burning oil but still normal compression?
Old Sep 27, 2008 | 01:45 PM
GrayG35's Avatar
GrayG35
Default burning oil but still normal compression?
My 04 g35 has been having oil consumption problems, but the compression tests come back fine and no oil is leaking out of the engine. What else can be causing the oil to burn. Is it possible for me to have normal compression and still burn oil? Its consuming almost 1qt every 1k miles....
Old Sep 28, 2008 | 01:00 AM
GrayG35's Avatar
GrayG35
bump??? any ideas?
Old Sep 28, 2008 | 06:39 PM
rcdash's Avatar
rcdash
You could try changing your PCV valve - it may be sucking out more oil during idle that it should be (PCV valves are supposed to pull less air at high vacuum unlike a standard check valve). It's a quick, cheap fix anyway.
Old Sep 29, 2008 | 06:15 AM
Q45tech's Avatar
Q45tech
Ring tension lowers under deceleration sucking oil into combustion chamber is the usual cause.
Old Sep 29, 2008 | 08:41 AM
rcdash's Avatar
rcdash
^ and a blocked/sticky PCV valve would make the situation worse. Ring seal is optimal with moderate vacuum in the crankcase.
Old Sep 29, 2008 | 08:47 AM
Netko350Z's Avatar
Netko350Z
My Z had the same issue but here is the kicker. I dove about 800 HIGHWAY miles and no problem with loss. With city driving I tend to see a some loss.
Driving style plays a part.
Old Sep 29, 2008 | 09:01 AM
rcdash's Avatar
rcdash
yes, and likely for the same reason Q45 mentioned ...
Old Sep 30, 2008 | 05:42 AM
j.arnaldo's Avatar
j.arnaldo
Just keep topping it off; you'll stay outta trouble!
Old Sep 30, 2008 | 11:00 AM
gothchick's Avatar
gothchick
Mine was consuming about 1/4 ~ 1/3 qt per 1000 miles this summer. As soon as the weather started cooling off, I've noticed my consumption is way less now.
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
