Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2JZ-GTE VVTI swap thread.
Old Apr 9, 2014 | 05:12 AM
  #341
NOLAGG's Avatar
NOLAGG
Whatsup midz, if you don't mind me asking where are you from ?
Old Apr 9, 2014 | 07:09 AM
  #342
midz350's Avatar
midz350
Middle East.
Old Apr 19, 2014 | 01:29 PM
  #343
midz350's Avatar
midz350
Pics of the car at the shop getting some body work and exahust fabrication.
I ordered a Walbro 485 fuel pump just to make sure I break 700whp on C16.
Also a lot of other small stuff.
P.S. please, dont mind the stock wheels. Witing for the ES2 19" to arrive. 19" 10" +15 fronts and 19" 11" +15 for the rear.
CZP
Attached Thumbnails My 2JZ-GTE VVTI swap thread.-cam00098.jpg   My 2JZ-GTE VVTI swap thread.-cam00097.jpg
Old Apr 26, 2014 | 11:17 AM
  #344
Cubano4ever's Avatar
Cubano4ever
How is everything .. Is the car running yet
Old Apr 27, 2014 | 02:56 PM
  #345
midz350's Avatar
midz350
Its 99% done. Just need to hook up the harness and start it. Should be this week hopefully.
Just got the wheels
Attached Thumbnails My 2JZ-GTE VVTI swap thread.-cam00101.jpg   My 2JZ-GTE VVTI swap thread.-cam00102.jpg
Old Apr 27, 2014 | 10:22 PM
  #346
Resmarted's Avatar
Resmarted
Looks good man!
Old May 31, 2014 | 04:34 PM
  #347
midz350's Avatar
midz350
I haven't updated this thread in a while. I have been busy with a new job and relocating to another city. Car is almost finished, but need to connect some wirings and clean it up.
Also, just bought another car. A clean 2003 Q45. Will post pics when I get it.
Here is the custom Speedhut gauge I ordered. Looks exactly like the OEM one.
Attached Thumbnails My 2JZ-GTE VVTI swap thread.-cam00141-01.jpg   My 2JZ-GTE VVTI swap thread.-cam00140-01.jpg   My 2JZ-GTE VVTI swap thread.-cam00138-01.jpg
Old May 31, 2014 | 04:49 PM
  #348
midz350's Avatar
midz350
Thumbs down
New Varreston wheels. 19" 10" +15 and 19" 11" +15 for the backs.
Old Sep 19, 2014 | 07:15 PM
  #349
NOLAGG's Avatar
NOLAGG
Car done yet?
Old Sep 24, 2014 | 06:44 PM
  #350
Resmarted's Avatar
Resmarted
That speed hut gauge is very nice. Really oem
Old Sep 24, 2014 | 07:23 PM
  #351
midz350's Avatar
midz350
Sorry, I was super busy with the new job and the moving.
I took the car to another shop. The old one was half assing the work at the end. Took the engine out to change one of the engine mounts. And sending a lot of parts for polishing.
The new shop is very slow at work and I'm not rushing them. I just want them to do it right this time.
I'm really enjoying the Q45. Its a clean 2003 that has only about 100k on the odometer. Its fast and comfy.
Old Oct 26, 2014 | 09:22 PM
  #352
2jz350z's Avatar
2jz350z
Cool project bro, I wonder how can I get the exact speedhut gauge that you have?
Is there a part number or its fully customized?
-Ghandi
Old Oct 26, 2014 | 09:56 PM
  #353
midz350's Avatar
midz350
-Ghandi
Its a custom one.
Send them an email and ask them to make you one just like the Order ID: 75500 - Order Date: 4/8/2014.
It was only like $180.
Its good to see another guy from the Gulf. I'm in Jubail
Old Oct 27, 2014 | 03:59 AM
  #354
NOLAGG's Avatar
NOLAGG
Originally Posted by midz350
Its a custom one.
How are you getting the speedo and engine temp to function with the can bus? Also are you retaining ac or any hvac controls and traction and how? Thanks
Old Oct 27, 2014 | 04:33 AM
  #355
midz350's Avatar
midz350
The speedo should work normally. And you need to use the engine temp from the VQ and hook it somewhere in the cooling system. They dont use the can bus system.
Yes, Im retaining the A/C.
Im not sure if traction is going to work. Its useless anyway.
Old Oct 27, 2014 | 04:56 AM
  #356
jdmlove1's Avatar
jdmlove1
^^ allot of 350z 2jz swaps going on in UAE...
are you using 350z transmission cd008 or cd009 ?
Old Oct 27, 2014 | 05:10 AM
  #357
NOLAGG's Avatar
NOLAGG
Me personally was going to go with my 03 cd008 transmission just for the simple fact I have meticulously maintained it, didn't grind , externally slaved and fig I'd run it till it needs a rebuild then rebuild with 009 internals. The thing is I'm trying to come up with a solution to the adaptor plate clutch/flywheel set up with out having to spend ask that cash for the kits that are out there.
We should have a 2jz swap thread.
Old Oct 27, 2014 | 06:09 AM
  #358
midz350's Avatar
midz350
Speedo get the signal from the rear diff's ABS sensor. It will work normally. It does not use the can bus.
The same for the engine temp. Just use the VQ temp sensor and install it with one of these or find a way.
Old Oct 28, 2014 | 08:38 AM
  #359
NOLAGG's Avatar
NOLAGG
What gas pedal and throttle cable are you using?
Old Oct 28, 2014 | 09:50 AM
  #360
midz350's Avatar
midz350
I'm using the OEM pedal and welding the cable to it.
The cable is out of old an Nissan Cefiro/Altima. It's a perfect fit.
Will try to go and get some pics.
