Aftermarket Drive Shaft ?
Old Jan 25, 2007 | 09:04 AM
mjedens's Avatar
mjedens
Default Aftermarket Drive Shaft ?
Any out there?
Old Jan 25, 2007 | 09:19 AM
shushikiary's Avatar
shushikiary
Yes
use the search function.
Old Jan 25, 2007 | 09:27 AM
mjedens's Avatar
mjedens
Default shushikiary
Smart ***! I wonder why I ever try to participate on this forum.
Old Jan 25, 2007 | 09:40 AM
THE TECH's Avatar
THE TECH
I have to agree with the search! Although I have never heard of the Z needing an upgrade from it's carbon OEM shaft. Here kitty kitty...
Old Jan 25, 2007 | 09:57 AM
mjedens's Avatar
mjedens
The "Search" forum returns no aftermarket driveshafts . The only thing I've found( on my own) is to have a custom one made at the Driveshaft Shop. For those of you who will ever need to replace the u joint, Nissan requires you to buy a whole new driveshaft assembly.(aprox $600.00)
Old Jan 25, 2007 | 10:04 AM
THE TECH's Avatar
THE TECH
Is that why you are looking for an aftermarket shaft, cause you need a new u-joint?
Old Jan 25, 2007 | 10:45 AM
mjedens's Avatar
mjedens
Yes! There are also some limitations on what the OEM will withstand with regards to RWHP coming off the line.
Old Jan 25, 2007 | 11:16 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Took me 1 minute:
https://my350z.com/forum/showthread....ght=driveshaft
There is a phone number on the drive shaft as well
Old Jan 25, 2007 | 12:33 PM
mjedens's Avatar
mjedens
Default Thanks for the try!
I was already aware of the driveshaft that Philthy had made for his G35. I had already called that # you mentioned and found out that the driveshaft he had made still had the stock ends which means I wouldn't be able to change u-joints down the line. They were very receptive though in coming up with something that would work for me.
The reason I started this thread was I wanted to make sure someone wasn't already producing a good quality driveshaft for the 350z .
Old Jan 25, 2007 | 08:58 PM
in2therain3's Avatar
in2therain3
I know that driveshaftshop's carbon shaft one is pretty impressive for the STi.
Old Jan 26, 2007 | 05:44 AM
98sr20ve's Avatar
98sr20ve
I don't know if this applies to the 350Z but for my S13 I found a local shop that was more then willing to make me a driveshaft using the ends that I had. So if you can find a shop local you might be set. I live in a smaller town as well. Price was very good compared to driveshaft shop. Check with the local Speed Shops and get some recommendations.
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
