Homemade Catch Can
Old Feb 21, 2008 | 04:27 AM
  #121
taurran's Avatar
taurran
Originally Posted by tsabrale
I bought this kit, got it ready to go, only to find out it doesn't quite work with the HR. For one, the other intake is in the way, and there are a few more tubes as well. So I wasn't sure which to hook it up to. Has anyone tried to attach a catch can on the HR?
-Joe
There are still two crankcase vents on the valve covers, and they plug into the intake manifold somewhere. Just find those hoses and put the catch cans on those lines.
Old Feb 21, 2008 | 11:26 AM
  #122
tsabrale's Avatar
tsabrale
ima shirimasen
I believe I saw where they were plugged in on the crankcase, but it looks like it has a filter on it, then plugs into the intake on the other side. I guess I need to pull off the cover and maybe take some pictures.
Shariffs has some pretty good pics of the HR apart.
https://my350z.com/forum/showthread....ght=hr+plenium
Old Feb 21, 2008 | 02:50 PM
  #123
invazn's Avatar
invazn
what are you having trouble with? find the pcv on the passenger side and just follow it up. it goes pretty much to the back middle.
Old Feb 21, 2008 | 03:06 PM
  #124
rkemp1's Avatar
rkemp1
Have you finished the install on your HR? If so post some pics of your setup.
Old Feb 21, 2008 | 03:25 PM
  #125
tsabrale's Avatar
tsabrale
ima shirimasen
Not yet. I will try to take some pics. Right now, I am having trouble with locating the PCV. Because of the dual throttle bodies, it's a lot harder to locate. I will give it another shot this weekend when I can work on it during daylight.
Old Feb 21, 2008 | 04:08 PM
  #126
rkemp1's Avatar
rkemp1
I understand man. Im not the best under the hood either, it took me over 2 hours to install those intakes! And since Im not familiar with the engine layout identifying parts is a little harder.
Old Feb 21, 2008 | 04:29 PM
  #127
invazn's Avatar
invazn
its right under the intake tube on the passenger side. pretty much the same place as the older models.
Old Feb 21, 2008 | 04:52 PM
  #128
tsabrale's Avatar
tsabrale
ima shirimasen
That would explain why I didn't see it. I will check it out this weekend.
Old Feb 23, 2008 | 05:57 PM
  #129
invazn's Avatar
invazn
ok, i just installed my oil catch can on my HR. one question though..
the only place i could find to mount my catch can on my heat shield right on the other side of my driver side intake. because of this, i had to use nearly 7 feet of fuel line all together. my question is, can that much hose prove to be problematic? does the intake manifold demand air from the pcv valve sooner than my length of hose can provide?
Old Feb 23, 2008 | 06:18 PM
  #130
tsabrale's Avatar
tsabrale
ima shirimasen
Hmm, for some reason, that doesn't seem right. I just installed it on my HR as well. I will post some pics. I was able to use only the 2 feet of tubing. The PCV is actually located, not under the passenger throttle body, it is located on the Valve cover near the front of the engine. The Intake manifold connected to the PCV is on the back of the engine. I just test it out all day today, and it seems to be working great.
Next posting will be directions for the HR with pics.
-Joe
Old Feb 23, 2008 | 06:49 PM
  #131
invazn's Avatar
invazn
-Joe
here are some cell phone pics of my set up. maybe it will clear up a few things.
i found the pcv just fine. youre talking about this right?
pcv with my new hose.
and the intake manifold tube.
intake manifold with new hose.
Old Feb 23, 2008 | 06:59 PM
  #132
tsabrale's Avatar
tsabrale
ima shirimasen
Yeah, that clears things up. Did you bother pulling out the PCV tube? It was a pain, but I pulled it out after everything was looking like it was working. You shouldn't have a problem. I will post pics of my setup here in a sec.
Old Feb 23, 2008 | 07:01 PM
  #133
invazn's Avatar
invazn
yea i yanked out all the original hoses. maybe thats how you got away with using so little hose. where did you mount it?
Old Feb 23, 2008 | 07:55 PM
  #134
tsabrale's Avatar
tsabrale
ima shirimasen
Default DIY Oil Catch Can with (HR Version)
I finally got some good pics of my install of this on my HR. To start with, you can get all the exact same parts you use for the DE. 2 ft of hose is plenty.
