Homemade Catch Can
Old Oct 21, 2008 | 08:06 PM
  #201
OldDirty Z33's Avatar
OldDirty Z33
I read almost this whole thread and was wondering why this mod is so cheap and so efficient then why wouldn't Nissan do this stock?
Old Oct 21, 2008 | 08:50 PM
  #202
blackfairlady's Avatar
blackfairlady
Originally Posted by J. Dub
Can us stock guys gain anything from this?
I'm stock, aside from a popcharger and plenum spacer, and I get oil in my PCV catch can. I have a secondary one for the valve cover and intake on the driver's side, and haven't noticed any oil in that one yet. It's only been on for 500 miles, but then again I didn't expect a lot of oil deposit on that side.
So an answer to your question would be that it won't be the be all and end all that you have one on your stock motor, but if you do, it will just run cleaner and a bit more efficiently.
Old Oct 22, 2008 | 06:58 AM
  #203
300zx1985's Avatar
300zx1985
Probably because they know the average Z owners wouldnt bother with emptying it.
Old Oct 22, 2008 | 08:39 AM
  #204
J. Dub's Avatar
J. Dub
That and they actually GAIN from peoples engines going out...
Old Oct 24, 2008 | 08:29 AM
  #205
Escobar's Avatar
Escobar
yea man, I made mine and after about 6 months there is a nice little pool of oil in it.
Old Nov 3, 2008 | 05:39 PM
  #206
red_magic2000's Avatar
red_magic2000
Does anyone know where I can get a 90 degree elbow that will fit the 3/8 inch hole on the filter. I could only find the straight fittings, and I need a 90 degree elbow.
Old Nov 4, 2008 | 05:54 PM
  #207
Parker01's Avatar
Parker01
So is it safe to pour the condensed oil back into your engine? I installed one in my MX-6 and have a nice pool in the bottom after just 2 weeks, go figure hah. If I can pour this oil back into my engine, hopefully I won't have to keep buying quarts of oil between changes.
I was hoping with purchasing a new car (Z) I would be past the days of topping up my oil, but from all the reading I have done basically every Z motor burns oil . Maybe I will just buy an RSX instead...n't!
Old Nov 4, 2008 | 09:27 PM
  #208
Escobar's Avatar
Escobar
that was only one year I believe...my Z hasn't burned a drop of oil.
Old Nov 17, 2008 | 06:19 PM
  #209
Parker01's Avatar
Parker01
You used the same catch can as me. What did you do about the black valve on the bottom? I didn't realize it when I bought mine but it has a sping loaded valve that opens on the bottom to drain any moisture/grit whenever the system is not under pressure. Therefore everytime you shut your car off the oil will drain out the bottom. Myself I removed the cheap plastic valve from the bowl and tapped it with a 1/4 thread and put in a heavy duty ball valve. Works like a charm.
Old Nov 18, 2008 | 02:50 PM
  #210
ramairZ's Avatar
ramairZ
Get the fitting at NAPA auto parts.
Old Nov 19, 2008 | 12:05 PM
  #211
stealthz's Avatar
stealthz
here's the one I made from the home depot husky version....
Attached Thumbnails Homemade Catch Can-catch-can-1.jpg   Homemade Catch Can-catch-can-2.jpg   Homemade Catch Can-catch-can-3.jpg
Old Nov 20, 2008 | 11:04 AM
  #212
LSX-PWR's Avatar
LSX-PWR
I put in a plastic cap on and then put J B weld all over it.
Old Nov 23, 2008 | 11:56 AM
  #213
drewk's Avatar
drewk
Whats up fellas, I just went FI (turbonetics), my car is having trouble burning oil so Im going to go out and get a hold of these parts. The passenger side is pretty much straight forward. But Im a little confused about the drivers side, is it necessary? I can't stress the amount of time I spend on this forum and the help it has given me throughout the years...
Thanks again everyone.
-Andrew
Old Nov 23, 2008 | 12:31 PM
  #214
stealthz's Avatar
stealthz
-Andrew
well neither are necessary but both help... your drivers side gets oil in the system as well and takes it to your intake or charge side, it's usually not as much oil though... if you don't want a catch can on the drivers side you can also put a breather filter on the drivers side....
Old Nov 23, 2008 | 12:42 PM
  #215
doug's Avatar
doug
i got this hose from home depot also.. its not very good with heat
Old Nov 23, 2008 | 01:09 PM
  #216
stealthz's Avatar
stealthz
yea I figured I would give it a try since I was already there... and I've seen some buddies use it on some of their projects... but thanks for the heads up
Old Nov 23, 2008 | 02:17 PM
  #217
drewk's Avatar
drewk
What does that breather filter do?
I just bought that hose....
Old Nov 23, 2008 | 02:39 PM
  #218
stealthz's Avatar
stealthz
a breather filter lets your crank case breath or vent still without recycling mixed air and oil vapor Back into your intake side....
Old Nov 26, 2008 | 12:55 AM
  #219
stealthz's Avatar
stealthz
yep that hose is junk don't run it....
Old Nov 26, 2008 | 07:47 PM
  #220
drewk's Avatar
drewk
I got the passenger side hooked up. But which hose do I do this too on the drivers side? Any closeup pics would be appreciated.
-andrew
