3.357 Final Drive Gears
Old Jun 13, 2008 | 07:47 AM
mscurfield's Avatar
mscurfield
Default 3.357 Final Drive Gears
I have been doing some reaserch on the longer ratio final drive's for FI aplications and am confused. A while ago I read that your able to just swap out the gears and not the whole pumpkin. Recently I have been reading most people have been swaping the whole pumpkins.
What would be the best way to go? Whole Pumpkin or Ring and Pinion only?
I have also found the part # for the Ring and Pinion 38100-OC760
Any Info/help would be apreciated
Thanks MikeS
Edit: I think this should have been in Tech :/
Old Jun 13, 2008 | 10:32 AM
helldorado's Avatar
helldorado
You can't swap the ring without buying a new LSD at the same time. The 3.357 and 3.538 ring gears are different thicknesses and use different LSD's.
Old Jun 13, 2008 | 11:01 AM
mscurfield's Avatar
mscurfield
That's what I was starting to realize, the more I have been reaserching.
So basicly the best way to go would be get a whole pumpkin?
Or are there any nissan ring and pinions that will fit with the OEM Nissan LSD.
The car is an 04 350TT.
Old Jun 14, 2008 | 01:39 PM
OCG35's Avatar
OCG35
or get 3.3 and AT Quaife (I think it can only be had from UK though) and install both in your pumpkin... its a pricey option (especially shipping for UK), but an option nonetheless...
Also, I think KAAZ makes a diff that fits with 3.3 (I was considering theirs before Quaife... Its been a while since I researched so you'd have to check on that one...
Old Jun 14, 2008 | 07:20 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Cusco makes an LSD for automatic equipped cars...we have them
that part # also is not correct for the 3.3 final drive
Old Jun 16, 2008 | 09:09 AM
JOEGYVER's Avatar
JOEGYVER
I just put 4.08s and nismo LSD in my 07 touring 5AT with 29k miles. I was planning on selling my 3.357s, differential, and axle flanges, if you wanted to go that route and put them in your pumkin. Let me know.
Old Jun 18, 2008 | 08:26 AM
mscurfield's Avatar
mscurfield
Check your PM
Where would the best place be to get a new set of gears?
I saw Z1auto but they only have the higher ratios?
Old Jun 18, 2008 | 08:38 AM
Z1 Performance
Former Sponsor
http://www.z1auto.com/prodmore.asp?m...ne&prodid=3234
Old Jun 18, 2008 | 01:32 PM
mscurfield's Avatar
mscurfield
Originally Posted by Z1 Performance
Thank you Sir, Dont know how I missed it.
Just to make sure.
The car is a 6 speed, to make the gears work I would need to swap in an automatic rear diff and I'm good to go?
Old Jun 18, 2008 | 01:46 PM
Z1 Performance
Former Sponsor
yep!
Old Jun 19, 2008 | 07:21 AM
JOEGYVER's Avatar
JOEGYVER
Z1 is correct, and FWIW, that is whom I purchased my 4.08s from, so thumbs up!
Old Jun 19, 2008 | 09:12 AM
mscurfield's Avatar
mscurfield
Thanks again for the help
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
