Slip in Second
on
Slip in Second
hi
i have a 03 ppw touring z(got in august)that sometimes when i shift into second gear from first it says "slip" on the dash. Ive never experienced it in another gear.
What is the cause for this?
thanks
thanks
on
Originally Posted by IronYuppie
hi
thanks
thanks
I’m guessing, but you probably have your RPM limiter set to a lower value than your shift point front 1st to 2nd. If you run up the engine beyond the limiter before shifting, you can activate TCS (TCS is part of VDC in your car).
--Spike
--Spike
--Spike
--Spike
Its actually just the setting for your shift light .
--Spike
--Spike
Originally Posted by cheshirecat79
I thought the rpm setting was just to set the light when to flash. I don't have TCS so I could be wrong. I didn't think it was an actual limiter. I have mine set at 6k and have no problem going to 7.
Boots patrol
Exterior
11-07-2015 12:26 PM
