FI on 5AT without reflash
Old Nov 1, 2005 | 07:24 AM
Oleg's Avatar
Oleg
Default FI on 5AT without reflash
Can you run TN-ST on 5AT with SGP VB and a 2800-3000 stall speed TQ, but keeping the redline at 6600 without missing the 1-2 shift?
This spring as I going FI with the TN. I am debating getting the tuner kit with Greddy EU, a return fuel system w/440 cc injectors, a walbro pump and the above mentioned tranny parts. This way when I am ready for more power I can just swap in a built motor and raise the boost. Should the TS reflash be a part of the setup or it is not necessary?
And MIA, when you read this, if I got a boost controller at this stage of the game, would I be able to turn the boost down if the weather goes to crap? Like run 8-8.5 psi when I feel like going crazy and turn down to 4-5psi when driving in rain or snow?
Old Nov 1, 2005 | 08:40 AM
MIAPLAYA's Avatar
MIAPLAYA
Yes you could as long as you get a lower PSI spring. Which Turbonetics can provide you if need be...as for the flash and not bouncing off the limiter I couldn't say for sure//
Old Nov 1, 2005 | 09:32 AM
Oleg's Avatar
Oleg
MIA, once again, if best case scenario for both, how much $ is the difference between the full and the tuner kit?
Old Nov 1, 2005 | 09:35 AM
MIAPLAYA's Avatar
MIAPLAYA
Tuner kit is a few hundred less then the full kit but does not come with injectors, flash, or fuel pump.
Old Nov 1, 2005 | 09:46 AM
Oleg's Avatar
Oleg
Does the TN re-flash work with any larger injectors? And if it does, can it still be run at 5 psi?
Old Nov 1, 2005 | 09:48 AM
MIAPLAYA's Avatar
MIAPLAYA
The reflash is designed for 380cc injectors but TS can reflash for bigger if need be. Although if you run an EU it wont matter.
Old Nov 1, 2005 | 11:12 AM
Oleg's Avatar
Oleg
Can they just do a limited flash for the redline and speed limiter? Or they don't do custom flashes?
Old Nov 1, 2005 | 11:13 AM
MIAPLAYA's Avatar
MIAPLAYA
Well Turbonetics doesn't typically do that kind of reflash work but TS can do that for you. I think its fairly cheap for that too. I think its called the L-Spec flash.
Old Nov 1, 2005 | 11:19 AM
roncfpz's Avatar
roncfpz
Yes, it's the "L" spec flash and it costs $395.
Old Nov 1, 2005 | 11:20 AM
MIAPLAYA's Avatar
MIAPLAYA
Well not as cheap as I thought but then again I imagine its worth it if you have a 5AT and drive on auto mode a lot.
Old Nov 1, 2005 | 11:23 AM
SungNamZ's Avatar
SungNamZ
The "L" Flash does Rev Limit, Speed Limit and 100% Throttle. TS can also flash for larger injectors.
Old Nov 1, 2005 | 11:29 AM
Oleg's Avatar
Oleg
I am just looking to have to discard a few pieces as possible when I am ready to make more power. So with all this extra stuff, like bigger injectors and a limited flash I can still buy one for 4300-4400?
Old Nov 1, 2005 | 11:50 AM
MIAPLAYA's Avatar
MIAPLAYA
It should be close to that:
I believe the tuner version is 3-400 cheaper then the full version. I'd need to ask a vendor for sure though.
RC 440s are $530
Emanage Ultimate with harness is $595
Full return system is $970
L Spec flash is $395
Old Nov 1, 2005 | 02:29 PM
Nismo 350z's Avatar
Nismo 350z
Then whats their $595 flash?
Old Nov 1, 2005 | 02:51 PM
MIAPLAYA's Avatar
MIAPLAYA
full tuned ECU including fuel and timing...
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
whosdady
Mar 10, 2004 11:40 PM
whosdady
Nov 27, 2003 05:42 AM
350zach
Nov 9, 2003 03:03 PM
EL Diablo
Oct 14, 2003 03:23 PM
