Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2JZ-GTE VVTI swap thread.
Old Jan 29, 2014 | 07:19 AM
  #321
graffkid732's Avatar
graffkid732
I don't know your budget on a rad and fan setup, but Sean at Titan is going to be building me a setup similar to his. Dual pass with 2 SPAL fans to fit the Z and have 2jz outlet/inlet.
I'm sure he can build something that will fit and perform your needs.
Old Jan 29, 2014 | 08:00 AM
  #322
midz350's Avatar
midz350
The custom radiator core will give me the ability to run whatever setup I want.
Old Feb 2, 2014 | 01:42 PM
  #323
NOLAGG's Avatar
NOLAGG
Hey man whatsup build is solid as I've recently said , but I was just wondering with you having to get a custom rad support and what not what caused this ? I've seen the swap done a lot cheaper and less labor intensive . I do want to do this to my Z soon and will probably start by picking up an aristo motor swap and do the basic maintenance on it in my garage while on a stand I till I can gather all the parts I need which is the reason I'm asking .
Old Feb 3, 2014 | 05:11 AM
  #324
graffkid732
If I had to guess, it's due to the engine mounts which brought the engine more toward the radiator instead of back toward the firewall.
Old Feb 4, 2014 | 12:12 PM
  #325
midz350's Avatar
midz350
Because the CD0009 is taller than the R154 which most are using, it pushes the engine forward. It was either a custom rad support or install push-type fans.
graffkid732, since the V160 is almost as tall as the CD0009, did you test fit everything yet?
Old Mar 7, 2014 | 05:34 PM
  #326
midz350's Avatar
midz350
I have not updated this in awhile.
A sneek peak for now:
Old Mar 10, 2014 | 01:29 PM
  #327
midz350's Avatar
midz350
And to help people out, here is how to wire and start the 2JZGTE: (Aristo JDM harness)
E10 is the small one. E9 is the bigger one on the left.
I collected the info from the internet. I will test it out this week and report back later.
Attached Thumbnails My 2JZ-GTE VVTI swap thread.-pinout-toyota-120p.png   My 2JZ-GTE VVTI swap thread.-201104221920-jzs147-engine-body-pinout.png
Old Mar 11, 2014 | 12:27 PM
  #328
Highway Riding's Avatar
Highway Riding
Nice teaser Mid... Keep it up man you'll be romping on her in no time!
Old Mar 14, 2014 | 04:33 PM
  #329
3fidzhr's Avatar
3fidzhr
So did you have to notch your crossmember ? I ended up scraping the idea of stock mounts. Motor was to far forward and had to much angle for my liking. So had to make new mounts and I notched the cm. sits great now and I was able to push it back just over an inch. Which gave me 3.25 inches to fit fans.
Old Mar 14, 2014 | 05:08 PM
  #330
midz350's Avatar
midz350
No. I had to make a custom rad support. Will take pics after I cleand it up.
Old Mar 16, 2014 | 04:03 PM
  #331
NOLAGG's Avatar
NOLAGG
[IMG]https://my350z.com/forum/attachment.php?attachmentid=361888&d=1394486749[/IMG
Hey man now when you say start and running what else is involved to actually drive it lol and I'm assuming you needed to extend certain wires and what not ?
Old Mar 16, 2014 | 06:00 PM
  #332
midz350's Avatar
midz350
The JDM aristo harness does not come with the E10 plug. You can get it out of a GS300, GS400 or an IS300. I will take my harness and AEM to someone tomorrow who is familiar with the 2jzgte harness and make him wire it for me and remove all the unneeded wires and plugs. I don't want to fry my AEM or start a fire
You also need to wire the starter, fuel pump, hook up the VQ water temp sensor, wire the A/C (if you want it), make power steering lines for the 2jz PS pump and you have a driveable swap to the exhaust shop. I may forgot a thing or two, but that is the main things for a swap.
Old Apr 2, 2014 | 06:08 PM
  #333
midz350's Avatar
midz350
I just got my harness back. Costed me like $450. All that is left to do is to pick up the E10 connector plug tomorrow from the junkyard, wire it and start the POS car
Old Apr 4, 2014 | 03:19 AM
  #334
Classy's Avatar
Classy
Sounds so easy
Old Apr 4, 2014 | 05:29 PM
  #335
Cubano4ever's Avatar
Cubano4ever
why the shop that did you swap didnt do the wiring???????
Old Apr 4, 2014 | 07:52 PM
  #336
midz350's Avatar
midz350
It took him 5 months to finish the swap, I don't want to wait another 5 months more for him to figure out how to wire it.
Also this guy knows the 2JZGTE harness like the back of his hand. He removed everything that is not needed from the harness, extended it and soldered in the new sensors and injectors.
Old Apr 4, 2014 | 11:43 PM
  #337
O.G's Avatar
O.G
The dream build right here, where are u located at? Can't find a shop willing to do this build for me
Old Apr 7, 2014 | 06:21 AM
  #338
Highway Riding
RT tuning might consider doing this swap but it isn't cheap and quick and will be a paper weight in the average NJ shop. Import Intelligence is where I go to get swaps done but they are also in PA. I'd advise against this swap if you plan on getting a NJ inspection. Sorry for the OT Mid. Nice Harness and GL starting her up!
Old Apr 8, 2014 | 03:16 AM
  #339
midz350's Avatar
midz350
O.G, I don't live in the US, so price of parts and labor won't be even close.
I had a misunderstanding with the guy who was working on the car with me, so I towed it to another shop. They will work on the exhaust and doing some body work at the same time. I'm between jobs now and moving to another city by the end of this month. Hopefully it will be finished by then.
Also ordered a new set of wheels and a couple of OEM parts from CZP.
And I finally gave in for now on getting the OEM tach to work and ordered the Speedhut gauge.
Old Apr 8, 2014 | 09:38 AM
  #340
midz350's Avatar
midz350
Speedhut art dept just sent me this:
I love this company already.
