Homemade Catch Can
Old Mar 18, 2008 | 04:16 PM
  #141
JonnyC's Avatar
JonnyC
Stopped by after work and picked it up along with some barbs (3/8" and a 1/4" in case i'm going to run a smaller hose to my Vortech filter). It was $10 in the store, so it might pay off to get the better quality one from Lowes. The entire thing is plastic (although thick, heavy plastic) unlike the metal one at Lowes.
Old Mar 18, 2008 | 05:07 PM
  #142
SpoilsofWar's Avatar
SpoilsofWar
Yep, I should have mentioned that it was plastic. Its $4.99 on their internet store, and I was ordering a bunch of stuff anyway.
It being plastic should not matter, as its meant to withstand compressor pressures which are much higher then it will ever see as a catch can. As long as you are more careful with the threading.
Old Mar 18, 2008 | 07:08 PM
  #143
frizille's Avatar
frizille
Finally got the pics off the camera from my install on a 2004.5 VQ. I put some double sided tape on the power steering fluid holder as a pad, left the non-stick backing on, then zip tied the catch can to it. So far no issues after about 1000 miles. Only downside, is you have to cut the zip ties to empty the container. I'll replace with some velcro once I find the big roll of it I got in my garage somewhere.
Old Mar 20, 2008 | 08:03 AM
  #144
tsabrale's Avatar
tsabrale
ima shirimasen
Originally Posted by Escobar
awesome mod, cant believe I missed it for this long. Im still kinda confused on which tubes I need to work with.
If you have an HR, I have them marked clearly the pics on the previous page. I was confused at first, so I made sure to take pics and circle the tubes. GL.
Update, the oil catch can has been working great for my HR. Looks like I have to empty it everyone month or so depending on how much and how hard I drive it. Great cheap mod for HR owners. This should hold me off until I see a after market one I want.
Old Mar 20, 2008 | 02:23 PM
  #145
Escobar's Avatar
Escobar
yeah I got it done today, I fabricated a bracket to hold it in place, I'll snap a few shots. I also used clear tubing so I could see inside it.
Old Mar 20, 2008 | 08:22 PM
  #146
invazn's Avatar
invazn
i have clear tubes too. it is starting to look like oil is getting trapped where the tube from the pcv ends and the valve going into the can begins. anyone else having this problem?
Old Apr 2, 2008 | 05:56 PM
  #147
SpoilsofWar
Heres two I made. Small one, and also a larger metal one because I realized I had an extra air/water filter in the garage.
Old Apr 2, 2008 | 10:33 PM
  #148
BakaN20's Avatar
BakaN20
Nice looking, maybe you should mass market them, lol. I bought an ebay one. It is black and looks pretty nice. I just need to put it on when i have time.
http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
Anyone got instructions on how to install an ebay one, i have an idea, but I just don't want to mess up, lol. Better safe than sorry, better to look like a moron on a forum then on the side of a street with a broken car, imo.
Old Apr 22, 2008 | 09:31 PM
  #149
ladyzed's Avatar
ladyzed
I was told by a veteran member here on my350z to install a catch can due to my engine's pinging problem.
I use 94+ octane and it still pings (04.5 with 30k miles).
Should I ?
Old Apr 30, 2008 | 07:27 PM
  #150
Spork's Avatar
Spork
Old May 2, 2008 | 07:58 AM
  #151
JGTC_350z's Avatar
JGTC_350z
just wondering guys , when u guys start up your car does the line "crush in" because of the vaccuum suction from the plenum?
Old May 2, 2008 | 09:44 AM
  #152
JonnyC's Avatar
JonnyC
That should never happen. It will only happen if there's a blockage in the catch can somewhere that's not allowing air to flow, or the PCV valve would be completely stuck shut for some reason.
Old May 2, 2008 | 10:54 AM
  #153
Spork's Avatar
Spork
The hose I'm using is way too strong to crush in.
But there shouldn't be any blockage that should cause that.
Old May 4, 2008 | 03:36 AM
  #154
JGTC_350z's Avatar
JGTC_350z
johnny , i posted the same question in this thread but people told me it's normal? pls do advice if u think it is not
https://my350z.com/forum/engine-and-drivetrain/356440-will-this-harm-my-engine-crushed-oil-catch-tank-lines.html.
there is no blockages as when i rev the engine the hose with expand ( more air volume going through it?)
Old May 4, 2008 | 10:48 AM
  #155
JonnyC's Avatar
JonnyC
Hmm...it's not going to hurt anything, but I would find some hoses to replace those.
Old May 5, 2008 | 06:58 PM
  #156
350zbra's Avatar
350zbra
Stupid Question: Will this stop my engine from pinging between 2 - 3k r's on tip in? That would be sick cause it's been doing that for quite some time and it makes me want to hang myself. Thanks.
Old May 7, 2008 | 06:21 PM
  #157
Escobar's Avatar
Escobar
here is mine, has been done for a while but I snapped a few shots while cleaning my filter.
Old May 7, 2008 | 08:48 PM
  #158
Escobar's Avatar
Escobar
https://my350z.com/forum/engine-and-drivetrain/357706-ping-is-gone.html
Old May 9, 2008 | 02:53 PM
  #159
350zbra's Avatar
350zbra
Wow!! This works really well after 2 days no more ping! Perhaps now I will be able to sleep at night. Thanks!!
Old May 18, 2008 | 01:39 PM
  #160
gothchick's Avatar
gothchick
Was bored today... Fabbed up a bracket and switched to stainless hose with anodized fittings. I've been running this catchcan with stainless mesh for about a year. Totally happy with it. I cracked open my plenum last weekend just to see how well this catchcan has worked over the last year, and it was spotless. :-)
Attached Thumbnails Homemade Catch Can-dsc02359.jpg   Homemade Catch Can-dsc02361.jpg
