Na 380+ rwhp?
Old Sep 30, 2012 | 09:39 PM
  #101
XChacalX's Avatar
XChacalX
Originally Posted by KingBaby
The dyno may be the same but the car putting down power isn't. Due to those factors a car may be stronger or weaker.
it true while the engine is running is a cold weather , if tuned right , yes it will be stronger .
those SAE compensation bring the result to a standard ,, no matter what the weather/temp/altitude/ other variable.
which his standard was what was shown ...
you cant deny how the SAE standard is done.
Old Sep 30, 2012 | 10:11 PM
  #102
KingBaby's Avatar
KingBaby
Hardest Setting
yea...lets get away from that argument...
What mods do you have now?
What mods do you have planned?
Old Sep 30, 2012 | 10:27 PM
  #103
XChacalX's Avatar
XChacalX
right now my mod is a 370z with a MASSIVE weight redution mod !! AKA Flingstone !!
more seriouly look in there http://www.the3 7 0z.com/members-370z-gallery/53619-megan-journal.html
from the start at 256whp to 324whp
what is planned for summer 2013 is yet to be finalized but it should be a whole different engine and ECU
ViPec V88
VQ37HR ( long rod engine with HR head )
JWT C1x with an unconfirmed JWT Exhaust cam
Custom Piston
Custom baffled oil pan ( my own )
*possible dry sump from Daily*
I was told to check back with Nick about his chromoly oil pump gear
depending if the funds are there, if not
HR oil pump with rev limit to 8000rpm MAX !!
Im getting that drysump at the most early 2014
THose Cam setup that talked with JWT are good up to 8800rpm
everything built by myself and the possible help of someone (wiring job)
Old Sep 30, 2012 | 10:33 PM
  #104
KingBaby's Avatar
KingBaby
Hardest Setting
so you're that guy...sucks man.
Well on the VHR I'm sure there is more to be had...
Old Sep 30, 2012 | 10:37 PM
  #105
XChacalX's Avatar
XChacalX
yeah im that guy who blew his VVEL head during a Time attack then blew the oil pump 200 km later on my way home. (6 hours drive )
I will never know how much more power there was left because i was in the middle of a big project that included dual 75mm TB and slightly bigger plenum.
I was 50% finish
anyway it will still be usefull on my future project , its not a complete lost
anyway VVEL suck soo much for racing
Old Sep 30, 2012 | 10:44 PM
  #106
KingBaby's Avatar
KingBaby
Hardest Setting
I've seen that with the guys that have been pushing it hard...I think two others have ruptured their heads?
Go 370Z!
If you do go the HR route should be very interesting.
Old Sep 30, 2012 | 10:50 PM
  #107
XChacalX's Avatar
XChacalX
it is the HR route for sure ...
Im going to start re-assembling my spare HR engine with cable TB and swap that 6MT since my Z had the 7AT within the next few weeks then get that Vipec V88 ECU wired up .
but the big built will only start somewhere around summer time frame...
350Z_Al
Oct 29, 2020 07:44 PM
foxsmp26
Sep 25, 2015 09:48 AM
racingdynamcs
Jun 18, 2003 01:45 PM
mpol99
May 17, 2003 11:28 PM
Toronto350Z
Dec 29, 2002 08:27 PM