Here is my setup. I went ahead and sealed it with some black silicon. I let it dry for 2 days before install.
HR Before Install
Remove the Engine Cover. It will look like this.
The PCV hose is circled in next pic. I circled it in two places. Where it is connected on the bottom right circle and you can see it continue on the left circle.
Close up of PCV hose connected to the PCV on the Valve cover.
Along the back of the engine, I marked the pcv hose. You can follow it to where it connects on the Intake Manifold.
This is where the PCV hose is connected to the Intake Manifold.
I found it was easier to disconnect this first. So I did.
Then it was a little of a pain to get to the metal hose clip but I got it disconnected.
Ok, for this next phase, I left the old PCV hose in there. Because it is a pain in the butt to pull out, I figure it would be a the same trying to put it back in. So I left it for now while I was testing my DIY catch can.
Here is what it looks like with the DIY connected. Remember he arrow should be pointing towards the intake manifold. Connecting to the PCV is easy. Since it's right up front.
Here is a pic of the hose connected to the Intake Manifold. I marked it here.
Looks like the oil catch can is doing what it is supposed to.
Here are pics of the final install. I cut about another 2 in. off of the front hose, and then got some velcro to hold the catch can in place. This way, I can undo the velcro to make it easier to access the container.
Close up of catch Can
That's it. I have more pics at higher quality here.
http://s204.photobucket.com/albums/b...20Catch%20Can/
So far, I only have about 20 miles on it, but it seems to be working great. I know this will fill up faster with aggressive driving. So far, no errors or leaks. The HR seems to response the same. But at least I have some piece of mind. Also, very easy project. Just like the OP said, around $25.
-Joe
Old Mar 2, 2008 | 09:29 AM
  #135
frizille's Avatar
frizille
Just got done with mine and I've got some install pics from a 2004.5 I'll post up shortly.
One question and I think I'm right but want to be sure - on my Husky can, the one with the #03 in the part number, it doesn't have an arrow but has "IN" and "OUT". I've got the "IN" side connected to the crankcase area and the "OUT" runs to the plenum. Seems logical... but wanted to ask anyway to be sure.
One problem - I've got the catch can mounted and hoses run but hear a hissing noise coming from that general area which indicates an air leak somewhere. I've sealed the bottom valve with silicon already. When I clamp the hose with my fingers after the catch can the noise goes away which would lead me to believe the air leak is after the catch can - if it was before it would be louder because the air would be forced out the same hole right?
EDIT: Did some more troubleshooting and it sounds like the hissing is coming from the can itself. I'm thinking maybe the silicon isn't sealed all the way and that's whats letting out the air. Should this thing be completely silent or should it sound like a balloon being filled (that hollow air sound)?
Old Mar 2, 2008 | 01:31 PM
  #136
BakaN20's Avatar
BakaN20
Anything wrong with getting an ebay oil catch can?
http://cgi.ebay.com/ebaymotors/Red-R...em270215334798
I looked at the lowes one on their website, one was 24.99 for the bigger one!!!
Old Mar 2, 2008 | 06:13 PM
  #137
invazn's Avatar
invazn
nothing wrong with them. just a hollow can. i went with greddy because i guess i just like the name.
Old Mar 15, 2008 | 03:48 PM
  #138
invazn's Avatar
invazn
new setup with the greddy catch can.
Old Mar 17, 2008 | 01:14 PM
  #139
SpoilsofWar's Avatar
SpoilsofWar
For those of you who still have to do this mod, Harbor Freight sells an identical compressor air/water filter for $4.99.
Part # is 94346-2VGA
Old Mar 18, 2008 | 10:53 AM
  #140
JonnyC's Avatar
JonnyC
EXACTLY what I came to this thread looking for, thanks! I was going to run to my local Harbor Freight tonight and wanted to see if they carry it first.
I'm actually going to plug the inlet from the PCV hose on the intake manifold and run maybe just a 1/4" hose over to my Vortech air filter. This way the PCV can remain operational even under boost, and the driver's side breather can just have a filter on it since it will always be sucking air in. Thanks to Quamen for the suggestion.
