bolt ons vs weight reduction
Old Aug 6, 2011 | 08:11 AM
Dgio1223's Avatar
Dgio1223
Default bolt ons vs weight reduction
Lookin to go the route of carbon fiber hood n trunk or basic bolt ins..intake exhaust..etc..
What would be more beneficial?
Old Aug 6, 2011 | 08:27 AM
John1006's Avatar
John1006
Basic rule is that for every 100 lbs you shed, you lose a tenth of a second in the quarter under perfect conditions. Assuming you have a DE motor, they don't respond too well to bolt ons. Full exhaust, your butt dyno might feel a little faster in the higher rpm range. Basic bolt ons though dont do the 350 any justice.
Old Aug 6, 2011 | 08:29 AM
350z-Jason's Avatar
350z-Jason
If you cut the car in half, you save almost 2000 pounds. That's your best bet.
Old Aug 6, 2011 | 08:31 AM
faiz23's Avatar
faiz23
FEZZZZZZ
Go fast or look fast pick one. I would save all your benjamins and go with FI or engine swap if you want real power. If you want to save money but want a little something than get a revup air box with high flow filter, Do a set of HFC, Y-pipe and exhaust. Spend the rest of the money on Suspension and brakes. When you hit a jackpot pick up a SC / turbo kit or throw the VQ motor in the trash and put something decent to begin with in the engine bay.
Old Aug 6, 2011 | 08:49 AM
DavesZ#3's Avatar
DavesZ#3
https://my350z.com/forum/engine-and-...ed-your-z.html
Questions about bolt-ons get asked all the time. Search and read this forum...
https://my350z.com/forum/engine-and-...t-ons-etc.html
https://my350z.com/forum/engine-and-...or-a-350z.html
https://my350z.com/forum/engine-and-...-bolt-ons.html
https://my350z.com/forum/engine-and-...ifcations.html
https://my350z.com/forum/engine-and-...nd-torque.html
https://my350z.com/forum/engine-and-...-on-gains.html
https://my350z.com/forum/engine-and-...wer-gains.html
Old Aug 6, 2011 | 09:10 AM
Ruthless18x's Avatar
Ruthless18x
Who cares? Are you going to track the car or just drive like an asshat on public roads?
Old Aug 6, 2011 | 09:38 AM
aaron.cobb3's Avatar
aaron.cobb3
There is a thread somewhere with all the weight of OEM parts. So find out how much you would lose and do the HP to weight ratio math. I'm pretty sure the link has been provided by Dave.
Old Aug 6, 2011 | 10:28 AM
Arvin89's Avatar
Arvin89
Just to let you know. The 350z hood is made out of aluminum. And very light as is. Getting a Carbon Fiber hood is not going to make a difference at all. You might lose 1 or 2 pounds.
If your really looking to lose weight, look into kevlar products.
Old Aug 6, 2011 | 11:35 AM
terrasmak's Avatar
CF hood is usually a 1/2 pound loss to even a gain, we are not driving honda's. The seats are heavy as hell, a nice weight loss is putting in some quality race seats.
Old Aug 6, 2011 | 12:14 PM
e30cabrio's Avatar
e30cabrio
Which half?
:P
Old Aug 6, 2011 | 02:15 PM
Czarrr's Avatar
Czarrr
My VIS CF hood is only one pound lighter than my OEM hood.
OP, stick with stock hood as mentioned.
This is very true.
Look fast or go fast. Aesthetics and bolt ons vs FI.
+10000000 for this comment.
I get a lot of schit from my homies who make fun of me because they've been with me since the day I got my Z.
It's EASY to put a good 7-8 grand with basic bolt ons and aesthetics.
Does it make your car any faster? Barely.
FI all the way.
Old Aug 6, 2011 | 02:50 PM
DavesZ#3's Avatar
DavesZ#3
Do you know what one single mod make the car go faster and handle better than all others? Training the driver.
Old Aug 6, 2011 | 03:25 PM
DemitriHKS's Avatar
DemitriHKS
I couldn't believe how heavy the OEM cats were. For a DE, doing TP is probably one of the best mods. You lose the weight and gain some HP at the same time.
Old Aug 6, 2011 | 03:34 PM
misterniceguy's Avatar
misterniceguy
A light catback will get your some weight loss and power gain. Like the JIC titanium single. Very light.
Old Aug 7, 2011 | 07:56 AM
I will put as much effort into this as you have. So far you are at zero.
Old Aug 7, 2011 | 01:00 PM
AngelsVQ's Avatar
AngelsVQ
Originally Posted by e30cabrio
Which half?
:P
the passenger side... duh!
Old Aug 7, 2011 | 01:27 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Old Aug 7, 2011 | 01:50 PM
ajcool2's Avatar
ajcool2
exterior
stock hatch: 77 lbs
hatch counterweight: 1.5 lbs
rear wiper and motor: 9 lbs
stock hood: 24 lbs
stock fenders: around 7.7 lbs each
headlight: 15 lbs each
interior
rear mat: 6 lbs
sound dampening "pads" in that space behind seats: about 5 lbs
shift ****: about 206 grams
leather heated seats: 50 lbs each
fabric seats: 37 lbs each
spare, jack, and tools: 40 lbs
headunit and speakers: about 7 lbs together
steel plate + bolts for subwoofer: about 5 lbs
suspension
stock sways: front 10.5 lbs and rear 4 lbs
stock spring and shock assembly: 10 lbs each
stock battery: 36 lbs
Standard Brakes
296x24mm Front Disc = 16.2 lbs
Single Piston Front Caliper = 12.2 lbs
292x15mm Rear Disc = 11.9 lbs
Single Piston Rear Caliper = 6.0 lbs
Track Model Brembos
324x30mm Front Disc = 20.0 lbs
4-Piston Front Caliper = 9.5 lbs
322x22mm Rear Disc = 17.6 lbs
2-Piston Rear Caliper = 4.3 lbs
fluids
full tank of gas: 6.5 lbs x 17 gallons = 110.5 lbs
full tank of washer fluid: 8 lbs
exhaust
plastic intake manifold: 4 lbs
stock headers: 15.4 lbs
rear muffler: 34 lbs
mid pipe: 12 lbs
y-pipe: 16 lbs
catalytic converters: 23 lbs each
wheels
(depending upon air pressure, almost any nissan tire + rim combo will be around 40-60 lbs each)
17" base rims F: 17x7.5 = 23.26 lbs and R: 17x8.0 = 24.140 lbs
18" track rims F: 18x8.0 = 18.1 lbs and R: 18x8.5 = 18.62 lbs
18" perf/touring rims F: 18x8.0 = 27 lbs and R: = 18x8.0 = 27 lbs
18" LMGT rims F: 18x8.5 = 18.3 lbs and R: 18x9.5 = 18.8 lbs
19" LMGT rims F: 19 x 8.5 = and R: 19x9.5 = around 22 lbs
all 20 lug nuts: 2.6 lbs
drivetrain
stock clutch weight: 22.19 lbs
stock flywheel weight: 23 lbs
crank pulley: 6 lbs
ajcool2's Avatar
ajcool2
^I keep this saved on my cell phone
Old Aug 7, 2011 | 04:58 PM
DemitriHKS's Avatar
DemitriHKS
ajcool2, that is a great write up of information. Thanks for posting that.
