Changing the Differential / Transmission Oil
Old Apr 21, 2008 | 04:04 AM
  #261
Swiffer's Avatar
Swiffer
^according to that, you can use non-Nissan fluids as long as it is the proper type (GL-5 or GL-4) and weight.
Old Apr 21, 2008 | 05:22 AM
  #262
ladyzed's Avatar
ladyzed
Does the differential fluid HAVE to be synthetic?
Old Apr 21, 2008 | 08:36 AM
  #263
Swiffer's Avatar
Swiffer
No, I dont believe so. Its along the same lines of using synthetic in the engine. You dont HAVE to, but its likely better to go ahead and use it.
Old Apr 27, 2008 | 01:19 PM
  #264
KAZ350Z's Avatar
KAZ350Z
anyone know how to replace the diff's seals and have a DIY for it???
Old Apr 27, 2008 | 06:15 PM
  #265
Swiffer's Avatar
Swiffer
What seal are you referring to?
Old Apr 27, 2008 | 07:58 PM
  #266
KAZ350Z's Avatar
KAZ350Z
not exactly sure, but they're the ones on the side i believe. I've been having leaking issues and it might be the problem. I was writing about it in another thread if you look at my posts.
Old May 2, 2008 | 06:51 AM
  #267
PhiSig's Avatar
PhiSig
Wheel Whore
I've gone through all 15 pages, and there was only one mention of overfilling. I have never done this before, but it seems like over filling would be almost impossible right???? Fill the diff and trans up till it start spilling over out the fill hole right? Just make sure to keep the car level, thats all, right guys?
Old May 2, 2008 | 03:43 PM
  #268
Monsta's Avatar
Monsta
You are correct. It is almost impossible to overfill them.
Fill the gear cases until fluid pours back out of them. Allow the fluid to drain back out of the FILL holes then replace plugs.
Old May 2, 2008 | 07:37 PM
  #269
SponGer's Avatar
SponGer
Just did this with Redline fluids in the tranny and diff. Pretty easy, but it sucked having to pump the fluid while on my back.
Old May 3, 2008 | 03:05 PM
  #270
PhiSig's Avatar
PhiSig
Wheel Whore
Thanks for answering my question. Still trying to figure out what to use. I am thinking Redline for the Diff and still kinda up in the air about the trans.
Old May 3, 2008 | 03:49 PM
  #271
kennedy's Avatar
kennedy
Dumb question I know the subaru guys make this mixture called a cocktail for the trans is there anything like that for the Z? If not no big deal just wondering if there is some mixture that is better then just tranny fluid.
Sorry I found it on another website this is what the Subaru guys use.
SOURCE (Taken from Grimspeed performance 7:51 pm 4/3/2008)
Here is the link as well.
http://www.grimmspeed.com/catalog/pr...molnde8928rc27 .
FINALLY!!!....a place to get all the ingredients for the Transmission Cocktail! This cocktail is the famous tranmission oil mix that many many subaru owners have used to fix that bad shifting/grinding manual transmission.
No more searching around town trying to find all the ingredients and not being able to find them all...GrimmSpeed has them all in stock and ready to ship out to you.
If you'd like a smoother shifting gearbox, this is for you.
Package includes:
1 Pennzoil Synchromesh Quart
2 Castrol Hypoy C 80w90
1 Redline Lightweight Shockproof
Old May 3, 2008 | 08:35 PM
  #272
SponGer's Avatar
SponGer
Although the shifter sucks in our cars, I did notice a little more smoothness with the Redline fluids.
Old May 17, 2008 | 02:40 PM
  #273
Swiffer's Avatar
Swiffer
Just got around to doing this today. DO NOT try and use one of those syphon hoses. Its a pita for the diff, and I didnt even attempt to use it for the transmission. The fluid is way too thick to flow at a decent rate. I only have @25k miles, so I'm going to hold off on the transmission until I pick up a suction gun.
And yea, the differential fluid had a strong smell to it. Didnt smell like sulfer, reminded me of the smell of roller coasters
Oh, and I need to pick up a bigger jack to get the car higher off the ground. My normal jack for oil/tire changes could not get high enough on the jack stands. I had the entire car lifted on the stands, but I needed it to be a few notches higher.
Old May 23, 2008 | 09:52 AM
  #274
quakerroatmeal's Avatar
quakerroatmeal
Just curious why is everybody using Redline, Royal Purple etc over OEM? Is there anything wrong with the OEM one? Changing mines tomorrow and I was just going to get OEM for both. Do they even sell any of these at local autozone/oreillys? I don't have time to order.
Old May 23, 2008 | 09:56 AM
  #275
JasonZ-YA's Avatar
JasonZ-YA
I ended up just buying OEM also from Texas Nissan in grapevine...about $9 bucks a quart.
I started this thread looking for local places:
https://my350z.com/forum/texas/360954-where-to-buy-dfw-area-redline-oil.html
I did find that JOTECH did have redline in stock, but they are far from where i live and said nevermind and bought OEM fluids...
- J
Old May 23, 2008 | 01:51 PM
  #276
quakerroatmeal
Thanks for the response. Jason. Also another question is the manual states GL-5 80w 90. Why is it the closest thing or everything I find (Redline, Royal Purple, Motul, etc) all 75w 90? And why does some product does not specifically say if its GL4 or GL5. I found Motul/Redline at Alamo here in Arlington Jason. I will probably pick up Motul since I don't hear that much great things about Redline.
Edit: I just called Alamo and they want 16$ a quart of Motul, think that sounds bit high. I might just go to Courtesy or Grapevine to pick some up. Stupid nissan local to me said they only sell by "bulk". So is it ok to use a product that says meets both GL4 and GL5 for differential fluid? I take it back I guess differential fluid is a lot more expensive then transmission fluid, aren't they the same? I don't know why nissan does not have the GL5 80w 90 in stock but told me it was 18$ a quart for that. Looks like Motul is back on my list, and OEM Nissan transmission fluid.
Old May 23, 2008 | 02:57 PM
  #277
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Amsoil does make GL5 80w90
Reason for something other than OEM is that Amsoil, Redline, motul, et al are a better quality. More temp resistance, and better for your diff and your tranny
Old May 24, 2008 | 07:37 PM
  #278
KAZ350Z's Avatar
KAZ350Z
Package includes:
Let us know how that works for you
Old May 25, 2008 | 12:54 PM
  #279
quakerroatmeal
Just got done changing mines yeterday, used Motul 300 for differential and OEM Nissan MTF for tranny fluid. Shifts very smooth now, the **** used to shake barely when it's in gear and you're driving, now it doesn't even move at all!
Old Jun 2, 2008 | 08:50 PM
  #280
PhiSig's Avatar
PhiSig
Wheel Whore
Still up in the air about everything after reading this post front to back AGAIN.
Would prefer the redline products, but some people are reporting the MT90 is no good, others say something else. Sounds like the 50/50 mix is working ok.
Now for diff, I still am left up in the air now as well, after seeing some people say the redline diff fluid is no good either.
Anyone running anything they REALLY like alot???
