Old Sep 8, 2006 | 07:47 AM
  #82
Audible Mayhem's Avatar
Audible Mayhem
My350z
a few people had their stock rev limiters at 7500 for a while but i would never recommend that. i had mine at 7200 with no problems.
Old Sep 8, 2006 | 07:53 AM
  #83
Motormouth's Avatar
Motormouth
why would you not recommend it? fuel/timing or component speed?
Old Sep 8, 2006 | 09:06 AM
  #84
ct350z's Avatar
ct350z
my rev limiter is at 6800, the engine stops making power after that n/a atleast!!!
Old Sep 8, 2006 | 09:25 AM
  #85
Quamen's Avatar
Quamen
Big Bri is revving to 8200 I believe and making power the whole way with his setup at a massive 22psi if I am not mistaken!
Old Sep 8, 2006 | 10:03 AM
  #86
blasian's Avatar
blasian
Check some dyno's and you'll see that the power drops after 6ish grand.
Old Sep 8, 2006 | 10:23 AM
  #87
chimmike's Avatar
chimmike
that and on non-revup motors, the rod bolts simply won't hold up on stock rods. ARP rod bolts would help a lot, but after 7200rpm or so you need a new valvetrain anyways IIRC.
Old Sep 8, 2006 | 10:52 AM
  #88
Motormouth's Avatar
Motormouth
but what if you are running headers, etc. and have the flow to back up an increased rev.... also, the point isn't the power after only, it's when you shift to stay in the powerband more. if you raise it just a few hundred, when you shift you can stay higher in the power. but it all depends on the powercurve I guess. when i had headers/testpipe there was a noticable gain after 4100 or so. also taht damn fuel cut is SO annoying if you are a second late ; )
Old Sep 8, 2006 | 11:02 AM
  #89
chimmike's Avatar
chimmike
that all doesn't matter, the cams basically dictate where the power is made.
Old Sep 8, 2006 | 11:03 AM
  #90
blasian's Avatar
blasian
but what if you are running headers, etc. and have the flow to back up an increased rev.... also, the point isn't the power after, it's when you shift to stay in the powerband more. if you raise it just a few hundred, when you shift you can stay higher in the power. but it all depends on the powercurve I guess. when i had headers/testpipe there was a noticable gain after 4100 or so.
I don't think its so much of that. Even FI'd people are experience a dip in power after that same area if I'm not mistaken.
I don't think it would help staying in a powerband where you are losing power. Especially if it were a range from 6.2k-7.5k. It could help in first gear I'd imagine, but beyond that I think it wouldn't accelerate as fast.
I'm sure someone else will chime in.
Old Sep 8, 2006 | 11:10 AM
  #91
Motormouth's Avatar
Motormouth
hmmm... good point. still, getting rid of the hard limiter is a good thing.
Old Sep 8, 2006 | 12:55 PM
  #92
FastZ33's Avatar
FastZ33
hurry up already i wanna see this beast of urs
Old Sep 8, 2006 | 01:03 PM
  #93
sq40's Avatar
sq40
He said he was hopping to have it done today from his post at 8Am. Hope it all went well.
Old Sep 8, 2006 | 01:14 PM
  #94
doskiez's Avatar
doskiez
Good luck on getting it finished cant wait to see what it will do
Old Sep 8, 2006 | 01:19 PM
  #95
350z0827's Avatar
350z0827
Well, motor is all together and ready to go in the car. Came home quick to make some dinner becasue going back to the shop and were are working until its running and on the road. Dyno tomorrow!! All went togther smoothly especially since all the bolts ans stuff were new. Just trying to figure out what to do for a tach though since the stock only goes to 8k, he is putting in a autometer for now just to test with so we know what rpm is at. Got he axles and the gear in it this afternoon also so we should be ready to go soon.
Old Sep 8, 2006 | 01:22 PM
  #96
sq40's Avatar
sq40
Your My Hero.
If I ever win the Lottery I want to be just like you.
Old Sep 8, 2006 | 01:27 PM
  #97
Alberto's Avatar
Alberto
Cranky FI Owner
Damn your crew works fast....
Old Sep 8, 2006 | 01:34 PM
  #98
ACEMAN's Avatar
ACEMAN
Master
They sure do!
This has to be the fastest i have ever seen things go together. And i have been a member on this site for 4 years.
I for one cant wait to see the results. Wont be able to sleep tonight, guess i will have to get drunk
Keep up the good work
Later
Aceman
Old Sep 8, 2006 | 01:37 PM
  #99
o snap its eric's Avatar
o snap its eric
i dont know if you saw the top gear vid but 5 professional wrc mechanics can take apart and reassemble a ford focus suspension from top to bottom and unmount and remount the tranny all within 45mins. fasssst
i would love to have mechanics or friends that work a shop that is so dedicated to a car. Put everything in the car with quality in a record time! good job to 350z0827 and crew
Old Sep 8, 2006 | 01:40 PM
  #100
Motormouth's Avatar
Motormouth
darn,.
in regards to the tach, doesn't the Nismo go up to 8500 or so? I can't remember but I think it's higher.
